This product has had a lot of good reviews - Morphing Clothes
It apparently adds any morphs the figure has to the clothes, so in theory you could clothe your curvier figures this was. I don't have the programme, but I have read a lot of good things about it.
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
I would suggest Morphing Clothes too. Your problem is that the clothes don't have the same morphs as the figures. Morphing Clothes or the Wardrobe Wizard will create the needed morphs for you. This isn't always perfect (you would have to use a modeling software and your own modeling skills for that), but works well in most cases.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Keep in mind that there is a misconception on how clothing will fit for the final render. Many believe a clothed model should have perfect form fitting throughout, front and back. But those areas facing away from the camera are never seen in the final render and it doesn't matter if there is a poke-through present. The convention for creating a scene should be populate your stage, pose your actors, then dress them in their clothing. The final pose will reveal how much further work is needed to properly conform the clothes. Many individuals install the model, dress them in their default position, then pose afterwards.
I'll add my voice to recommending Morphing Clothes, as well. I haven't used Wardrobe Wizard, though, so I can't speak on that.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Morphing Clothes may well be the best thing since sliced bread, but don't overlook that the original poster has tried using clothes with the correct morphs in them:
Quote - If for example i put on the cloths and then morph v4, then use the same morph for the clothes = fail.
Thanks to everyone for the kind help. I did get myself the program "morphing clothes" on your advice. I played with it a little bit, but the results were the same. It seemed to want to fit a little better, but still had skin hanging out all over. I'll try it again tonight. But for now, here's some examples of using character morphs on cloths as well as the character itself.
This is standard V4 with Luscious Curves Morph #6
The First Set Of Pics Is:
V4 With Mat > V4 With Clothes On > V4 With Morphs > V4 With Clothes Morphed Same As V4
This set is using "Hot Strike"
www.imagebam.com/image/a8350635755183
www.imagebam.com/image/ee02ff35755184
www.imagebam.com/image/3d56bf35755185
www.imagebam.com/image/3d56bf35755449
Second Set Is The Same Order.
Jasmina's Mellisa Dress Set Clothes Labeled As " Morph Injected "
www.imagebam.com/image/a8350635756010
www.imagebam.com/image/eb60f535756013
www.imagebam.com/image/6e368435756017
www.imagebam.com/image/17fdd535756102
I can see that in the cloth's morph dials, even though injected with the same morph as V4, the morph dials aren't changed.
What I would try is injecting the morph in the character first, THEN putting the clothes on. That right there might even fix it, as some clothes come in superconforming. Also, don't negate the use of the Magnetize poses in your main V4 folder ;)
into a fruit salad.
Ok, I'm going to see if I can follow your steps, and get to where you are, ok? Hang on :)
into a fruit salad.
Ok, I loaded a character using all DAZ-created morphs, this is just from Morphs ++.
into a fruit salad.
into a fruit salad.
into a fruit salad.
into a fruit salad.
You're welcome :)
A Note: Not all clothing items will work perfectly with all morphs. There are some morphs that, for some reason, some clothing makers leave out. I don't know why, since I couldn't model my way out of an open gate, but it's the truth. And, sometimes, the morphs don't work properly. A good thing to do in cases like this is just seriously fiddle with morphs, in both the positive and negative spectrum, scale values, and (I know, scary thought!!) Magnets.
into a fruit salad.
Even with clothes that have the morphs built in, I often find I have to do a bit of adjustment with the morph dials (or the morph brush, or even ZBrush if it's a real tricky one) Don't get discouraged though, also remember clothes don't have to fit where the camera can't see 'em :)
Doesn't matter how much pokethrough there is behind a figure for e.g so long as the camera only sees the front
My Freebies
Buy stuff on RedBubble
I have had a great start to poser. I've went from renders that looked like crayon art, to some pretty decent stuff. I got lights down, I got the settings down, I got the envirsphere working, I got into shading with the vss, there's many things I can do at this point. Yea me! lol
But what I cannot do is get any cloths to fit. Period. I use v4, but never the default morphs. I make my characters heavy, curvy, so I put the clothes on and they don't fit. I have searched and searched for a solution. I bought "Conforming Clothes" failed with it after spending hours and hours. I tried magnents, I bought clothes that were morph injected, I can't get anything to work. I grow tired and I grow frustrated. Doing a google search returns infinity results. But where I ask, is the one difinitive, step by step guy to making conforming clothes fit in Poser 7?
There's tuts for making conforming cloths, or fitting conf. clothes in poser 4. I'm sorry to be so frustrated. The time and money I spent on my own stupidy is killing me. So I just have to ask for help.
If for example i put on the cloths and then morph v4, then use the same morph for the clothes = fail. Then I'll break out magnents, and if I pull and item over the stomach, the zone moves her hair. I didn't attach the magnent to the hair, I did it to the clothes!!? Little things like this are always happening to me. I suck. I've tried a hundred ways, all yeild fail.
