Wed, Feb 12, 10:48 PM CST
Subject: a very stupid and simplistic question..
erosiaart ( ) posted Sun, 04 April 2010 at 4:41 AM · edited Tue, 11 February 2025 at 5:28 AM
positve/negative..then why isn't my moon becoming a half moon?  Have I suddenly forgotten?
can someone plz baby me a bit and do a mini tut on creating half noons?
somehow, my brain isn't working here.
DAM3D ( ) posted Sun, 04 April 2010 at 5:03 AM
 I would just use the sky editor to edit the moon itself...but if you wanna make an object (sphere) and make it look like a half moon, then just make 2 spheres, select the one you want to make the moon, hit the little A for attribute editor... select positive.
Then select the other sphere and it's A for attribute and select negative. Then make that sphere a bit larger and move it into place to "slice" a chunk out of your moon sphere, select both and group them.
 My Rendo-Space
Do you know where your towel is?! I love Vogon Poetry. :P
DON'T PANIC!
Portland Pirate Festival Arrrr!
erosiaart ( ) posted Sun, 04 April 2010 at 5:07 AM
that's what i did.. and it didn't happen..
i mean creating the object. It ought to have happened.. but it didn't. That's why i was wondering if I went wrong somewhere.. and I wasn't doing it right..
erosiaart ( ) posted Sun, 04 April 2010 at 5:15 AM
Ah..got it.. the grouping bit. Dumb..dumb..
thanks weezer!
TheBryster ( ) posted Sun, 04 April 2010 at 8:14 AM
WTG, Rosie!
pakled ( ) posted Sun, 04 April 2010 at 9:15 AM
now you know the only stupid questions are asked in the Poser forum...;) j/k..;)
erosiaart ( ) posted Sun, 04 April 2010 at 9:24 AM
palked.. lol!!!
cheers.
btw.. my moon is a bowl!!! i guess i have to work that out,,,
bobbystahr ( ) posted Sun, 04 April 2010 at 11:20 AM
 Do it with the Light Lab Rosie...a half moon is the product of shadow and not subtraction of part of the moon in real life so would be made the same way in Bryce
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
erosiaart ( ) posted Sun, 04 April 2010 at 11:25 AM
what if you were putting a lady sitting on it? a poser.. pardon the blasphemy.. figure? or a cat? or a dolphin jumping over the moon? ok..that i can use the skylab for. Illusion there. But a cat on a moon?
bobbystahr ( ) posted Sun, 04 April 2010 at 11:45 AM
 Were I to try that [and I did], I'd make it a 2D object essentially and have it face the camera, there's a switch for that, and have the lady or cat grouped to the moon where you want it/her to appear, so no matter where you put your camera you can't see but the side shot keeping the 2D aspect out of the image. I did a similar image for an all nite radio show and that's how I achieved this, although in Imagine 3D but the technique would be the same.. ...
I see a sound
erosiaart ( ) posted Sun, 04 April 2010 at 11:50 AM
Ok..think i've got that.. though the camera bit keeping the 2d out of the shot aspect puzzles me.
tom271 ( ) posted Sun, 04 April 2010 at 12:34 PM · edited Sun, 04 April 2010 at 12:37 PM
Instead of a spheres try two thin cylinders...    add a radial light ... in the lab, under fallout set it to range.. put a small number on it .. like 33.. and move the radial light very near the moon...  in the materials lab of the cylinder.. knock out shadows...   It's a fantasy moon.... add a moon texture..
bobbystahr ( ) posted Sun, 04 April 2010 at 12:41 PM
 Tom has it.... essentially a cylinder shrunk in the length would have the 2D character and I think Track to camera in the {A} tab would keep it looking at the camera
I see a sound
skiwillgee ( ) posted Sun, 04 April 2010 at 4:30 PM
Rosie,  Here are three samples I did for you in about 15 minutes.  Clockwise starting from the top a sphere, a sphere flattened on the Z axis, and a single cylinder.  All matted with a simple rock material ( I did this in Bryce 5 with stock presets).
They are individually lighted with their own parallel light set to ranged and the range value is low enough that the light is limited its moon only.  All three are rendered in the same scene close to each other so you can see the ability to limit lighting on objects when you use ranged settings.  The flattened sphere has three parallel lights spread out a little so to make a bigger crescent.
The problem with these would be your desire to place a figure sitting on the moon.  The lights would effect the imported poser figure also and you may be wanting something different for the figure.  But if you like the realism of these examples you can always render the moon, save the image and then import the image as a 2d plane for you figure to sit on.
Just some thoughts.  Happy Easter.
UVDan ( ) posted Mon, 05 April 2010 at 4:06 AM
Forum Moderator
erosiaart ( ) posted Mon, 05 April 2010 at 4:36 AM
Thanks everyone. I'll sit on it tonite. (41 deg cel here).
UV Dan..lol..that moon is adorable!
Willie..i'll need to create that moon for another scene..so your mini tut is a blessing.
Tom..I'm gonna try that out later down the day.
Bless ya for helping..
TheBryster ( ) posted Mon, 05 April 2010 at 7:48 AM
*now you know the only stupid questions are asked in the Poser forum...;) j/k..;)
Pakled? Cut that out! We don't go insulting our Poser collegues, even if it is justified. :lol:
pakled ( ) posted Mon, 05 April 2010 at 11:22 PM
I know...I've been trying for years to get them to stop thinking questions are stupid in general. What can I do?...;)
clay ( ) posted Mon, 19 April 2010 at 1:53 PM
OR you just make a sphere add your material to it, then go into the material lab, ad a "b" channel in the transparency and then select "basic altitude" from the material list, then in the DTE select the filter and adjust the a and b settings to get the transparency to your liking. Like the moons in this image I did.
Do atleast one thing a day that scares the hell outta ya!!
UVDan ( ) posted Mon, 19 April 2010 at 2:01 PM
Forum Moderator
Thanks for that tip.   I always wondered how folks got moons like that.
clay ( ) posted Mon, 19 April 2010 at 2:03 PM
Dan that's also how I do water lines on terrains, I use the diffuse channel with basic altitude instead of the transparency channel.
UVDan ( ) posted Mon, 19 April 2010 at 6:14 PM
Forum Moderator
Thanks, that is nice to know.
erosiaart ( ) posted Mon, 19 April 2010 at 9:35 PM
clay..lovely moon..
thanks .. if only it wasn't 42 deg here now..i'd sit and work on it.
lines in water??
clay ( ) posted Mon, 19 April 2010 at 10:08 PM
yes where you see where water has pulled from the bank of the terrain. Like this sample.
erosiaart ( ) posted Mon, 19 April 2010 at 10:47 PM
got it..
thank you for that tip! Will use it for sure..
Cyba_Storm ( ) posted Sat, 24 April 2010 at 4:13 AM
"There is no such thing as a stupid question, only people too stupid to ask a question and learn."  Note:This quote does note apply to Poser users. Yeah yeah, I know. Another couple of days in the comfy chair for picking on the talentless. Ooops. Um. I didn't mean talentless. Okay a week in the comfy chair. Lets change that talentless to lacking imagination. Better? No.
Looks like you need to order in a few meals Cardinal. This could take a while.
TheBryster ( ) posted Sat, 24 April 2010 at 8:26 AM
Huh? You think I'm gonna feed you while you're in the Comfy Chair. Get real! The only meals I'm gonna order in are TV dinners for me while I watch you suffer!
Sentenced to 10 days in the Cardinal's Cradle of Pain :lol:
