Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Swimming against the tide, boys, swimming against the tide.
Using Poser to make small breasts is like buying a stretch limo
for its parallel parking abilities.
My python page
My ShareCG freebies
Try negative values for BreastsSize etc, a little bit here and there.
Just an example I used for one of my chars:
Breastssize: -0.36
BreastsLarge: -0.2
BreastsCleavage: 0.79
CleavageWidth: -0,276
BreastsPerk: 0.28
AureolaOut: 1.15
AureolaPerk: 0.31
Nipples: 1
NipplesHeight: 0.2
NipplesDepth: 0.56
NipplesBig: 0.44
Try it, I love the result ;)
Ulli
Thanks for the info. I'll try Jules setup and hope
it what I need. I'm going to search every 3D site
and if I find that special morph, I'll try to post the
link. I know theres a lot of folks out there who love
small breasts as I do. This is going to be my new
project.
Beware-The Smoking Man Still Lives!
Quote - Anything more than a mouthful is wasted. I've found that smaller breasts are much more sensitive than big bazongas.
Uh...I gave V4 some huge breasts and looked at the dial settings and wrote down all the numbers. Then I gave her some small breasts, the size that would have qualified her as president of the itty-bitty-titty-comittee. I wrote those dial numbers down too.
Gee, when I compare the two sets of numbers, the sensitivity of the dials in Poser where the same for big bazongas vs itty bitty ones. They never changed.
Somebody want to tell me what I am doing wrong. :b_confused:
Gary
One of the problems when dialing down breast size is that the various breast size dials don't always play nice with each other at negative values. In particular, the dial for silicone breasts (don't remember the actual name) does nasty things at negative values. Also, if you are using a FBM (especially an elite one) to make a character overall slender, sometimes it reacts badly with negative values of "breasts large".
One of my major dislikes about V4 is that the default breasts are a solid D, so getting them to look normal (not even small, just normal) is more work than it ought to be. Although I guess like Ockham says, it's a waste of time to point this out. I guess when DAZ gets around to doing a "Stephanie Petite" for the Gen 4 mesh it will be another morph of the base V4 rig again, which means you'll still be getting base models designed around a D cup, so texture distortion will pretty much be unavoidable when working with normal sized breasts.
After much practice, my sage advice:
Start with FBM, dial voluptuous down to between -4 and -6. This affects the full body, but results in much more realism. This is critical - starting any other way will yield unrealistic results. If you don't like the overall shape, change glutes, thighs, arms, whatever - separately.
Now adjust breasts, dial 'size' and 'large' down until you like the overall size.
Fix the distortions (they will be there) as best you can with other adjustments - among the helpful are diameter, cleavage, straight out, perk and ariole out. Natural can also be helpful - use it in the negative direction to fix the bottom shape.
This is the only way I have found to achieve small realism.
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
To attach the zip, I had to add a ".TXT" file extension. Drop the ".TXT" part when you save it to disk, so it becomes "SmallerBreastsV4.zip". Extract the zip to your Poser folder. The files should end up in:
Runtime/libraries/Pose/DAZ's Victoria 4/Morph Injections/3rd Party
And if you find a better free small breast morph, please let me know.
Just one little try, based on the one of Les but the boobies more to the inside. Sorry, its quick and dirty one so you have load the morph target in the old fashioned way via the properties Tab to the chest.
Ulli
Ulli
I like 'em small too :-)
My experience so far is only with Aiko3. With this figure it 's possible to dial them even 'almost' completely away without messing the geometry up too much. And i 'm also using magnets a lot to change other bodyparts as well.
Maybe this is gonna be a bit overkill on the topic here, but honestly i can 't understand why a lot of women in real life want to enlarge their breasts via a boob job.
Society failed to tolerate me...
... and i have failed to tolerate society
For the same reasons people in the gallery here start with a D (default V4) and dial up to EEE.
I have used combinations of male and child morphs to get smaller breasts... these exist for both V4 and V3. Perhaps using a flat chest like that and morphing the breasts back out with magnets or morphs would work. Long ago IssacNewton I think made a "Ando" morph for Posette that was a "neutral base" to morph new waist and breasts out from again.
Jules, that Lulu is very nice. Realistic small breasts.
one day I saw this really fabulous looking woman...she had a very curvacious body, fine shaped legs, real nice booty...then her boobs were pretty flat. It didn't look right at all. sorry to you real small breasted women, I've been looking at v2 and up for too long, plus all the fakers around town. :)
i feel the same way about real large breasts too. Too big doesn't look right.either...and after age sets in, and gravity takes over, and the major sag happens...they are darn scary with nipples down past the belly button ... yikes ... I can't take it anymore
anyway...check out this site for pictures of all different sizes of breasts...real ones. this would be a good reference for morphing and maybe for a developer to use in the next female model.
http://www.007b.com/breast_gallery.php
and... pictures and comparisons of the different cup sizes
http://www.afraidtoask.com/?page_id=119
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
Quote - > Quote - I thoroughly concur, tiny tits are tops!
LOL...that's good to know, since most women are NOT built like Vicky...LOL.
They aren't?!!!
Then they can't be 'real' women, can they? And I don't date boys! (Not that there's anything wrong with that... if you're a girl!) 8^D j/k
I should clarify something. I was just joking, but the thing is, almost every woman in my family has breasts that are as big as or bigger than V4's!
Ironically, the woman I'm most attracted to in my life is much smaller. But don't get me wrong. There's nothing wrong with a nice pair of D cups.
Folks I need a little help. I want to make smaller boobs
on my characters mainly V4 and V3. I can make them
smaller but they seem not real enough using the dials
for each character. I think small breast women have always
been hot. Just don't like the balloons most characters
come with. Thanks for any help!
