Sun, Dec 15, 7:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 14 2:19 am)
Subject: Antonia - Opinions?
Fisty ( ) posted Wed, 13 May 2009 at 12:15 AM
That looks very good
SaintFox ( ) posted Wed, 13 May 2009 at 12:17 AM
by the way: What to do with those eyes? As you may see they are almost black (no, I did not use the shader here as I was unsure and the diffuse channel of the cornea already holds a material system).
I'm not always right, but my mistakes are more interesting!
And I am not strange, I am Limited Edition!
Are you ready for Antonia? Get her textures here:
The Home Of The Living Dolls
bagginsbill ( ) posted Wed, 13 May 2009 at 12:20 AM · edited Wed, 13 May 2009 at 12:21 AM
SaintFox - would you care to let me have a copy of your texture files as is right now? I won't do anything with them - just want to try a couple renders myself to see if we're seeing the same things. I don't mind if there are seams - and I won't send it to anybody.
odf ( ) posted Wed, 13 May 2009 at 12:20 AM
That last one looks good, except that the small spot seems to miss the face.
SaintFox ( ) posted Wed, 13 May 2009 at 12:22 AM
Of course you can have them! I will upload them and drop you a line. As said: I want to make them available to all developers when they are ready and everybody is very welcome to create his own sets from them. As I am of the opinion that there is no "only saving truth" in 3d I think it can be very exciting to see what different shader systems, light and so on do with it!
Allow about 15 minutes to set everything up for download please!
odf ( ) posted Wed, 13 May 2009 at 12:26 AM · edited Wed, 13 May 2009 at 12:27 AM
As for the eyes: the shaders supplied with the preview package should do the right thing. They are from BB's latest available VSS version like the rest of Antonia's shaders. Just replace the texture maps and maybe adjust the intensities in the "Diffuse" nodes (not in the main nodes) until the brightness looks right. I'm at work right now, so I can't check the shaders or give more detailed instructions. Obviously, the cornea needs to be transparent and untextured no matter what else you do (unless you want to simulate contact lenses).
bagginsbill ( ) posted Wed, 13 May 2009 at 12:34 AM · edited Wed, 13 May 2009 at 12:34 AM
Here's how Antonia renders right now with an 83% white point light and a 10% white IBL (no image).
SaintFox ( ) posted Wed, 13 May 2009 at 12:37 AM
*LOL* about the small spot - I made this willingly and nudged the light source a bit to have a more intimate effect ;o) But, just to please you... :biggrin:
bagginsbill ( ) posted Wed, 13 May 2009 at 1:04 AM
SaintFox textures + VSS. I like it a lot.
Rodma_Hu ( ) posted Wed, 13 May 2009 at 1:11 AM
VSS?
Wow.
bagginsbill ( ) posted Wed, 13 May 2009 at 1:12 AM
All I did there was replace the color maps with the new ones. I didn't make any changes to the shader settings. In particular, the Tint was still set up for the other texture.
Here I made the Tint much more neutral, so we can see the natural color of this texture set. It's very pale. That's a good thing - it means it is easy to adjust to be any color we want using VSS parameters.
But people who are not using VSS may find it a bit washed out. It's almost gray and very bright. Which is why, SaintFox, you were getting that over-exposed look. It's a very light color.
I really like it this way, though. I can do a lot with this.
SaintFox ( ) posted Wed, 13 May 2009 at 1:15 AM
I like it as well!! She definitly is far closer to a real human being now.
Now is there a way to keep the basic tones a bit more (as far as desired!) - I decided for this skin as I liked the mix of pale and tanned parts and the obvious blood circulation it would be interesting for me to see if the overall tan can be reduced.
At the moment I am trying out the "vss-shaded" set that came with Antonia with my texture and I think I stumbled over one single thing that could be enhaced, the lashes. Please give a moment to try it out and I will post some examples.
SaintFox ( ) posted Wed, 13 May 2009 at 1:16 AM
Upps - crosspost! That's exactly what I meant. WOWWWW!!!
bagginsbill ( ) posted Wed, 13 May 2009 at 1:25 AM
Glad you like it. This is an excellent color map.
Meanwhile, I played with settings and made another variation - not what you intended but it's really cool how flexible this texture is.
SaintFox ( ) posted Wed, 13 May 2009 at 1:27 AM
Very mediterrenean! I see that my intention on choosing a pale(r) person was right as it seems to offer lots of options!
A_ ( ) posted Wed, 13 May 2009 at 1:29 AM
that's really interesting.
bagginsbill ( ) posted Wed, 13 May 2009 at 1:32 AM
You have no idea. This texture is so easy to work with it's sick. You did exactly the color I keep telling people to work towards. If you make the diffuse color map the same color as dead, bloodless skin, then I can work the blood and pigment in any way I want.
SaintFox ( ) posted Wed, 13 May 2009 at 1:37 AM
You can't imagine how much fun this is to watch - it's the perfect "bonbon" to me after dealing with the hands and feet for two days 😉
bagginsbill ( ) posted Wed, 13 May 2009 at 1:39 AM
I added a bit of Clouds to produce some variation in skin color across the body. Adds to the realism a bit.
Just for fun, I tinted the iris to blue.
SaintFox ( ) posted Wed, 13 May 2009 at 1:49 AM
Goes together well with all those veins and so called imperfections in the skin!
And here is my result with the lashes.
This is what he have with the Antonia set so far (settings and rendered result - don't think too much over the eye bump - this is the bump that comes with Antonia and so it doesn't match the cornea's texture).
You can see that the lashes are pretty thick and short.
SaintFox ( ) posted Wed, 13 May 2009 at 1:50 AM
SaintFox ( ) posted Wed, 13 May 2009 at 1:52 AM
I am sorry, I am not able to post the screenshot - the system is telling me something about filesize limit...
odf ( ) posted Wed, 13 May 2009 at 1:53 AM
Hey, those look amazing. I'm very excited about this texture.
SaintFox: Oh! I understand now what you tried to do with the spot. I guess with the bright background the intimate effect didn't quite come through for me.
SaintFox ( ) posted Wed, 13 May 2009 at 1:54 AM
That's what you end up with when you want to show it all: Cosy atmosphere and all shadows :laugh:
odf ( ) posted Wed, 13 May 2009 at 1:55 AM
File size limit: I think it's something around 250k for this forum. I usually post PNGs, but when they get too large, I switch to JPEGs.
SaintFox ( ) posted Wed, 13 May 2009 at 1:57 AM
here we go: The default settings
bagginsbill ( ) posted Wed, 13 May 2009 at 1:58 AM
200K. I usually save renders JPEG 90% and they fit.
bagginsbill ( ) posted Wed, 13 May 2009 at 2:00 AM
You might want to take those painted eyebrows off and use a transmap on the eyebrow piece. It will make the hairs stand out better, and people can make them any color they want.
I really like this texture set. Thanks for letting me play. I have to go sleep now - have to work tomorrow. Ugh. It's 3 AM.
SaintFox ( ) posted Wed, 13 May 2009 at 2:04 AM
...amd here is what I use for most of my characters. As you see the diffuse color is not black. If I want it to look black I use a kind of very dark gray. For Antonia I use a dark brown, a color that looks pretty natural if you are not going for a mascara look or want it to go together with an asian or african/afro-american character.
I confess that I am unsure if it makes any sense to plug the texture into the transparency edge channel as well (as more as I set it to 0.0) - I think this part of the settings is a fossil or something like that that I carry around with me.
But anyway: The trick is to choose a paler version of the color you use in the diffuse channel for the specular color.
I am sure that some of you are able to come up with something more clever (or an advanced version) but I thought that this may be worth a look.
bagginsbill ( ) posted Wed, 13 May 2009 at 2:10 AM · edited Wed, 13 May 2009 at 2:11 AM
Your specular is doing nothing on the lashes - you have the Specular_Value = 0. That turns it off.
When there is a pair of channels, XYZ_Color, XYZ_Value, they are multiplied together. Set the color and then you can adjust the brightness using the XYZ_Value parameter. But, when XYZ_Value = 0, the product (color times value) is 0 - meaning do nothing.
So ... good trick! Hehehe.
SaintFox ( ) posted Wed, 13 May 2009 at 2:13 AM
I will hand out the whole texture to the people in the developer forums as psd-files. The brows are already on a seperate layer (and will be for the bump as well) and can be left off if desired - but they are not painted... these are the brows of the "skin model" not color shifted or such so that they match the skin perfectly.
What I plan is pretty much what we made for V4 as a comercial product - and so I hope that it is okay that we only give it away to the developers. But if someone creates free jpg's from the set it's totally okay with me and Leo. Just the uncompressed base should be limited to those that create for Antonia, regardless if they use it for their own render fun or for freebies or comercial products.
odf ( ) posted Wed, 13 May 2009 at 2:22 AM
Quote - I will hand out the whole texture to the people in the developer forums as psd-files. The brows are already on a seperate layer (and will be for the bump as well) and can be left off if desired - but they are not painted... these are the brows of the "skin model" not color shifted or such so that they match the skin perfectly.
That's very generous of you. I'm looking forward to playing with the texture set.
(Hopefully I can open the PSDs in Gimp.)
SaintFox ( ) posted Wed, 13 May 2009 at 2:33 AM
Yep - good trick. LOL I KNEW that you would find out at least what does NOT cause the finer effect. My "problem" is that I mostly know what to do (at least I can ask, right?!) but often not know why something works. So this is the perfect occasion to discuss and ask.
This is the result of some try and failure when trying to get rid of hard, brittle lashes or this strange "aura" you often get where the lash geometry should be completely transparent. I've loaded several characters I've made and found that I adopted the settings from an asian character I made long ago that has almost black lashes and a specular color of a very dark blue. But here I used a slight specularity.
If you have some more patience I render some tests with altered values for "Transparency edge"...
SaintFox ( ) posted Wed, 13 May 2009 at 3:24 AM
Okay - forget about it. I am really feeling silly now!!!
I can use whatever settings I want, I am not able to reproduce the look I had so often and wanted to avoid with my oh-so-clever settings. Do you know what gives you even more headaches as an error? Not being able to reproduce it. If i ever run into the problem with the "aura" or the brittle lashes again I will make a screenshot and ask again.
I even took character by others I have that show these problems on their promotional images and I am not able to create the effect here with Poser.
...but, much more important: Greetings from my "partner in crime", Leo (Digital-Lion)! He asks for understanding and a bit patience regarding the seams. At the moment he works full time, 5 days the week (while he used to work part-time a while ago) and so it may take him a while to fix the seams and maybe add a tattoo.
odf ( ) posted Wed, 13 May 2009 at 3:48 AM · edited Wed, 13 May 2009 at 3:49 AM
I think the aura you speak of is probably the effect you see when you leave the specularity on without a mask. I don't know exactly how the three transparency settings interact, but setting them up like in your first picture usually works for me for lashes and brows.
I don't know about brittle lashes. That could be caused by all kinds of things, I imagine.
SaintFox ( ) posted Wed, 13 May 2009 at 3:54 AM
You can't imagine how eased I am that you stopped laughing at me and are able to write again :biggrin: I feel like a complete fool and I am really glad to go back to things I know a thing or two about!
odf ( ) posted Wed, 13 May 2009 at 4:06 AM
I didn't laugh at you.
Just near you.
SaintFox ( ) posted Wed, 13 May 2009 at 4:29 AM
I am off for some sleep in half an hour (it's already late morning) and will check back in the evening.
ice-boy ( ) posted Wed, 13 May 2009 at 4:56 AM
Quote - ...amd here is what I use for most of my characters. As you see the diffuse color is not black. If I want it to look black I use a kind of very dark gray. For Antonia I use a dark brown, a color that looks pretty natural if you are not going for a mascara look or want it to go together with an asian or african/afro-american character.
very good lashes IMO. the problem i see in other lashes is that there are to many. if we look at some ipcs from real people we can see that there are not 100 lashes. but under 50.
looks very realistic
artistheat ( ) posted Wed, 13 May 2009 at 5:33 AM
This is taking a turn for the Best...Like what I see a lot...Sure Fox I'll be happy to use what ever you throw my way:)
odf ( ) posted Wed, 13 May 2009 at 10:01 AM
Progress report from the JCM front...
I think I'm starting to get the hang of this. This is still not perfect, but at least the bulges are gone.
odf ( ) posted Wed, 13 May 2009 at 10:06 AM · edited Wed, 13 May 2009 at 10:14 AM
The same pose from the back.
I sculpted the combined kick/spread pose that gave me trouble and split the difference between the two channels. That actually worked much better than I had expected. The workflow is not ideal, but at least - thanks to DAZ - there finally is one for this kind of thing.
I'll try not to spend years on perfecting the JCMs, but I have to admit I am excited about the possibilities. Finally we can make a figure that bends somewhat realistically.
I'll do the knees next, then have a look at the hand and feet. When I'm done with the first round, I might upload a new preview version. It's been a month...
shante ( ) posted Wed, 13 May 2009 at 11:24 AM
Quote - Well the rigg is getting there.  Have alot more added now. Hands and feet next (fingers and all that UGH!)   Then have to run her through a gambit of poses and fine tune, but looking good so far.
For some darn reason this thread seemed to have dropped my subscription request and I forgot to come back.
Glad I remembered since a lot more has been done since I was last here.
looks great too but I have one question and I hope I am not being to damn picky.
In V3 and V4 I notice that the the bony bulge at the top of the foot seems to be too high on the foot when the foot is en point. V2 foot/shin rigging seemed to handle it much gentler and that bony hump actually seems to reside lower on the foot. In V3/V4 and this figure I am noticing too, that bony hump at the top of the foot is too high up on the foot making the pointing foot pose look strange. Any way this can be fixed.
having a foot fetish I seem to notice strange things!  :)
shante ( ) posted Wed, 13 May 2009 at 11:29 AM
Quote - Progress report from the JCM front...
This is beautiful. The groin areas on ALL the current figures (From DAZ anyway) fall WAAAAAAY short of a decently conceived and constructed groin area. On my old V2 there was a Groin width morph I apply which helps a bit but it is minimal. I am glad someone (YOU!) has thought a bit further in advance of the construct of this part of the anatomy. Apparently DAZ doesn't want to promote ANY possibility of their figures being used for erotic imagery so they avoid any hint of concentrated effort in doing this right. Thus all their figures, even when not used for erotica look fake when doing kicks or extreme fight or dance stretches.
Thanks!
Since on the subject of erotica is there going to also be added a morph for more realistic genitalia?
You know I had to ask!!!???.....;)
shante ( ) posted Wed, 13 May 2009 at 12:44 PM
Quote - Even with some additional pounds she looks quite nice.
Looks good. How was this done? Your morphs or morphs included in the Antonia WIP Set?
Jules53757 ( ) posted Wed, 13 May 2009 at 2:00 PM
My morphs and they will be available to the public when Antonia has her coming out.
Ulli
WandW ( ) posted Wed, 13 May 2009 at 3:15 PM
Quote - My morphs and they will be available to the public when Antonia has her coming out.
After seeing her naked here for months, I never really thought of her as a debutante before. 😊
JOELGLAINE ( ) posted Wed, 13 May 2009 at 4:40 PM
We have to hammer out the basic figure before putting clothes on her. If she can't even sit down realistically , why put pants on her? :laugh:  She will be as good as she can be made.
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
SaintFox ( ) posted Wed, 13 May 2009 at 5:46 PM
About those jcm - way cool! Especially when remembering what happens to the thighs of V3 and to her behind when you bent her this way I think that this is fantastic work!
And about clothes: so far we can use dynamic clothes (even those made for other figures) if desired 😉
JOELGLAINE ( ) posted Wed, 13 May 2009 at 6:15 PM
I like conforming better.  When you use multiple figures in a scene, dynamics break down and crash Poser.  Conforming works easier and doesn't crash Poser to the desktop. Each to their own. I never do single figure pics. 😉
