Sat, Jan 11, 6:01 AM CST
Subject: Conforming Clothing Tut For Newbs?
Chonan ( ) posted Wed, 13 May 2009 at 12:28 AM · edited Sat, 11 January 2025 at 5:55 AM
I have had a great start to poser.  I've went from renders that looked like crayon art, to some pretty decent stuff.  I got lights down, I got the settings down, I got the envirsphere working, I got into shading with the vss, there's many things I can do at this point. Yea me!  lol
But what I cannot do is get any cloths to fit.  Period.   I use v4, but never the default morphs.  I make my characters heavy, curvy, so I put the clothes on and they don't fit.  I have searched and searched for a solution.  I bought "Conforming Clothes" failed with it after spending hours and hours.  I tried magnents, I bought clothes that were morph injected, I can't get anything to work.  I grow tired and I grow frustrated.  Doing a google search returns infinity results.  But where I ask, is the one difinitive, step by step guy to making conforming clothes fit in Poser 7?
There's tuts for making conforming cloths, or fitting conf. clothes in poser 4.  I'm sorry to be so frustrated.  The time and money I spent on my own stupidy is killing me.  So I just have to ask for help.
If for example i put on the cloths and then morph v4, then use the same morph for the clothes = fail.   Then I'll break out magnents, and if I pull and item over the stomach, the zone moves her hair.  I didn't attach the magnent to the hair, I did it to the clothes!!?  Little things like this are always happening to me.  I suck.  I've tried a hundred ways, all yeild fail.
-BrandyE- ( ) posted Wed, 13 May 2009 at 12:35 AM
your problem is that most clothing makers dont support the very curvy, heavy morphs :(
Brandy
Anniebel ( ) posted Wed, 13 May 2009 at 12:58 AM
This product has had a lot of good reviews - Morphing Clothes
It apparently adds any morphs the figure has to the clothes, so in theory you could clothe your curvier figures this was. I don't have the programme, but I have read a lot of good things about it.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
hborre ( ) posted Wed, 13 May 2009 at 5:40 AM
The program works very well.  I have used it for various models haven't had a misfit yet.
bantha ( ) posted Wed, 13 May 2009 at 7:49 AM
I would suggest Morphing Clothes too. Your problem is that the clothes don't have the same morphs as the figures. Morphing Clothes or the Wardrobe Wizard will create the needed morphs for you. This isn't always perfect (you would have to use a modeling software and your own modeling skills for that), but works well in most cases.
-"Amazing Grace" Hopper
hborre ( ) posted Wed, 13 May 2009 at 9:30 AM
Keep in mind that there is a misconception on how clothing will fit for the final render.  Many believe a clothed model should have perfect form fitting throughout, front and back.  But those areas facing away from the camera are never seen in the final render and it doesn't matter if there is a poke-through present.  The convention for creating a scene should be populate your stage, pose your actors, then dress them in their clothing.  The final pose will reveal how much further work is needed to properly conform the clothes.  Many individuals install the model, dress them in their default position, then pose afterwards.
JenX ( ) posted Wed, 13 May 2009 at 1:37 PM
I'll add my voice to recommending Morphing Clothes, as well.  I haven't used Wardrobe Wizard, though, so I can't speak on that.
DarkEdge ( ) posted Wed, 13 May 2009 at 7:10 PM
Yup, MorphingClothes is what you want.
You don't need to be a rocket scientist like with some of the other apps.
EnglishBob ( ) posted Thu, 14 May 2009 at 4:39 AM
Morphing Clothes may well be the best thing since sliced bread, but don't overlook that the original poster has tried using clothes with the correct morphs in them:
Quote - If for example i put on the cloths and then morph v4, then use the same morph for the clothes = fail.
  • which shouldn't be happening. Chonan, could you give one specific example of a figure/clothing combination that doesn't work as it should? It sounds as if you're allowing yourself to become flustered by your failures, which is a good recipe for finger trouble. ;) As I said, if you're using clothing with the correct morphs in it, it should work. Let's go through it step by step and find out why it doesn't.
Chonan ( ) posted Thu, 14 May 2009 at 11:16 AM
Thanks to everyone for the kind help.  I did get myself the program "morphing clothes" on your advice.  I played with it a little bit, but the results were the same.  It seemed to want to fit a little better, but still had skin hanging out all over.   I'll try it again tonight.  But for now, here's some examples of using character morphs on cloths as well as the character itself.
This is standard V4 with Luscious Curves Morph #6
The First Set Of Pics Is:
V4 With Mat > V4 With Clothes On > V4 With Morphs > V4 With Clothes Morphed Same As V4
This set is using "Hot Strike"
www.imagebam.com/image/a8350635755183
www.imagebam.com/image/ee02ff35755184
www.imagebam.com/image/3d56bf35755185
www.imagebam.com/image/3d56bf35755449
Second Set Is The Same Order.
Jasmina's Mellisa Dress Set Clothes Labeled As " Morph Injected "
www.imagebam.com/image/a8350635756010
www.imagebam.com/image/eb60f535756013
www.imagebam.com/image/6e368435756017
www.imagebam.com/image/17fdd535756102
I can see that in the cloth's morph dials, even though injected with the same morph as V4, the morph dials aren't changed.
JenX ( ) posted Thu, 14 May 2009 at 11:23 AM
What I would try is injecting the morph in the character first, THEN putting the clothes on.  That right there might even fix it, as some clothes come in superconforming.  Also, don't negate the use of the Magnetize poses in your main V4 folder ;)
Chonan ( ) posted Thu, 14 May 2009 at 11:36 AM
I just tried it in that order.   V4 Morphed, Added Clothes, Then Morphed The Clothes.  Same result, not even close to fitting.
I cry a little inside with each new attempt and each failure.   ;)
JenX ( ) posted Thu, 14 May 2009 at 11:41 AM
Ok, I'm going to see if I can follow your steps, and get to where you are, ok?  Hang on :)
hborre ( ) posted Thu, 14 May 2009 at 12:27 PM
If you did use Morphing Clothes, select your morphed character, go to edit>copy, select the clothes and paste.  The morph values from your model will translate to the clothing.  Tweak as necessary.  It works, tried last night with a little something I was playing around with.
JenX ( ) posted Thu, 14 May 2009 at 1:06 PM
Ok, I think I know what you're getting at, and let me show you with renders :)
Ok, I loaded a character using all DAZ-created morphs, this is just from Morphs ++.
JenX ( ) posted Thu, 14 May 2009 at 1:07 PM
Now, since I don't have the exact outfits you're mentioning, I used one from one of the vendors.  Here's Jasmina's Wedding dress.  It....tries to conform.  It does.  This is before conforming the figure, btw.  It didn't get any better after hitting conform.
Chonan ( ) posted Thu, 14 May 2009 at 1:07 PM
Edge of my seat here!   Bless your heart for the help to all, and especially to JenX!
JenX ( ) posted Thu, 14 May 2009 at 1:09 PM
As you were saying, I had problem getting specific morphs to work while in the Body part of the figure.  HOWEVER, selecting the parts with poke-through, and utilizing the obvious bodymorphs (in this case, Voluptuous, and a couple breast morphs, including Breast Droop) I was able to fit the dress to her body.
JenX ( ) posted Thu, 14 May 2009 at 1:12 PM
These are the only dials I changed in the "Chest" area.
Chonan ( ) posted Thu, 14 May 2009 at 3:33 PM
Hmmmmmmmm.  This is encouraging.  I will do a new test.  You're the best for the renders.  Much appreciated!
JenX ( ) posted Thu, 14 May 2009 at 4:00 PM
You're welcome :)
A Note:  Not all clothing items will work perfectly with all morphs.  There are some morphs that, for some reason, some clothing makers leave out.  I don't know why, since I couldn't model my way out of an open gate, but it's the truth.  And, sometimes, the morphs don't work properly.  A good thing to do in cases like this is just seriously fiddle with morphs, in both the positive and negative spectrum, scale values, and (I know, scary thought!!) Magnets.
FrankT ( ) posted Thu, 14 May 2009 at 4:08 PM
Even with clothes that have the morphs built in, I often find I have to do a bit of adjustment with the morph dials (or the morph brush, or even ZBrush if it's a real tricky one) Don't get discouraged though, also remember clothes don't have to fit where the camera can't see 'em :)
Doesn't matter how much pokethrough there is behind a figure for e.g so long as the camera only sees the front
My Freebies
Buy stuff on RedBubble
