Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Sep 22 8:55 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
This looks like a classic example of Poser's smoothing issues and render problems. some quick quesitons...
That's all I have off the top of my head.. flying blind here---Poser isn't open right now and I have to head out soon, but just thought I'd toss some things in as food for thought. -Les
Those are pretty surely depth mapped shadow artifacts. Looks very much like Poser's default lighting, with 256x256 shadow maps.
As to how you fix it, don't use Poser's default ligthing, because it's garbage. Practically ANYTHING is an improvement over the default lighting scheme.
This is the wireframe view
I am using the default settings for Poser 6 because I must do it. Nothing changed in any moment, and the default lights of Poser 6.
I must use defaults and not tweak anything because this model is for sale in the marketplace, so I must know how to model it well for good Poser render or I won't be able to sell it.
some pointers:
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
Quote - I must use defaults and not tweak anything because this model is for sale in the marketplace, so I must know how to model it well for good Poser render or I won't be able to sell it.
That can't be right, if the model is for Poser, then you have any settings required in the file you supply whether it's a CR2 or PP2.
If your item requires any settings that can only be set by the user, then you'll need to mentin that in the ReadMe and should consider supplying a sample scene (one corresponding to one of the promo renders would be a good idea).
Obviously if you're going for compatability with older versions and/or D|S, some settings may not be available, but this mostly affects what you can do with materials unless you supply several version/application specific setups.
What modelling program you use won't solve some problems as those require the right settings in Poser.
Granted some problems can be lessened or eliminated by using the right techniques, but all reasonable modelling programs will have some means to achieve the desired end result.
And for god's sake, make sure you don't use Poser's default lights for your promos (or anything in fact).
Quote - And for god's sake, make sure you don't use Poser's default lights for your promos (or anything in fact).
Agreed wholeheartedly
Visit my blog! :D
Yup. In any version of Poser the default lighting will make you want to give up modeling in favor of a more rewarding career like sewer maintenance. :)
two things to take big note of:
Poser + triangles = ugliness. You can get away with a few tri's here and there, but something that's completely triangulate can be problematic at best. It looks like you've done some smooth modeling for the most part, too, but the program has output it that way. Definitely something to think about in your application itself...
Intersecting meshes like the way you have the wing going through the body can be weird in Poser; better to do things like wings as extrusions.-Les
Thanks to you all. I will take note of all this for the future.
I have tried all that before posting here. I tried reducing by hand all the triangles to quads, and small quads to big quads, and that's not the problem.
I had a bigger problem with another application that I was using before this, and now it seems that there is something in the output that is not good for Poser. I also tested different lights and the problem persists.
Intersecting meshes are not the problem, because if I eliminate them completely and export my object, the problem persists.
I have several modelers, some of them expensive but they produce enormous meshes that are hard to optimize to reach the 45,000 limit polygon that many marketplaces have. That's why I was using a low-poly modeler like Anim8or, but it is not a modeler done with Poser in mind.
I have purchased Hexagon that seems to not produce meshes with these problems, and has lots of modeling features that I appreciate, and will use in the future.
I will report if I see improvements when I remodel the plane.
Thanks a lot again for your time!
Keep in mind that no matter what you do, the default lights in poser will make it look like dogshit. This is not particularly a problem with your geometry, although you're getting some good advice about the long triangles etc., but in your first pic, those are depth mapped shadow artifacts. Avoiding them has more to do with camera orientation and shadow map size settings than changing your geometry.
Yes, Anim8or, Hexagon or Wings all have some good toolsets to correct this kind of mesh.
Wings is probably the easier to grasp for people new to modeling. In this case, I'd redo the whole model, as it would be more efficient and not longer (in Wings at least) than to attempt some heroic rescue on this one.
I am modeling a plane for poser and when I render it in Poser I see this:
There are some lines that are not there when rendered in other applications. You can see them in the border of the wings, in the propeller and in the fuselage.
Do some of you had this problem sometime? Why is this caused? How can I fix it?
Thank you very much for your help!
