Mon, Dec 23, 12:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: Small Breasts
vampchild ( ) posted Fri, 26 June 2009 at 9:24 AM · edited Sun, 01 December 2024 at 8:55 AM
Folks I need a little help. I want to make smaller boobs
on my characters mainly V4 and V3. I can make them
smaller but they seem not real enough using the dials
for each character. I think small breast women have always
been hot. Just don't like the balloons most characters
come with. Thanks for any help!
Beware-The Smoking Man Still Lives!
lesbentley ( ) posted Fri, 26 June 2009 at 9:43 AM
I thoroughly concur, tiny tits are tops!
hborre ( ) posted Fri, 26 June 2009 at 9:45 AM
Posematic has put out a series of breast morphs for just about all the models available.  In addition, most character morph packs do include breast poses for just about any situation (i.e., lying down, leaning to the one side, etc.)
ockham ( ) posted Fri, 26 June 2009 at 9:48 AM
Swimming against the tide, boys, swimming against the tide.
Using Poser to make small breasts is like buying a stretch limo
for its parallel parking abilities.
My python page
My ShareCG freebies
markschum ( ) posted Fri, 26 June 2009 at 10:31 AM
Get the Ultimate breast morphs in freestuff, apply to one character and every other breast will  look small :)
You may be able to go with negative values on the size morphs .
Jules53757 ( ) posted Fri, 26 June 2009 at 10:47 AM
Try negative values for BreastsSize etc, a little bit here and there.
Just an example I used for one of my chars:
Breastssize: -0.36
BreastsLarge: -0.2
BreastsCleavage: 0.79
CleavageWidth: -0,276
BreastsPerk: 0.28
AureolaOut: 1.15
AureolaPerk: 0.31
Nipples: 1
NipplesHeight: 0.2
NipplesDepth: 0.56
NipplesBig: 0.44
Try it, I love the result ;)
Ulli
vampchild ( ) posted Fri, 26 June 2009 at 11:14 AM
Thanks for the info. I'll try Jules setup and hope
it what I need. I'm going to search every 3D site
and if I find that special morph, I'll try to post the
link. I know theres a lot of folks out there who love
small breasts as I do. This is going to be my new
project.
skuts ( ) posted Fri, 26 June 2009 at 1:16 PM
Anything more than a mouthful is wasted. I've found that smaller breasts are much more sensitive than big bazongas.
"Facts are the enemy of truth."
grichter ( ) posted Fri, 26 June 2009 at 2:01 PM
Quote - Anything more than a mouthful is wasted. I've found that smaller breasts are much more sensitive than big bazongas.
Uh...I gave V4 some huge breasts and looked at the dial settings and wrote down all the numbers. Then I gave her some small breasts, the size that would have qualified her as president of the itty-bitty-titty-comittee. I wrote those dial numbers down too.
Gee, when I compare the two sets of numbers, the sensitivity of the dials in Poser where the same for  big bazongas vs itty bitty ones. They never changed.
Somebody want to tell me what I am doing wrong. :b_confused:
Gary
AnAardvark ( ) posted Fri, 26 June 2009 at 2:04 PM
One of the problems when dialing down breast size is that the various breast size dials don't always play nice with each other at negative values. In particular, the dial for silicone breasts (don't remember the actual name) does nasty things at negative values. Also, if you are using a FBM (especially an elite one) to make a character overall slender, sometimes it reacts badly with negative values of "breasts large".
pjz99 ( ) posted Fri, 26 June 2009 at 2:06 PM
One of my major dislikes about V4 is that the default breasts are a solid D, so getting them to look normal (not even small, just normal) is more work than it ought to be.  Although I guess like Ockham says, it's a waste of time to point this out.  I guess when DAZ gets around to doing a "Stephanie Petite" for the Gen 4 mesh it will be another morph of the base V4 rig again, which means you'll still be getting base models designed around a D cup, so texture distortion will pretty much be unavoidable when working with normal sized breasts.
My Freebies
Klebnor ( ) posted Fri, 26 June 2009 at 3:10 PM
After much practice, my sage advice:
Start with FBM, dial voluptuous down to between -4 and -6.  This affects the full body, but results in much more realism.  This is critical - starting any other way will yield unrealistic results.  If you don't like the overall shape, change glutes, thighs, arms, whatever - separately.
Now adjust breasts, dial 'size' and 'large' down until you like the overall size.
Fix the distortions (they will be there) as best you can with other adjustments - among the helpful are diameter, cleavage, straight out, perk and ariole out.  Natural can also be helpful - use it in the negative direction to fix the bottom shape.
This is the only way I have found to achieve small realism.
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
lesbentley ( ) posted Fri, 26 June 2009 at 3:34 PM · edited Fri, 26 June 2009 at 3:45 PM
file_433631.TXT
I don't have the V4 ++ pack, so all this talk about small breasts got me to dust off my magnets and have a go. What I came up with as a first attempt is admittedly not a great morph, but it's free, and perhaps will be useful to someone. I packaged the morph as a delta injection.
To attach the zip, I had to add a ".TXT" file extension. Drop the ".TXT" part when you save it to disk, so it becomes "SmallerBreastsV4.zip". Extract the zip to your Poser folder. The files should end up in:
Runtime/libraries/Pose/DAZ's Victoria 4/Morph Injections/3rd Party
And if you find a better free small breast morph, please let me know.
lesbentley ( ) posted Fri, 26 June 2009 at 3:38 PM · edited Fri, 26 June 2009 at 3:44 PM
And here is what the morph looks like.
P.S. the morph is a FBM, you will find a dial to adjust it in the Body.
Jules53757 ( ) posted Fri, 26 June 2009 at 5:02 PM
Just one little try, based on the one of Les but the boobies more to the inside. Sorry, its quick and dirty one so you have load the morph target in the old fashioned way via the properties Tab to the chest.
Ulli
Jules53757 ( ) posted Fri, 26 June 2009 at 5:41 PM
Just to show the difference, on the left there is my Lulu with the settings above, followed by my modfication of lesbentley's  morph and on the right the lesbentley original.
Ulli
Jules53757 ( ) posted Fri, 26 June 2009 at 5:43 PM
And here from a different angle:
Ulli
Jules53757 ( ) posted Fri, 26 June 2009 at 5:47 PM · edited Fri, 26 June 2009 at 5:51 PM
file_433642.txt
Sorry, forgot the file. Here it is and you have to delete the extension txt too.
Ulli
lesbentley ( ) posted Fri, 26 June 2009 at 6:37 PM
Yes, on my morphs the breasts needed to come together more, and I made a mess of the sternum and the bottom of the rib cage. Looks like you did a great job on Lulu's breasts.
Sa_raneth ( ) posted Fri, 26 June 2009 at 7:20 PM
somebo9dy mind tellin me how to save this as a zip file  cause all i can get it  to save  as  is  a txt file
 thanks
Nance ( ) posted Fri, 26 June 2009 at 9:07 PM
In the Save As dialog box, change the filename by deleting the '.txt' portion.
... or just change the filename extension after you've saved it.
Sa_raneth ( ) posted Fri, 26 June 2009 at 9:17 PM
thanks
operaguy ( ) posted Fri, 26 June 2009 at 10:11 PM
V4.2 morphs++ Muscle Morphs That's all I've needed. I have been making V cute-sized for years.
operaguy ( ) posted Fri, 26 June 2009 at 10:12 PM
Torso study
operaguy ( ) posted Fri, 26 June 2009 at 10:13 PM
It's all in the genes. Er.................jeans.
operaguy ( ) posted Fri, 26 June 2009 at 10:33 PM
i forgot to check the nudity box and now i can't edit. Sorry.
sirenia ( ) posted Sat, 27 June 2009 at 5:24 AM
I like 'em small too :-)
My experience so far is only with Aiko3. With this figure it 's possible to dial them even 'almost' completely away without messing the geometry up too much. And i 'm also using magnets a lot to change other bodyparts as well.
Maybe this is gonna be a bit overkill on the topic here, but honestly i can 't understand why a lot of women in real life want to enlarge their breasts via a boob job.
Society failed to tolerate me...
... and i have failed to tolerate society
pjz99 ( ) posted Sat, 27 June 2009 at 5:37 AM
For the same reasons people in the gallery here start with a D (default V4) and dial up to EEE.
My Freebies
LaurieA ( ) posted Sat, 27 June 2009 at 9:35 AM
Quote - I thoroughly concur, tiny tits are tops!
LOL...that's good to know, since most women are NOT built like Vicky...LOL.
momodot ( ) posted Sat, 27 June 2009 at 9:44 AM
I have used combinations of male and child morphs to get smaller breasts... these exist for both V4 and V3. Perhaps using a flat chest like that and morphing the breasts back out with magnets or morphs would work. Long ago IssacNewton I think made a "Ando" morph for Posette that was a "neutral base" to morph new waist and breasts out from again.
Jules, that Lulu is very nice. Realistic small breasts.
Dave-So ( ) posted Sat, 27 June 2009 at 3:45 PM · edited Sat, 27 June 2009 at 3:48 PM
one day I saw this really fabulous looking woman...she had a very curvacious body, fine shaped legs, real nice booty...then her boobs were pretty flat. It didn't look right at all. sorry to you real small breasted women, I've been looking at v2 and up for too long, plus all the fakers around town. :)
i feel the same way about real large breasts too. Too big doesn't look right.either...and after age sets in, and gravity takes over, and the major sag happens...they are darn scary with nipples down past the belly button ... yikes ... I can't take it anymore
anyway...check out this site for pictures of all different sizes of breasts...real ones. this would be a good reference for morphing and maybe for a developer to use in the next female model.
http://www.007b.com/breast_gallery.php
and... pictures and comparisons of the different cup sizes
http://www.afraidtoask.com/?page_id=119
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
fivecat ( ) posted Sat, 27 June 2009 at 4:14 PM
I have a freebie flatten chest morph for V4. It injects as completely flat, but you can adjust the dial to  use it in varying strengths in combination with other breast morphs to get a decent looking small breast.
Go to my site  http://www.byfivecat.com/ and go to 3d downloads.
momodot ( ) posted Sat, 27 June 2009 at 4:29 PM
Thank you, fivecat :)
EClark1894 ( ) posted Mon, 29 June 2009 at 2:59 AM · edited Mon, 29 June 2009 at 3:06 AM
Quote - > Quote - I thoroughly concur, tiny tits are tops!
They aren't?!!!
Then they can't  be 'real' women, can they? And I don't date boys! (Not that there's anything wrong with that... if you're a girl!)    8^D j/k
I should clarify something.  I was just joking, but the thing is, almost every woman in my family has breasts that are as big as or bigger than V4's!
Ironically, the woman I'm most attracted to in my life is much smaller. But don't get me wrong.  There's nothing wrong with a nice pair of D cups.
vampchild ( ) posted Mon, 29 June 2009 at 9:11 AM
Thank you Dave-so for the sites. There were good refence
pics there, Also thanks Fivecat for the Morph.
