Sun, Feb 2, 6:18 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: O/T .temp files
arrow1 ( ) posted Sun, 25 April 2010 at 11:24 PM · edited Wed, 29 January 2025 at 6:09 AM
Does anyone know if it is safe to delete .temp files stored on my computer? My machine is having a heart attack at the moment and while I was searching for files to delete I came across 3.26gigs of temp files mainly made by Poser! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
RobynsVeil ( ) posted Sun, 25 April 2010 at 11:39 PM
By all means, delete them!
Metaphor of Chooks
RobynsVeil ( ) posted Mon, 26 April 2010 at 12:01 AM
Actually, it's a good idea to delete .tmp files as well, particularly those left by rogue programmes like MSN Messenger - never cleans up after itself :cursing:. I use a script that cleans them up for me at startup... just pop this in your Startup folder and the next time you boot, it will invoke the script (you might need to give it permission - in WinXP, it just runs) and then you sit and wait a bit as it cleans them all up. I've cleaned off gigabytes of rubbish left behind that way.
Metaphor of Chooks
arrow1 ( ) posted Mon, 26 April 2010 at 12:09 AM
 Many thanks for your reply.Sorry to be a pain but where do I find the startup folder to put the script in? Cheers
RobynsVeil ( ) posted Mon, 26 April 2010 at 12:23 AM · edited Mon, 26 April 2010 at 12:25 AM
For WinXP it's:
C:Documents and Settings"User Name"Start MenuProgramsStartup
where "User Name" is your name. I have no idea where it might be in Win 7 or if Win 7 will allow something to run at start-up... I can't afford Win 7 atm so I'm sorry I can't help you.
Metaphor of Chooks
arrow1 ( ) posted Mon, 26 April 2010 at 12:45 AM
Many thanks.I sorted it out.Cheers
dphoadley ( ) posted Mon, 26 April 2010 at 12:49 AM
What extension should I put on that script.  Right now, I saved it as a .txt file in my Startup folder.
dph
RobynsVeil ( ) posted Mon, 26 April 2010 at 1:14 AM
The extension should be .vbs - it is a visual basic script... Windows Scripting will read and execute it when it sees it in your Startup folder.
If it's the first time running on your system, be prepared for a long boot session: it will look everywhere and clean up anything ending with .tmp and then tell you hold many megabytes it's found and deleted. Sometimes your AV sees it as something bad: tell AV it's okay. Hey, you have the source code: you can easily see it's not sending back details of your personal life to the mother ship. :biggrin:
Metaphor of Chooks
dphoadley ( ) posted Mon, 26 April 2010 at 1:31 AM
Quote - you can easily see it's not sending back details of your personal life to the mother ship.
It wouldn't matter anyway, as the Mother Ship would die of boredom!!!
dph
blf ( ) posted Mon, 26 April 2010 at 6:19 AM
I have used ccleaner which you can DL for free at www.ccleaner.com.
lmckenzie ( ) posted Mon, 26 April 2010 at 8:06 AM
Attached Link: CCleaner
You can also use CCleaner, which in addition to clearing out the temp folder cleans a host of  other detritus including (at your option) log files, chkdsk fragments, browser caches, and application specific temporary files like Photoshop, Flash, media players etc. You can also set it to run at startup and optionally  do a secure wipe of deleted files. Highly recommended.
N.B. A number of security folks recommend disabling the association for .vbs files to prevent malicious scripts from running. Your AV or other security software may  block execution of .vbs files also. If your system is set up to 'hide file extensions for known file types' (I think the default through XP at least), files like the infamous AnnaKournikova.jpg.vbs can appear to be innocent images or text files but in reality be malicious script code.
If you don't write or run script files often, it's not a bad idea to change the association so that .vbs files open in Notepad. You can still run them from a command line ex:
Wscript DeleteTempFiles.vbs
e.g  Wscript "C:MyApps DeleteTempFiles.vbs"
Put that command in a text file on your desktop and rename it to DeleteTempFiles.bat and you're still set with a convenient way to run it - or put the .bat file in your startup folder. I'm not sure if Vista/Win7 place any new restrictions on this stuff, as I too still run XP.
Just to clarify, the file Robyn posted is safe since she checked the code. Actually, safer than the stuff I write but I have only my own computer to destroy :-)
arrow1 ( ) posted Mon, 26 April 2010 at 6:19 PM
 Thank you everyone once again.I now have 7.15 gigs of extra space on my C: drive. Cheers
arrow1 ( ) posted Mon, 26 April 2010 at 6:48 PM
One thing I have noticed is that when I searched for .tmp or.temp files it found templates and textures everywhere.Are these temp files or the actual templates and textures connected with Poser etc? Cheers
RobynsVeil ( ) posted Mon, 26 April 2010 at 7:02 PM
They might be textures... as long as there is a .tmp or .temp after the name, they were generated by an untidy programme who doesn't believe in cleaning up after itself and are safe to get rid of.
Metaphor of Chooks
