Mon, Dec 23, 12:04 PM CST
Subject: Clay Render Material...?
DarkEdge ( ) posted Fri, 11 December 2009 at 8:07 AM · edited Mon, 23 December 2024 at 7:43 AM
I know I've seen this before, but now I can't find it.
Looking for a simple Clay material for rendering. I have PoserPro and Poser 8.
Thanks
PhilC ( ) posted Fri, 11 December 2009 at 8:30 AM
New Node > Lighting > Diffuse > Clay
Hope that helps :)
Anthanasius ( ) posted Fri, 11 December 2009 at 8:34 AM
Excuse me but, what is a clay in french ?
Génération mobiles Le Forum / Le Site
DarkEdge ( ) posted Fri, 11 December 2009 at 8:40 AM · edited Fri, 11 December 2009 at 8:46 AM
argile
Phil, what would be the proper slot to stick this in, diffuse, alt diffuse...???
Anthanasius ( ) posted Fri, 11 December 2009 at 8:49 AM
Thx ...
Clay node work like the Diffuse node pluged in Alt_Diffuse .
PhilC ( ) posted Fri, 11 December 2009 at 8:57 AM
Yes Alt Diffuse, but to be honest just experiment and see.
DarkEdge ( ) posted Fri, 11 December 2009 at 9:10 AM
Thanks Anthanasius and Phil. 😉
bagginsbill ( ) posted Fri, 11 December 2009 at 9:23 AM
The Clay node will act just like Diffuse until you increase the Roughness.
Be sure to turn off the built-in diffuse ... set Diffuse_Value on the root node to 0.
Clay has little to no specular, so set Specular_Value = 0.
If you are simulating a somewhat polished clay, you will need some very broad and weak specular. If you are doing glazed clay, this is all wrong and you need one of my glass shaders.
DarkEdge ( ) posted Fri, 11 December 2009 at 9:33 AM
Thanks BB. No I'm going for the classic flat clay look in 3d renders.
Khai-J-Bach ( ) posted Fri, 11 December 2009 at 9:33 AM
so this will produce a clay render?
you'll need AO or IDL as well for the full effect.
Khai-J-Bach ( ) posted Sat, 12 December 2009 at 2:01 PM
By jove, I think I've got it. hows this? single clay node on the alt-diffuse. Diffuse and Specular set to 0. BB's Envirosphere, 2 lights, 2 raytracing shadow, 1 IBL/AO. Rendered in Poserpro.
the Mesh is my rebuilding of my Wellington Mark 1 Aether Propulsion Engine.
Khai-J-Bach ( ) posted Sat, 12 December 2009 at 2:08 PM
rear view
Anthanasius ( ) posted Sat, 12 December 2009 at 4:29 PM
I think you can have the same result with a diffuse node, not only clay ... No ?
Khai-J-Bach ( ) posted Sat, 12 December 2009 at 5:49 PM
doesn't give that 'soft' look very well doing that. nice and clean tho.
Anthanasius ( ) posted Sat, 12 December 2009 at 5:59 PM
Ok !
