Sat, Feb 8, 10:10 PM CST
Subject: Exporting for Photoshop Extended
inquire ( ) posted Mon, 05 April 2010 at 1:56 PM · edited Sat, 08 February 2025 at 10:05 PM
 I have PoserPro2010. I'm about to buy, when it's released, Photoshop CS 5. If I wish to export a figure from Poser so that it can be imported in Photoshop, how do I go about that? Does PoserPro2010 have that ability already built in?
Miss Nancy ( ) posted Mon, 05 April 2010 at 2:18 PM
cs4e apparently don't recog. poser obz files, hence:
  • export wavefront.obj from poser or
  • expand obz file in geom. folder
 then import smart obj to cs4e
inquire ( ) posted Mon, 05 April 2010 at 2:23 PM
 I'm going to get CS5 Ex. I hope it does a better job. But, assuming it's cs4e, and I export as a wavefront.obj, can I import into Photoshop so that the textures, materials, colors, lighting, all look as they did in the Poser render? In other words, will I get a uni-colored plastic-looking thing, or will it look as the figure did in the render?
Miss Nancy ( ) posted Mon, 05 April 2010 at 3:20 PM · edited Mon, 05 April 2010 at 3:26 PM
cs4e does various render styles, incl. ray-trace.  I found the lighting seems brighter in poser (directional lites only), but otherwise it looks like the smooth-shaded preview. for some reason this one failed to import the tiff file - may not have found it.  no, wait, I forgot to load 'em.  once loaded, it looks like texture-shaded preview.
I dunno if cs5e supports IBL/IDL/GI, but at least cs4e will import the three default infinite lites.
ask in photoshop forum about automating the process whereby it applies the tiff file to all mtls.
for me it doesn't load the tiff file by itself, even tho in same folder level as obj file.
inquire ( ) posted Mon, 05 April 2010 at 3:41 PM
 Thank you for your help and the screen shot illustration. You say it looks like the texture-shaded preview. Does it ever look as good as the  render?
bagginsbill ( ) posted Mon, 05 April 2010 at 4:48 PM
No.
Miss Nancy ( ) posted Mon, 05 April 2010 at 5:56 PM
cs4e renders as good as, but much slower than, poser 4 IMVHO. no shader trees, no IDL/GI. I would advise them not to try to add those to cs5e. it has GC and exposure control, but that's not enuff.
arrow1 ( ) posted Thu, 08 April 2010 at 11:56 PM
I have CS4 extended and have been trying to find a tutorial on how to export a Poser 3d mesh with textures into Photoshop CS4 extended and then open it..Can anyone assist and I cannot find a tute anywhere? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
inquire ( ) posted Fri, 09 April 2010 at 6:45 AM
 I did manage to find this, after posting my question here:
Look at Chapter 19 »3d Basics« in
http://help.adobe.com/en_US/Photoshop/11.0/photoshop_cs4_help.pdf
»Photoshop supports the following 3D file formats: U3D, 3DS, OBJ, KMZ, and DAE.«
Miss Nancy ( ) posted Fri, 09 April 2010 at 4:51 PM · edited Fri, 09 April 2010 at 4:55 PM
if the tutorial only needs to involve how to export poser figure from poser, very simple (OS X).
opening the obj file in cs4e just requires using the "open" cmd. the downside is how slow it
manipulates and renders in cs4e IMVHO, but at least one can paint directly on the obj.
  1. select figure in poser
  2. file/export/wavefront obj
  3. single frame
  4. uncheck ground in hierarchy
  5. leave export options at default
  6. save to new obj folder, which will have obj and mtl files
  7. then the tedious part:
  8. get list of all texture files (scripts/printinfo/listFiles)
  9. manually put copies of all texture files in new obj folder
  10. there is an util script to do step 9 by machine, but it doesn't work well for me
  11. open obj file in cs4e like any image file (doesn't have to be smart object)
  12. if the texture names are all identical to the ones in mtl file, cs4e will load all of them
inquire ( ) posted Fri, 09 April 2010 at 5:44 PM
 Where is that utility script -- the one to do step 9 by machine? I'd like to try it. Here's hoping.
Miss Nancy ( ) posted Sat, 10 April 2010 at 12:26 PM
inquire ( ) posted Sat, 10 April 2010 at 6:34 PM
 Thank kyou very much, Miss Nancy.
arrow1 ( ) posted Sat, 10 April 2010 at 7:44 PM
Thanks all for your help.Cheers
