It looks like you have a couple versions of Python installed on your machine with the default version being the the 2.5 Version you have installed on your C: drive. Normally this wouldn't be a problem. but it appears that the 2.5 version of Python you installed on your C: drive is setting some Windows registry values that point to the wrong place. What I would recommend is to
upgrade (free) to SkinVue6.3 at Cornucopia 3D - there is a fix in SkinVue6.3 that solves this problem by forcing the import of wxPython to use VuePython paths as the first search path versus anything you might have in your registry.
Hello.I have a problem.I install VueSkin6.1 to root folder of Vue Infinite and copy Skinvue6_1_Dazplugin and then i try to run python script SkinVue6PC.py. When i clikc this script it's nothing hapend.When i open Python Console i see that:
Python 2.4.2 (#67, Feb 6 2007, 12:05:31) [MSC v.1400 32 bit (Intel)] on win32
Can you help what i should do???
