Wed, Feb 19, 4:32 PM CST
Forum Moderators: RedPhantom
Subject: Poser 8 users - Post your UI!
Netherworks ( ) posted Wed, 05 August 2009 at 9:44 PM · edited Wed, 19 February 2025 at 4:32 PM
This is what I came up with for the Pose Room.  I turned my Library into a non-dockable, floating window that's off by default and appears on top of the Hierarchy editor pane when I press the shortcut button (mapped to the unused Search button on my keyboard).
MikeJ ( ) posted Wed, 05 August 2009 at 10:14 PM
Where did the camera trackball go?
LostinSpaceman ( ) posted Wed, 05 August 2009 at 10:23 PM
How do you turn off docking by default?
Netherworks ( ) posted Wed, 05 August 2009 at 10:26 PM · edited Wed, 05 August 2009 at 10:31 PM
Quote - Where did the camera trackball go?
heh, the Render pane is showing.  I only use the controls in the preview pane, never liked the "Camera Controls" floater so I hid it.  You can close just about anything that you don't use too much.  I'm not animating a lot so I closed the animation controls, for example.
Netherworks ( ) posted Wed, 05 August 2009 at 10:30 PM
Quote - How do you turn off docking by default?
Okay, when the window is docked, you have a little square in the upper right corner.  right-click that and click on Drag-Dock Enabled to deselect the checkmark.  You can also switch from Docked to Floating this way.
Acadia ( ) posted Wed, 05 August 2009 at 10:36 PM
Where is the library?!
Netherworks ( ) posted Wed, 05 August 2009 at 10:40 PM
It floats back when I press a keyboard key (have the shortcut mapped to a key):
Little_Dragon ( ) posted Wed, 05 August 2009 at 10:52 PM · edited Wed, 05 August 2009 at 10:59 PM
I see that the Editing Tools and Document Display Styles can still be arranged horizontally.  I'd wondered about that.
Can they still be set vertically?
Quote - ... (mapped to the unused Search button on my keyboard).
You can assign your own hotkeys in P8?  Is there now an interface for this, or did you manually edit the XRC file?
Netherworks ( ) posted Wed, 05 August 2009 at 11:00 PM · edited Wed, 05 August 2009 at 11:04 PM
Little Dragon,
You can just float them by dragging into the middle of the screen (where preview is) and reshape to vertical or horizontal or even 2 columns if you wanted to :)
The snapping feature is well implemented with docking windows.  Areas that you can dock into give off a glow effect.  Sometimes it takes a wee bit of fiddling.
No, the standard Library hide/show shortcut is Ctrl+Shift+B.  I have a Natural Multimedia keyboard and I can map certain keys to evoke macros when pressed.  I changed the "Search" key on my keyboard to do Ctrl+Shift+B, which effectively lets me "toggle" the Library.
wolf359 ( ) posted Thu, 06 August 2009 at 10:05 AM
Hi Can someone post screen shot of the graph editor an animation pallete?
just curious
Thanks
My website
pjz99 ( ) posted Thu, 06 August 2009 at 10:18 AM
By the way for windows that are set to drag-dock enable, if you want to keep a window from docking, hold down Ctrl while dragging.
My Freebies
ssgbryan ( ) posted Thu, 06 August 2009 at 1:50 PM
I can't post until I get home tonight, but last night, I just moved every last palette to 1 screen & left the room on the other.
1912 x 1052 is nice.
I can actually see all of my Dystopia stuff without having to move the camera.
Netherworks ( ) posted Thu, 06 August 2009 at 3:23 PM
> Quote - Hi Can someone post screen shot of the graph editor an animation pallete? > > just curious > > Thanks
Here is the Graph Editor.  Smallest Size I can get as a floater.
Netherworks ( ) posted Thu, 06 August 2009 at 3:24 PM
Here is the animation palette floating.
wolf359 ( ) posted Thu, 06 August 2009 at 4:23 PM
No enhancements as I expected
Thanks for posting the images
Cheers
My website
raven ( ) posted Mon, 17 August 2009 at 5:44 PM
Here's a comparison pic of my P7/PPro vs P8 layout.
