Sat, Feb 15, 4:22 PM CST
Subject: Question about hair rim/edge due to ambient occlusion
ghost6677 ( ) posted Mon, 24 August 2009 at 3:27 AM · edited Sat, 15 February 2025 at 4:17 PM
Hello,
i have a question about conforming hairs.
When the scalp doesnt fit the head exactly due to scaling/morphing, i experience a slightly darker edge then the usual skin along the forehead.
I was able to track it down to the ambient occlusion in my lights.
Is there a possibility to EXCEPT a single material from AO, that looks quite easier then to plug an AO node in all other textures and leaving that one out :D
Thanks.
IsaoShi ( ) posted Mon, 24 August 2009 at 7:03 AM · edited Mon, 24 August 2009 at 7:08 AM
You can make a figure/actor/prop "Invisible to raytracing", which will stop it creating any AO. However, if you are using raytrace shadows it will no longer create any direct shadows either, which can be a problem.
The "Invisible to raytracing" option is in the body/actor/prop Properties palette.
(edited to add:) also, invisible to raytracing means it won't show in such things as Reflection, Refraction..
santicor ( ) posted Mon, 24 August 2009 at 3:15 PM
what if the scalp itself is just made invisible ( uncheck visible in its properties, asuming the conforming hair has scalp as a separate prop)
You  then  have the HEAD body part  that can  have the AO applied and the hairparts themselves should cause shadows on the head, no?
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
MistyLaraCarrara ( ) posted Tue, 25 August 2009 at 10:09 AM · edited Tue, 25 August 2009 at 10:14 AM
I did an 8 hour render last weekend, and I forgot to tick the Visible in Raytracing on a figure. doh!
But, it made a good illustration of Visbile in Raytracing, if you look at the shiny floor.
Dude on the left isn't casting a reflection.
oops, forgot to attach the image
IsaoShi ( ) posted Tue, 25 August 2009 at 10:52 AM
I would be a bit miffed if I had no reflection. Having only half a shadow is bad enough.
I found out about RT and reflections when some hide/show clothing parts for Rhiannon's Elsa Wylde produced AO artifacts. I set up two mirrors at an angle to show the artifacts from all sides in a forum thread picture. Then somebody suggested making the clothes invisible to raytracing.
Sure enough, my next render came out with one clothed Elsa and three nudes. I put the pic in my gallery (Mirror mirror on the.... eeeeek!).
Well, that's my story, and I'm sticking to it.
