Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 6:51 am)
Sentences please; all I see is an unreadable wall of text.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Winterclaw:
LOL, You have been texted or twittered. Some people can read this communication style, and some cannot. Not to be arrogant, but allow me to translate.
*"Well, were do I start.
The other day I made a music player, a bit like an Ipod. I exported it to poser to add texture to get it ready to save. Bearing in mind, I had made a UV map for the screen and menu button, and the rest was being textured in the Mat Room. I’ve done this before and had no problems adding .jpg’s, etc. to items that I made before.
Well, I imported, went to the mat room, and added textures to the bit that didn’t need UV maps on them. OK, then I went to add .jpgs like you do, then back to the Main Poser, and went to render in FireFly, and nothing. The normal textures rendered great but the others didn’t. I tried different formats, like .png.
Today I decided to put it a side and make something else and the same thing has happened again, but this time the UV textures worked on 1 item but not the others. I’m so pulling my hair over this, as it’s so strange as to why it’s doing it.
I’m working in poser 7. All normals are all forward. I hope some one can help me as I’m thinking of screaming very loud, LOL. Thanks. Sorry for the long read."*
Sadly, I do not have the answers to the problems.
LMK
Probably edited for spelling, grammer, punctuation, or typos.
Thanks for the translation, lkendall. I'd given up on the first post, too.
As for the problem at hand.. are you sure you've saved - and that you're using - the new, UVMapped obj?
Thank you Ikendall, that helped a bunch.
As trekkiegrrl suggested it sounds like the OP forgot to save after making the UVs.
WARK!
sorry about the long winded and confusing writing was very tired and stressed wen wrote it lol
chris the player and other item were made in hex i followed atutorial on how to do thm step by step wati cant under stand is the other item i made yesterday accepeted theuv map but wen i did another tht one did not
However, you might want to consider getting a copy of UV Mapper (I use the Pro version, but what follows applies to the free version)
With UV Mapper you can Load your model to see what the UV mapping done in Hex looks like.
If you need to UV map it the simplest thing to do would then be to create a new UV Map using the Box method for the player.
Then you could select by group or material and work on part individually. For example after Box mapping the whole model you can then select a material such as menu and map it using planer mapping and make it fill the entire map.
Then when you’re done you would need to Save the Model and you can also Save the Texture Map (i.e., the template) to use as a guide for texturing. When saving the Texture Map you can chose to not show parts that are hidden, so for example you can hide the menu and save a Texture Map for the rest of the model and then show the menu and hide the rest of the model and save a Texture Map for the menu.
Here are a few useful UVMapper Keyboard shortcuts:
=: Expands the current selection to fill the entire map
‘: Hide unselected
]: Show selected
[: Hide selected
I just started using Hex, so I'm not much help either. However, from perusing the Hexagon forum here (probably a good place to stop by), I've seen more than one thread about difficulties UVMapping in Hex.
I just tried UVMapping something from Hexagon last night, and the way it 'worked' was way different from my other package (Wings 3d). This evidently is a known problem with Hexagon. Evidently you do something with the edges, but I'm still in nu-be mode, so try over there.
I was gonna suggest checking your keyboard for a loose space bar, until someone explained it...;)
I use Hexagon almost exclusively for my models these days - and its UVmapping SUXXX!
So I uv map everything in UVMapper Pro after it's done.
I've tried it in Hexagon, but .. ended up remapping it in 'UVMapper anyway.
well were do i start the other day i made a music player bit like a ipod i exported it to poser to add texture to get ready to save baring in mind i had made a uvmapfor the screen and menu button and the rest was being texture in mat room ive done this be4 had no problems adding jpg s etc to items i made b4 well i importedwent to mat room addedtextures to bit thtdidnt need uv map on wen ok thn i wentto add jpg like u do back to main poser went to render in ff and nothing the normal textures renderedgreat but the others didnt i tried different formats png to day i decided toput it a side and make some thing else and same ting has happened a gain but this time uvtextures worked on 1 item but not the others im so pulling myhair over this as itssostrangeto why its doing it im working in poser 7 all normals ar all forward hope some one can help me as im thinkin of screaming very load lol thnks sorry for the long read
