Quote - Where did the camera trackball go?
heh, the Render pane is showing. I only use the controls in the preview pane, never liked the "Camera Controls" floater so I hid it. You can close just about anything that you don't use too much. I'm not animating a lot so I closed the animation controls, for example.
I see that the Editing Tools and Document Display Styles can still be arranged horizontally. I'd wondered about that.
Can they still be set vertically?
Quote - ... (mapped to the unused Search button on my keyboard).
You can assign your own hotkeys in P8? Is there now an interface for this, or did you manually edit the XRC file?
Little Dragon,
You can just float them by dragging into the middle of the screen (where preview is) and reshape to vertical or horizontal or even 2 columns if you wanted to :)
The snapping feature is well implemented with docking windows. Areas that you can dock into give off a glow effect. Sometimes it takes a wee bit of fiddling.
No, the standard Library hide/show shortcut is Ctrl+Shift+B. I have a Natural Multimedia keyboard and I can map certain keys to evoke macros when pressed. I changed the "Search" key on my keyboard to do Ctrl+Shift+B, which effectively lets me "toggle" the Library.
Hi Can someone post screen shot of the graph editor an animation pallete?
just curious
Thanks
By the way for windows that are set to drag-dock enable, if you want to keep a window from docking, hold down Ctrl while dragging.
![file_436158.jpg](https://live.cdn.renderosity.com/forum/threads/2778502/file_436158.jpg)
This is what I came up with for the Pose Room. I turned my Library into a non-dockable, floating window that's off by default and appears on top of the Hierarchy editor pane when I press the shortcut button (mapped to the unused Search button on my keyboard)..
