Sat, Feb 1, 5:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: SP3's rig?
  • 1
  • 2
pjz99 ( ) posted Tue, 03 March 2009 at 5:45 PM · edited Sat, 01 February 2025 at 4:59 AM
Is it just me or is SP3's rig borked?  The joint parameters for left and right shins are not symmetrical (see pic).  I've been trying to rig a pair of shoes this afternoon and having a lot of problems, I'm pretty sure this is why.  This pic is of the actual character figure's shin Bend parameters, but the problem appears to be present in the "BLANK" figure (rigging bone donor) as well.  Have other people noticed this?
edit: I see the same thing in V4's shins.
My Freebies
pjz99 ( ) posted Tue, 03 March 2009 at 5:51 PM
M4's shins are correct, the falloff zones overlap perfectly (as I'd expect).
My Freebies
pjz99 ( ) posted Tue, 03 March 2009 at 6:02 PM
More: the same problem in David (not really surprising) - no similar problem in Sydney or Simon (surprisingly, Jessi is OK here too).
My Freebies
IsaoShi ( ) posted Tue, 03 March 2009 at 7:12 PM
For some reason in the past few days I've been getting all hot and bothered whenever I read your forum posts. I'm going to have to try to ignore them... sorry.
DarkEdge ( ) posted Tue, 03 March 2009 at 7:30 PM
Pjz, who is SP3?
pjz99 ( ) posted Tue, 03 March 2009 at 7:36 PM
DAS Stephanie Petite 3...
My Freebies
pjz99 ( ) posted Tue, 03 March 2009 at 8:42 PM
I'm pretty convinced now the rig is just bugged and I'm not going to get anywhere trying to work around it - while I guess I could noodle around in the rig and try to fix it for myself, the result wouldn't distributable anyway.  Is there some fix that's in common circulation?
My Freebies
TrekkieGrrrl ( ) posted Wed, 04 March 2009 at 5:05 AM
 Thing is.. from your pic I can't see the problem. You're saying the kleft and right shin aren't symmetrical.. but this only shows one of them. How much are they off? A lot or a little?
It seems weird that if this is a major problem, nobody would have found/made a fix for it by now :) After all there are lots of shoes ect out there for the characters (Oh speaking of shoes: THANK YOU for that awesome shoe tutorial! I'll have to see if it's adaptable to Hexagon ^_ ^)
pjz99 ( ) posted Wed, 04 March 2009 at 5:11 AM
In the pic, the falloff zones for left and right shins are shown from the right non-orthographic (flat) camera, and they are not oriented the same way (hopefully more obvious in this pic)
My Freebies
pjz99 ( ) posted Wed, 04 March 2009 at 5:15 AM
M4's shin JPs overlap perfectly (as I'd expect):
My Freebies
pjz99 ( ) posted Wed, 04 March 2009 at 5:17 AM
There are lots of shoes out there, but not that many high heel shoes for SP3 specifically - I own exactly one, and it is clearly rigged wrong:
My Freebies
ksanderson ( ) posted Wed, 04 March 2009 at 5:27 AM
Maybe Blackhearted knows more. He did one of the best SP3 characters - Irina 2.0.
Kevin
pjz99 ( ) posted Wed, 04 March 2009 at 5:29 AM
This is the kind of problem I'm having - the left two pairs shoes are V4 , 1 free and 2 conformed to the zeroed figure, the right two pairs are SP3, 3 conformed to the zeroed figure and 4 free.  The rig for both shoes has had Poser's "Figure -> Symmetry -> Right to Left -> Include joint setup" done, but the SP3 rigs are obviously not applying a symmetrical deformation - ergo, something is screwed up with the rig.  I got this to to work twice in a row with V4, but spent a day on it with SP3 and couldn't get anywhere.  It's acting like one of the conform target figure's leg bones is not oriented the same way as the other side's counterpart.
My Freebies
pjz99 ( ) posted Wed, 04 March 2009 at 5:31 AM
Quote - Maybe Blackhearted knows more. He did one of the best SP3 characters - Irina 2.0.
Flat shoes only, I suspect he ran into a similar problem and came to the same conclusion.
My Freebies
Blackhearted ( ) posted Wed, 04 March 2009 at 6:26 AM
Quote - Flat shoes only, I suspect he ran into a similar problem and came to the same conclusion.
:P
i actually did try to make high(er)-heeled boots but was having issues conforming them, this may have been a factor.
at the time i didnt know why things werent working right, just that they werent - i just went back and made flat heeled boots.
thank you!
pjz99 ( ) posted Wed, 04 March 2009 at 6:38 AM
Okay, good enough for me ^^
My Freebies
TrekkieGrrrl ( ) posted Wed, 04 March 2009 at 4:53 PM
 Hm this is interesting. So there's really no heels for SP3? (or David for that matter.. he COULD walk in boots with a heel...)
Now.. I don't know how these are grouped, if you have a left and a right shoe or both shoes loads as one, I've seen conforming shoes done both ways... IF they load as one, perhaps you could split them and conform them as two totally separate things (mentally think of them as a shoe and a glove that just happens to be on the foot LOL)
Dunno if it would help but it's certainly weird, and very interesting. Also that no one has apparently pinpointed the problem before.
How about Aiko3? Isn't she a sort of SP3 with a morph? Because IF the problem is solved in Aiko you might be able to use her as a donor for the JP's and transfer them to SP3.
pjz99 ( ) posted Wed, 04 March 2009 at 5:33 PM
I wouldn't say there are "none", but I have seen few, and I only own the one pair. Since this is my own model, it's grouped however I want it to be and could be split up into separate files if that would help, but I don't think it really would.  The problem appears to be that SP3's bone - the character's bone - is skewed or scaled in some way that is not obvious.  I guess I could manually rig each shoe, but - well - that isn't worth my time for a model that at best would have been handed around as a freebie anyway.
Not real excited to model shoes for A3, although I wouldn't mind for Ingenue V3/Glamourous Vickie (they're actually ready made for heeled shoes, a bit over the top).
My Freebies
DarkEdge ( ) posted Wed, 04 March 2009 at 6:31 PM
You are an experienced operator Pjz so please don't take my suggestions in the wrong way...just trying to help. 😉
I've had the Poser Blank rigs do strange things before as well. Then I create my own BlankCR2 for that figure and it all works just fine. Most times I delete the IK's, but sometimes I need to keep them in otherwise things go wonky.
With all that said I fear that even if you did have a good Blank CR2 to go from it will still be screwed up as it is just trying to do what the figure rig is doing, and since the figure rig isn't sure what it wants to do at this point (not symetrical) then...???
Just for sh*ts and giggles trying conforming them with the IK's on, see what happens. That's pretty much what I do when up against the wall, I'll just try stuff to eliminate that option from my trouble shooting...more or less throw things against the wall to see if they stick.
Good luck to you! 😄
pjz99 ( ) posted Wed, 04 March 2009 at 7:33 PM
I'm not very interested in trying things at random when the character's rig is obviously a bit screwed up (mismatched falloff zones e.g.).  If it wasn't important enough to DAZ for them to fix one of their own flagship characters at some point during the past several years, who am I to go against the trend?
My Freebies
DarkEdge ( ) posted Wed, 04 March 2009 at 7:38 PM
Quote - If it wasn't important enough to DAZ for them to fix one of their own flagship characters at some point during the past several years, who am I to go against the trend?
Agreed. 😉
Paloth ( ) posted Fri, 06 March 2009 at 5:52 AM
Just as an experiment, I attempted to correct Steph 3’s rig by using Symmetry/Right Leg To Left Leg and checking ‘yes’ on the ‘Do you want to copy the joint zone’s setup also?’ box. This simply will not work on Steph 3’s shins. The falloff zones remain asymmetrical. The fact that it should work but it doesn’t is another example of how messed up Poser Setup can be.
Spanki ( ) posted Sat, 07 March 2009 at 3:30 PM · edited Sat, 07 March 2009 at 3:32 PM
I don't have any immediate answers for you, re: high-heeled shoes, but to answer your question - yes, SP3's rigging is horked (IIRC, V3's is somehwat off as well).  In fact, it's not just her legs/feet - if you check the 'center' of each joint, you'll find that her neck (? head? chest?) are not exactly at 0.0 on the X axis either.  It was a royal pain in the you-know-what when I was rigging the SP3 clothing (stockings and lingerie).
Daz is pretty sloppy about this with some figures, unfortunately.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Conniekat8 ( ) posted Sat, 07 March 2009 at 9:30 PM
When I was making stormchaser boots for V4/GND, I had issues with this too. Finally I made a morph to squeeze the feet/legs into the boots.
Not only is it not symmetrical, but there's some sort of a rotational shift to the shins between the original mesh and what you get when you use the cr2 (developers blank or not).
It all boils down to a lot of fiddling around to fit boots.
wdupre ( ) posted Sun, 08 March 2009 at 1:53 AM
I am pretty sure that this has something to do with poser's gimbol lock bug, the reason I suspect this is becouse if you look at the rig in studio there is no symmetry issue the falloff spheres are identical. but look at the identical joint in poser and the left one has flipped
pjz99 ( ) posted Sun, 08 March 2009 at 4:11 AM
Oddly, I didn't have a problem rigging boots for V4.  I don't think the problem is the same for that figure, even though the rig is still not symmetrical (at least in Poser).  Currently working on a set of boots for M4, I'm optimistic about those since M4's rig appears to be symmetrical around that area.
My Freebies
Conniekat8 ( ) posted Sun, 08 March 2009 at 2:00 PM
Sorry, if it came across that way, I wasn't suggesting that the problem is the same with SP3 and V4. I never rigged SP3, so I wouldn't know.
I saw you mentioning in the first post that the problem you were seeing in SP3, you were seeing in V4's rig too.
PJZ's first post:
*Is it just me or is SP3's rig borked?  The joint parameters for left and right shins are not symmetrical (see pic).  I've been trying to rig a pair of shoes this afternoon and having a lot of problems, I'm pretty sure this is why.  This pic is of the actual character figure's shin Bend parameters, but the problem appears to be present in the "BLANK" figure (rigging bone donor) as well.  Have other people noticed this?
edit: I see the same thing in V4's shins. *
pjz99 ( ) posted Sun, 08 March 2009 at 2:30 PM
Yeah I hear you - I'm saying the problem appears to be much worse with SP3 than it is for V4.  If you want to, you might compare the boots I included with my last freebie and see how their rig looks next to yours.  I got this to work a couple of times in a row for V4, but for SP3 I never got a decent joint arrangement.  I can see that the V4 rig is also not symmetrical, but for whatever reason it didn't cause the same degree of trouble when rigging shoes for her.
My Freebies
Conniekat8 ( ) posted Sun, 08 March 2009 at 8:39 PM
Quote - Yeah I hear you - I'm saying the problem appears to be much worse with SP3 than it is for V4.  If you want to, you might compare the boots I included with my last freebie and see how their rig looks next to yours.  I got this to work a couple of times in a row for V4, but for SP3 I never got a decent joint arrangement.  I can see that the V4 rig is also not symmetrical, but for whatever reason it didn't cause the same degree of trouble when rigging shoes for her.
Gotcha :)
I've been using the DAZ's figure setup tools more and more... for the JCM mostly at the moment. Can't wait to try it on a rig... but that's probably few weeks down the road. If you;re curious, I'll share my experience(s)... while they're fresh. I don't do enough of it to have it memorized later on... One rig every two months doesn't cut it.
pjz99 ( ) posted Sun, 08 March 2009 at 9:01 PM
I'm interested to see how that works, sure - probably would be useful to everyone to have a little pictorial walkthrough of it in its own thread.
My Freebies
TrekkieGrrrl ( ) posted Sun, 08 March 2009 at 9:18 PM
 Hm but IF It's a Gimbal Lock problem, shouldn't all Poser figuressuffer from it? Which apparently they do not.
Will, I'm absolutely not saying it isn't so, actually it sounds like a very good explanation.. I just wonder why some Poser characters seem to suffer from this more than others.
And especially that the native Poser figures has less problems.COULD it be (and PLEASE..this is not a DS vs Poser debate by any means) that Daz figures are geared more towards DS while Native Poser figures are .. well meant for Poser?
And how are they rigged differently?
It's interesting for me. Purely from a curious point of view :)
pjz99 ( ) posted Sun, 08 March 2009 at 9:48 PM · edited Sun, 08 March 2009 at 9:49 PM
I think it more likely, the DAZ figures are not tested as thoroughly in Poser - they're definitely marketed for Poser "loud and proud".
I took a look at the joints of SP3 vs. EF Sydney (who does not show this kind of problem) and the only thing that really jumps out as different is that the DAZ figure's endPoint, origin and orientation values are carried out to much further decimal point precision (7 places) and some values are small enough that they probably should have been simply zero'd (e.g. -0.008something).
A couple of values in particular in the jointX block for the SP3 shin (where the falloff zones are described) are pretty ominous:
0.0619999 8.45394e-005 0 0
-1.50849e-011 0.167996 0.00151762 0
-9.73378e-014 0.00108402 -0.119998 0
I know that's scientific notation, I wonder if it's being interpreted correctly by Poser.
My Freebies
pjz99 ( ) posted Sun, 08 March 2009 at 9:55 PM · edited Sun, 08 March 2009 at 9:55 PM
Incidentally, while this problem does not manifest on Sydney's shin bones, it does show up at the buttock bones:
My Freebies
pjz99 ( ) posted Sun, 08 March 2009 at 9:57 PM · edited Sun, 08 March 2009 at 9:58 PM
I don't think it's a coincidence that, in Sydney's buttock bones, there are similar very tiny non-zero values for some of the jointX (falloff zone) parameters:
0.0718686 0.0541607 **-0.000383462 0
**0.0611069 0.312 8.3968e-005 1
My Freebies
pjz99 ( ) posted Sun, 08 March 2009 at 10:24 PM
Surprisingly, Simon's rig appears to be OK - I would have thought problems similar to Sydney's would manifest, but nope.  While Simon's joint params do contain some very small values, none are smaller than e-07 unless they are simply zero.  However, this isn't really out of line with Sydney's joint param values (none of hers are smaller than e-06 unless they're zero).  Maybe it's that one specific joint param is of a data type that is too small to contain the value recorded in the CR2 (insufficient precision), and by luck, Simon is OK while Sydney is not.
My Freebies
pjz99 ( ) posted Sun, 08 March 2009 at 10:56 PM
As an experiment that I shouldn't have wasted my time on, I tried rounding most of the values in Sydney's JPs for the screwed up area - this did not help or affect the problem, so it doesn't seem to be related to interpreting the precision of these numbers correctly.  I have no real idea why this problem pops up consistently for one figure and not for another.  I'm also seeing the retarded tumbling falloff zones behavior, so it can't even be fixed manually, it's simply impossible to get the falloff zones to line up even when manually typing the correct values in each field - simply selecting a field in Parameter Dials causes the falloff zone to move!
My Freebies
pjz99 ( ) posted Mon, 09 March 2009 at 1:59 AM
More wasted time: I slapped SP3's rig around until it appeared completely symmetrical and turned that into a pose.  This doesn't do anything useful however, because a conformed figure still produces asymmetrical deformations.  Somehow, one of the leg bones is "upside down" or "backwards", or it is being interpreted as such by Poser anyhow (is there a difference?)
At any rate, I cheated and got my goddamn SP3 shoes rigged any damn way, I twisted the character's toe -9 degrees (that's how badly off this is).
My Freebies
pjz99 ( ) posted Mon, 09 March 2009 at 3:37 AM
Bite me Poser!
My Freebies
Paloth ( ) posted Mon, 09 March 2009 at 7:02 PM
SP3’s shin falloff zones appear symmetrical when viewed in Daz Studio. Also, her foot bones are located separate from the toe bones and point out horizontally above the foot geometry. In Poser, the foot bones have snapped to the toes and the shin zones are out of whack.
pjz99 ( ) posted Mon, 09 March 2009 at 7:12 PM
Well, I don't think DAZ is going to put a disclaimer on figures with this kind of problem e.g. "This figure doesn't work correctly in Poser, sorry".  I guess I could spend $300-400 on D|S to try to get it close to Poser in function - well, no.
My Freebies
Paloth ( ) posted Mon, 09 March 2009 at 7:21 PM
Yeah, Poser rules and all that. I just wish they'd fix the Setup bugs. One of these bugs is that a bone will always snap to its first child.
pjz99 ( ) posted Mon, 09 March 2009 at 9:09 PM
Oh, I'm not saying Poser's the perfect app.  It's not even a very good app in terms of interpreting its own content.  I'm just not eager to sink several hundred bucks into D|S to get a maybe better Poserish app - I guess I'll stick to the figures that are rigged correctly (or at least, less incorrectly).
My Freebies
pjz99 ( ) posted Mon, 09 March 2009 at 10:36 PM · edited Mon, 09 March 2009 at 10:36 PM
Too irritating - this shoe rig actually works correctly in D|S (symmetrical deformation).  So much money I've wasted >.
My Freebies
Paloth ( ) posted Tue, 10 March 2009 at 12:34 AM
That looks good. The one thing that worries me is that when I start rigging for Poser in Daz Studio, Poser might not be able to correctly interpret the exported cr2s.
pjz99 ( ) posted Tue, 10 March 2009 at 2:36 AM
Yeah, that seems to be the root problem here, at least with SP3 (no idea why EF let Sydney out the door with this problem).
My Freebies
EdW ( ) posted Wed, 11 March 2009 at 1:09 PM
I did some heels for SP3 a long time ago.... I called them "porn shoes".,, they are close to 5" heels
I'm at work so I can't post any pics of them. I didn't have a really bad time getting them to work. One thing I found is that you need to make sure all of the IK statements are deleted from the cr2 and that IK is actually off.
Ed
pjz99 ( ) posted Wed, 11 March 2009 at 1:18 PM
Yeah I checked that also (removed IK from the rig), didn't help with these.  They just do not behave the same in Poser as they do in DAZ|Studio.
My Freebies
EdW ( ) posted Wed, 11 March 2009 at 11:33 PM
Here's a couple of pics of heels I've done for Steph3. I also did a pair of sandals and running shoes. I don't remember having problems making conformers out of any of them.
I'll load the heels and take a look with the joint editor and see if I did anything out of the ordinary.
EdW ( ) posted Wed, 11 March 2009 at 11:35 PM
Here's another set of boots with heels
EdW ( ) posted Thu, 12 March 2009 at 12:06 AM
Ok I went and looked at all of my heels, sandals and shoes I've done for Steph3 and all of them are symmetrical as far as the joint centers and falloff zones go. I did these a few years ago so maybe they did something to Steph3 that messed her up.
pjz99 ( ) posted Thu, 12 March 2009 at 12:10 AM · edited Thu, 12 March 2009 at 12:11 AM
What version of Poser was this?
edit - is the toe actually rigged separate from the foot there? I wouldn't think so for the platform shoe, how about the boot at the bottom?
My Freebies
  • 1
  • 2
