Wed, Dec 25, 7:47 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Dec 23 6:26 am)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Cloths for Victoria.
blueblott ( ) posted Fri, 01 May 2009 at 6:34 AM · edited Thu, 01 August 2024 at 5:49 PM
Hi,
Is there any way to import Victoria 4.2 into Blender 2.48a with cloths.?..
The mesh model imports just fine, but without cloths.
If thats not possible how do i go about some cloths for her?
I have not seen any tutorials on cloths for Blender as yet.
I want to do the same for "Apollo Maximus"
Thanks for any help.
Regards
Blueblott.
lisarichie ( ) posted Fri, 01 May 2009 at 7:58 AM
:biggrin:You have come to the right place.
Import V4 into Blender then import each clothing mesh individually for existing clothing.
Alternatively you can export a clothed model from D|S quite easily by clothing V4 and exporting the visible nodes as an .obj file.
If you choose to use the second method I recommend turning off any V4 nodes that are completely covered by the clothes to reduce the poly count of the exported object.
One difficulty you will incur on importing D|S and Poser figures into Blender is the 16 material limit per object mesh in Blender. You can circumvent this by importing the mesh using the import by materials option. This breaks the mesh into separate objects according to material group. Then you can join the separate groups according to UV map and consolidate the materials according to UV map also. It's a hassle but only has to be done once if you re-rig for Blender and save the resulting file.
My tutorial linked to in the resource sticky in this forum covers the basics of clothing creation in Blender for use in Poser and D|S.
It's not a "How to do everything clothing related tutorial". The focus is on introducing the Blender tools and work flow through creating a simple t-shirt. The techniques used are much the same for any clothing item.
Though it is a basic tutorial the information should provide a good basis that you can further refine to your particular projects.
If you pursue this and have any questions feel free to PM me.
blueblott ( ) posted Fri, 01 May 2009 at 8:44 PM
**Big thankyou Lisarichie,
That is rearly good news one thing i noticed when i imported V4 it needed smoothing which i tried to do in Blender without much luck.
It was getting a bit late perhaps my concentration was needing a rest lol !
Thanks for the tutorial and all your help.
Regards
Blublott
lisarichie ( ) posted Fri, 01 May 2009 at 9:41 PM
To smooth the mesh select it and click set smooth in the links and materials tab.
blueblott ( ) posted Fri, 01 May 2009 at 9:50 PM
**Thanks for that
I am sure thats what i did last night but may be not!!
blueblott ( ) posted Sun, 03 May 2009 at 5:21 AM
**Hi Lisarichie,
Perhaps you can help me a little more if you can.
I followed the steps you mentioned, and yes Victoria is nice and smooth,and imports with cloths as you outlined in the first part of your reply but as you can see from the attached image i seem to be getting mixed results.
The eyes as you notice ,one is white the other has got the v4 cloths texture purple applied to it?
Just dont seem to be able to get the eyes imported and eye lashes are just black areas.
I used a three point lighting setup.
Also i suppose i shall have to re-rigg her in order to animate?
Thanks for helping me.
Regards
Blueblott
lisarichie ( ) posted Sun, 03 May 2009 at 8:11 AM · edited Sun, 03 May 2009 at 8:14 AM
The eyes are easy enough to fix.
Go into the materials tab, in the texture slot replace the map with the correct one.
Blender may have dropped the some materials so you may have to create new materials to make this work. Remember that Blender has a 16 material limit per object so if you import an object with more than 16 material zones something is going to be clipped.
You have to manually adjust the alpha for any transmapped areas like the eyelashes.
Yes, you will have to rig for animation in Blender. I would use the Collada importer to bring the V4 armature into Blender to simplify the process.:biggrin:
The collada importer script available at the following link works but you will have to do a little tweaking before binding the mesh to the skeleton.
teraapi.com/collada4blender/index.htm
Here's a link to some rigging info that will get good results. [
kokcito.tk/tut/rig1.html](http://kokcito.tk/tut/rig1.html)
There is more rigging info on BlenderGroupie
blendergroupie.blip.tv/#729604
If you haven't rigged in Blender before watching the ManCandy vids will be a big help.
blueblott ( ) posted Sun, 03 May 2009 at 6:56 PM
**Many thanks Lisa,
have now armed myself with the tutorials you mentioned and hope to" lift my game" from here on ! lol.
Again thanks for helping me.
Blueblott.
