You can make a figure/actor/prop "Invisible to raytracing", which will stop it creating any AO. However, if you are using raytrace shadows it will no longer create any direct shadows either, which can be a problem.
The "Invisible to raytracing" option is in the body/actor/prop Properties palette.
(edited to add:) also, invisible to raytracing means it won't show in such things as Reflection, Refraction..
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
what if the scalp itself is just made invisible ( uncheck visible in its properties, asuming the conforming hair has scalp as a separate prop)
You then have the HEAD body part that can have the AO applied and the hairparts themselves should cause shadows on the head, no?
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
But, it made a good illustration of Visbile in Raytracing, if you look at the shiny floor.
Dude on the left isn't casting a reflection.
oops, forgot to attach the image
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
I would be a bit miffed if I had no reflection. Having only half a shadow is bad enough.
I found out about RT and reflections when some hide/show clothing parts for Rhiannon's Elsa Wylde produced AO artifacts. I set up two mirrors at an angle to show the artifacts from all sides in a forum thread picture. Then somebody suggested making the clothes invisible to raytracing.
Sure enough, my next render came out with one clothed Elsa and three nudes. I put the pic in my gallery (Mirror mirror on the.... eeeeek!).
Well, that's my story, and I'm sticking to it.
what I should be."
Murakami)
Hello,
i have a question about conforming hairs.
When the scalp doesnt fit the head exactly due to scaling/morphing, i experience a slightly darker edge then the usual skin along the forehead.
I was able to track it down to the ambient occlusion in my lights.
Is there a possibility to EXCEPT a single material from AO, that looks quite easier then to plug an AO node in all other textures and leaving that one out :D
Thanks.
