Sun, Feb 2, 10:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Subject: Poser 5
KimberlyC ( ) posted Tue, 29 December 2009 at 10:51 PM · edited Sun, 02 February 2025 at 10:35 AM
 Gang I'm in need of some help. I have 1GB of ram. When trying to render in Poser 5 if I add more thank vick and hair, it won't render. It gets stuck on "adding object". Do we feel this is a "needs memory" problem or a Poser problem?
Thanks!
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
seachnasaigh ( ) posted Tue, 29 December 2009 at 11:38 PM
While 1Gb isn't a lot for Poser, you certainly shouldn't  crash because of Vicky and hair.  Try a different doll and different hair, etc., just to see if the problem remains.
Post a screenshot of the scene preview, and a screenshot of the render settings.  Maybe someone will spot the problem.
KimberlyC ( ) posted Tue, 29 December 2009 at 11:40 PM
It happens with everyone of them. Higher res textures alone freeze up poser as well.
markschum ( ) posted Tue, 29 December 2009 at 11:52 PM
I run win xp with 512 mb of real ram , and have the page file (virtual memory) set to system managed.  I didnt have problems with Poser 5 with sp2 loaded.
seachnasaigh ( ) posted Tue, 29 December 2009 at 11:55 PM · edited Tue, 29 December 2009 at 11:59 PM
I only heard of 3D (for personal use) midway through Poser 6, but I believe there is a limit to texture dimensions in P5 which is less than that of P7 and later.  I wonder if that is the issue, but I don't know.
State the pixel dimensions of the textures which failed.  And hopefully, someone with P5 experience will jump in here.
~  Ooops  ~  Mark posted while I was still typing. ^^
What do you mean by sp2?  Stephanie Petite (generation 2), or does that refer to a service pack 2 (for P5 or for WinXP?)
KimberlyC ( ) posted Wed, 30 December 2009 at 12:03 AM
Quote - I run win xp with 512 mb of real ram , and have the page file (virtual memory) set to system managed.  I didnt have problems with Poser 5 with sp2 loaded.
page file set to system managed?
KimberlyC ( ) posted Wed, 30 December 2009 at 12:11 AM
ok.. set the system managed..will see if that makes a difference.
KimberlyC ( ) posted Wed, 30 December 2009 at 12:34 AM
Nope..didn't work. Still stuck on "Adding objects...." :(
Jules53757 ( ) posted Wed, 30 December 2009 at 1:31 AM
Do you have all Service Releases installed? Also I would set the pagefile to manually 2048 and 2048 for both figures. Reduces the processorload a little bit.
Ulli
pakled ( ) posted Wed, 30 December 2009 at 11:15 AM
I'm running Poser 5 with 3g (actually 4, but I've been told it only uses 3) of memory. I've also heard that sometimes if you have a reference to a folder that doesn't exist or is misplaced, it will cause 'memory' errors.
You might try reloading the file.
KimberlyC ( ) posted Wed, 30 December 2009 at 11:28 AM
Quote - Do you have all Service Releases installed? Also I would set the pagefile to manually 2048 and 2048 for both figures. Reduces the processorload a little bit.
Yep.. how do you set the pagefile manually for the figures?
KimberlyC ( ) posted Wed, 30 December 2009 at 11:30 AM
Quote - I'm running Poser 5 with 3g (actually 4, but I've been told it only uses 3) of memory. I've also heard that sometimes if you have a reference to a folder that doesn't exist or is misplaced, it will cause 'memory' errors.
It happens with all characters.. Hmm.. starting to sound like I need  to get a couple more gigs.  darn costly :P
Plutom ( ) posted Wed, 30 December 2009 at 12:34 PM
You have plenty of RAM for Poser 5 since Curious Labs only recommended 256MBs
Clean your computer via Cleanmgr or a good program like McAfee.
Defrag your computer.  Then try Poser 5.  Does it work, if no
Shut down your computer for about 10 seconds and then reload Poser 5, if it doesn't cure the problem. You probably will need to do a little troubleshooting.    Delete half of what you have does it run, if yes than it is something in the half that you just deleted, split that part in half, does it run, if yes than it's in the section that your removed.
When you find the culprit, are you using it with other characters?
This process solves about 95 percent of Poser or any other software problems.  Jan
seachnasaigh ( ) posted Wed, 30 December 2009 at 3:07 PM · edited Wed, 30 December 2009 at 3:10 PM
It isn't a lack of RAM.  1Gb will not be overwhelmed by loading one doll and accessories.  Something else is wrong.
  This is important, according to what I've read about P5, as it had serious bugs in its initial release.
Does anyone know where service release updates for P5 can be downloaded?
KimberlyC ( ) posted Wed, 30 December 2009 at 3:19 PM · edited Wed, 30 December 2009 at 3:28 PM
 Yea.. I have the most recent service update.  I've tried the above and still having problems :(
I'm off to try the files. I'm not sure where to start lol Problem is..it does it almost everytime. Its not one certain character :(
wespose ( ) posted Thu, 31 December 2009 at 1:52 PM
Ive ran Poser 5 on a Pentium 3 with only 386 Megs of PC 133 ram and didnt have this problem. Now granted if I used more than 2 figure in a scene it would run out of virtual memory and crash during rendering. but still I never had any problems with textures or hair props. Hell as it is now Im on a P4 with 1.86 gb of pc 5400 ram and I never have a problem with hair props or textures, I dont think its your hardware.
KimberlyC ( ) posted Fri, 01 January 2010 at 11:38 PM
Think i need a new poser lol :)
FightingWolf ( ) posted Sat, 02 January 2010 at 1:15 AM
Online Now!
" Think I need a new Poser lol :)"
That was my first thought when you mentioned that you have Poser 5.  I have poser 8 and I can't imaging going back to anything before that.  But if you decide to keep your Poser 5 then you may need to uninstall then reinstall the program.  Sometimes programs or a file will become corrupt causing problems like the one you have.
If you have already tried the reinstall method then the only other thing that I think it could be is a registry issue where something in the registry is causing the problem.  Most of the time a registry cleaner will fix the those types of problems and they are safer than manually messing with the registry. Just make sure you get a registry cleaner that is reliable and from a reliable source.  Don't pick one of those registry software that you may have seen in an annoying pop-up that you didn't ask for.  If you have McAffee Internet Security then you already have one.  If not then you can go to Cnet.com to look at some reviews and pick a reliable one.
Frederick
Poser By Design
KimberlyC ( ) posted Sat, 02 January 2010 at 5:25 PM
Quote - " Think I need a new Poser lol :)"
Frederick
Poser By Design
Oh I have no problem upgrading to 7 or 8 If I could. I'll try both of these. I'm still having that problem, so maybe one may help. Thanks!!
