Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
I'm several versions back, but is it possible you don't have a texture for him? The default versions of characters often have a 'plastic' look to them, so usually you have a 'character' (x for David, etc)
Stop me if you've already done this, though.
Lose Reflection_Lite_Mult while you're at it, too. Does absolutely nothing good for your render, and I believe it slows things down, too.
The "unmanly" eyebrows may be due to the texture set you're using. Not everyone has a Gallagher Brothers monobrow, anyway. Also, keep in mind it's supposed to be a young guy so you shouldn't expect it to be extremely hairy.
All that said, you could try creating a new transmap with great big hairy brows if it bothers you that much.
I believe I have a texture for him. The eyebrows is D_Transmap. jpg and the face is D_HeadMap.jpg but maybe those are the default?
Changed the falloff values and lost the Reflection_Lite_Mult but those didn't change anything, thanks anyway.
Altered the transmap to make the white value of the eyebrow more white and that helped a little. Guess I need to get another Head map. Maybe the eyebrows just aren't that beefy with the D_HeadMap.jpg file.
Michael
![file_449913.jpg](https://live.cdn.renderosity.com/forum/threads/2797725/file_449913.jpg)
Hi All,I'm having a devil of a time to get my David figure's eyebrows to fill out.
Attached is a picture of his 'unmanly : )' eyebrows. This guy needs his eyebrows!
I'm also attaching the settings I have in the material room.
I am using Poser 8.
Thank you for any help.
Michael
