What are you using for the Irradiance Cache value? It can be much lower for IDL than AO.
No, what that means is you told Poser it is not allowed to speed up IDL by using cached values. You're forcing it to calculate IDL luminance and shadows for every single point in the scene, including points you can't see that are needed to figure out the total bounced lighting.
Try 5. If it looks wrong, try 10, and so on. It will be way faster.
IC=100
ILQ=7
Time: 424 seconds
Time: 14 seconds
So IDL is only costing 9 seconds.
Quote - i've tried 2, 25, 42, 70.. it all leaves awkward gaps in the "ao" type shadows around her clothes.
its rendering right now ( precalculation went WAY faster with lower IC )
You may be experiencing the IDL 90-degree artifacts, which cannot be dismissed via higher render settings. This is a bug that SM is working on.
I'd have to see what you're getting to be sure.
Maybe. Or moving the cloth away a tiny bit might fix it.
Just wondering what your render times are with an IDL quality higher than 2. lol.
I'm on a 2.4ghz core 2 duo with 4gb ram and im sprouting cobwebs waiting :/
