Mon, Feb 24, 9:05 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 1:37 pm)
Subject: Strange anomaly when rendering: Please Help!!
GaryChildress ( ) posted Sat, 02 January 2010 at 7:26 PM · edited Thu, 30 January 2025 at 7:51 PM
I'm trying to render an object in Poser and it keeps giving me strange black patches on the item. I've tried a few different things and nothing seems to help. I have no idea why the item is doing this. It shows up fine in the preview window but then when I render it shows the black patches. It only shows in render.  I've tried different texture map orientations and tried smoothing the item more. I used Wings3d to create the object. Nothing seems to work so far.
Please help!! :(
Please visit My 3D Freebies
Thank you for your patronage!
Khai-J-Bach ( ) posted Sat, 02 January 2010 at 7:28 PM
have you tried switching on 'Normals Forward' in the texture room?
markschum ( ) posted Sat, 02 January 2010 at 7:30 PM
Try checking the NORMALS FORWARD box in the material settings.
These black polys are usually reversed normals or sometimes a non-planar polygon. Normals forward should fix it if its the normals.
LaurieA ( ) posted Sat, 02 January 2010 at 8:03 PM · edited Sat, 02 January 2010 at 8:03 PM
Sometimes it's caused by colinear faces too. And normals forward doesn't always fix them.
pjz99 ( ) posted Sat, 02 January 2010 at 8:39 PM
can you show a wireframe of that model?
is polygon smoothing on?
are you sure you don't have duplicated polygons (your modeler might refer to this as "two-sided polygons")?
My Freebies
Medzinatar ( ) posted Sat, 02 January 2010 at 8:40 PM
There is sometimes roundoff error bringing in from Wings, try adding displacement node of say 0.001 to fix colinear if normals fixes don't work
GaryChildress ( ) posted Sat, 02 January 2010 at 9:02 PM
Many thanks!  Normals forward worked!  :)
pjz99 ( ) posted Sat, 02 January 2010 at 9:05 PM
If you HAVE to hit normals_forward to get your model to render right, then something is wrong with your geometry.  Can I take a look at your OBJ file?  PM me your email address if so.
My Freebies
LaurieA ( ) posted Sat, 02 January 2010 at 9:25 PM
Just out of curiosity, you do run the cleanup command in Wings when you finish a model, right? Just to clean up isolated verts and stuff?
GaryChildress ( ) posted Sun, 03 January 2010 at 7:01 AM
No. I never run the cleanup command. I wasn't sure what it's function was. I usually select the entire model and tesselate/triangulate, though.
pjz99, I sent you my e-mail address.
I think the problem is that I'm dealing with a very thin piece of material and when I went to give it bends and folds I think I may have gotten some of the geometry messed up.
pjz99 ( ) posted Sun, 03 January 2010 at 1:01 PM
All polygons are infinitely thin (they're two dimensional) - I'm pretty sure your problem is that you have two sets of polygons layered up against each other.  We'll see when I get a copy of your model, it won't take long to look.
My Freebies
GaryChildress ( ) posted Sun, 03 January 2010 at 1:14 PM
model sent....
Thanks. I'm pretty sure that is the problem. I was working with a very thin piece and think I may have gotten some of the front/back orientations messed up while creating folds and stuff.
