Thu, Dec 12, 8:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
Subject: Any advice on distorting transparencies, reflections for under water ?
MistyLaraCarrara ( ) posted Fri, 29 May 2009 at 11:53 AM · edited Wed, 04 December 2024 at 9:23 PM
If you be under the water looking up at the sky, especially for animations, surface ripples go by.
Or looking down, things look magnified under the water.
I'm working on a Mermaid panorama scene.  My efforts are looking too cartoonish.
Those dynamic hair roots are a bane to my efforts.  aahhhh
Thanks for letting me peeve!  lol
Fazzel ( ) posted Fri, 29 May 2009 at 1:30 PM
For water you should use the refract node, not transparency.  This will give you the effect you are
looking for.
MistyLaraCarrara ( ) posted Fri, 29 May 2009 at 2:46 PM
cool.  thanks
Daidalos ( ) posted Fri, 29 May 2009 at 2:47 PM · edited Fri, 29 May 2009 at 2:48 PM
Point a spotlight straight down at the water from the suns direction too. ;)
I have found that it helps if there's actually light coming from the light source in the scene.
"The Blood is the life!"
replicand ( ) posted Fri, 29 May 2009 at 3:17 PM
 Also, depending on the size of the water body you're looking to create, try displacing the surface with a wave function.
Water gets murky with distance, so you'll want some sort of environment shader to attenuate visibility.
MistyLaraCarrara ( ) posted Fri, 29 May 2009 at 3:40 PM
That's in the 3d nodes?
I'd like to animate a splash landing.
I setup the Orca to dip up and down.
Here's the W-I-P  if anyone is interested.
http://www.realmsandgalaxies.com/wings3d/ty2-3a.wmv
