Tue, Nov 26, 4:34 AM CST
Subject: any quad core i7 iMac users using IDL yet?
Vex ( ) posted Wed, 18 November 2009 at 4:04 PM · edited Tue, 26 November 2024 at 4:25 AM
Just wondering what your render times are with an IDL quality higher than 2. lol.
I'm on a 2.4ghz core 2 duo with 4gb ram and im sprouting cobwebs waiting :/
bagginsbill ( ) posted Wed, 18 November 2009 at 4:43 PM
What are you using for the Irradiance Cache value? It can be much lower for IDL than AO.
Vex ( ) posted Wed, 18 November 2009 at 4:57 PM
 100 lol.
i thought it had to be 100 for idl to make shadows?
bagginsbill ( ) posted Wed, 18 November 2009 at 5:01 PM
No, what that means is you told Poser it is not allowed to speed up IDL by using cached values. You're forcing it to calculate IDL luminance and shadows for every single point in the scene, including points you can't see that are needed to figure out the total bounced lighting.
Try 5. If it looks wrong, try 10, and so on. It will be way faster.
Vex ( ) posted Wed, 18 November 2009 at 5:04 PM
 oh neato. okies :D
thank you.
for quality I should put it on 100 ?
bagginsbill ( ) posted Wed, 18 November 2009 at 5:07 PM
No try 7.
bagginsbill ( ) posted Wed, 18 November 2009 at 5:14 PM
Check this out. Rendered with
IC=100
ILQ=7
Time: 424 seconds
bagginsbill ( ) posted Wed, 18 November 2009 at 5:15 PM
Now with
IC=10
ILQ=7
Time: 23 seconds
Vex ( ) posted Wed, 18 November 2009 at 5:15 PM
 i've tried 2, 25, 42, 70.. it all leaves awkward gaps in the "ao" type shadows around her clothes.
its rendering right now ( precalculation went WAY faster with lower IC )
bagginsbill ( ) posted Wed, 18 November 2009 at 5:17 PM
IDL turned off.
Time: 14 seconds
So IDL is only costing 9 seconds.
bagginsbill ( ) posted Wed, 18 November 2009 at 5:18 PM
Quote -  i've tried 2, 25, 42, 70.. it all leaves awkward gaps in the "ao" type shadows around her clothes.
You may be experiencing the IDL 90-degree artifacts, which cannot be dismissed via higher render settings. This is a bug that SM is working on.
I'd have to see what you're getting to be sure.
bagginsbill ( ) posted Wed, 18 November 2009 at 5:22 PM
See the strange lighting where the cube meets the floor in the shadows area? That's a bug.
bagginsbill ( ) posted Wed, 18 November 2009 at 5:25 PM
Here I used much higher settings (40, 40), but still the artifacts are there.
Vex ( ) posted Wed, 18 November 2009 at 5:29 PM
bagginsbill ( ) posted Wed, 18 November 2009 at 5:32 PM
Yep - that's the bug.
Vex ( ) posted Wed, 18 November 2009 at 5:39 PM
 so if i tackle it with the morph tool and change it from a 90º angle it will behave?
bagginsbill ( ) posted Wed, 18 November 2009 at 5:43 PM
Maybe. Or moving the cloth away a tiny bit might fix it.
Vex ( ) posted Wed, 18 November 2009 at 5:46 PM
i really like IDL.
it makes me feel like im not using a $250 piece of software.
