Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
The problem is even if you turn on the texture view, you will see the mesh anyway, so if you take a print screen you will end with the texture (lowresolution in the view) and the mesh.
If you dont have the money for Baker you can try to win one of the prizes from our contest... Inagoni is one of the donors for prizes:
Follow me at euQfiz Digital
Not all procedurals will convert to texture maps perfectly since they're mathematically based - there is a reason that texture painting is worth while ;-) . I haven't tried Baker so I can't tell you if that solution is a better option than Carrara's native export.
If you take time to name the shading domains, those texture names should export automatically - at least they do on my rig.
The naming issue is really (believe it or not) a good thing for yourself or other users of the model once opened in .obj format. If the texture names are all the same, except for a number, tracking down and changing a texture can be a huge pain for the user. On a couple of assignments where I needed to use purchased models, I could have killed the author because the textures we only numbers so tracking them down and modifying them was a time killer.
So, if you're going to be selling your creations, the easier you can make it on your customers will pay of in continued sales. ;-)
"a universal way to turn procedural textures into texture maps is to apply the procedural texture to a flat surface, and make a rendering of the surface. The rendered texture can then be applied as a map on different objects.... another reason to convert procedural textures into bitmaps is to move textured models between different programs." from "Digital Lighting and Rendering" y Jeremy Birn, p. 327.
If you have many procedural textures to deal with, this may not be practical. Still, no one mentioned it and it seems like a good thing to know.
(see images below)
