Tue, Nov 19, 8:51 AM CST
Subject: Making a texture
RedPhantom ( ) posted Fri, 03 April 2009 at 3:12 PM · edited Tue, 19 November 2024 at 8:42 AM
Site Admin Online Now!
I have a picture that I'd like to use as a tatoo for Vicky's arm however it's not as simple as pasting it over a texture in psp since the top of the arm is split. How do you do this?
ice-boy ( ) posted Fri, 03 April 2009 at 3:15 PM
very hard. very hard.
you will need a software that will do painting in 3d to paste this tatoo on her arm .
Victoria_Lee ( ) posted Fri, 03 April 2009 at 3:47 PM
Quote - very hard. very hard.
Not always hard.  If you have a good working knowledge of your paint program and are comfortable working in layers the tattoo can be placed to span the seam.
Hugz from Phoenix, USA
Victoria
ice-boy ( ) posted Fri, 03 April 2009 at 3:56 PM
true. but IMO very hard.
RedPhantom ( ) posted Fri, 03 April 2009 at 4:27 PM
what kind of software does that?
hborre ( ) posted Fri, 03 April 2009 at 6:13 PM
Online Now!
DecalMaster is the only known software where you can apply a tattoo or decal over texture seams.  Used to be sold here, now it can be found over at DAZ3D.
markschum ( ) posted Fri, 03 April 2009 at 6:25 PM
two layers each with a copy of the tatoo, and use sultans seam guide rather than the Daz template. Position one on one side of the seam , and the other on the other side of the seam .  Its a bit tricky but doable.
dphoadley ( ) posted Sat, 04 April 2009 at 4:03 PM
Quote - I have a picture that I'd like to use as a tatoo for Vicky's arm however it's not as simple as pasting it over a texture in psp since the top of the arm is split. How do you do this?
1st get Snow Sultan's color coded seam guide, and load into Photoshop.
2nd Split your tattoo image into two half layers, and start to juxtapose each half on opposite sides of the arm of the seam guide, using the color codes to line them up.
DPH
Miss Nancy ( ) posted Sat, 04 April 2009 at 5:46 PM
if it's v1/v2, with front/back texmap sections, then apply the same small tattoo tex twice (over front and back of seam) as a colour math/multiply node using UV offset/scale.  as they said, it won't be easy.
RedPhantom ( ) posted Sat, 04 April 2009 at 9:26 PM
its v3. Why do I have to always pick the hard projects to be the ones I've just got to do?
Thanks for the suggestions
