Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
I think you can only export models that you imported as they are. I don't think the textures will go. The only full exports with textures are for Terrains and Lattices. Your mailbox will be exported with out the Bryce textures, thats only if you don't change it. Once you save it as an obp, it's no longer exportable, at least I think. This is one of the glaring deficiencies of Bryce, but maybe someday it will be a feature we get. I hope this helped a little. Good luck, kaom
KenS-no i didnt regroup it at all. the only change i did besdies addin the textures was move the flag from the left side to the right side. does anyone know anything bryce 5? maybe u can import obj in bryce 5? who knows. w/that mailbox i finally learned how to animate took me forever to learn that course i never really messed w/it too much either. if i somehow stumble across a way to export this or any obj i'll definaitely let yall know. thanx
Attached Link: http://home.pb.net/~stevecox/
you said the mailbox was in .3ds format, load it into bryce, and click the "E" to edit/smooth mesh, when that window is open, hit CTRL+D and saves as mailbox.obj and exit program. Load object into uvmapper then goto Edit/New Map/Planar and it will create a image map template. save the new object and the template. then open the template into a paint/photo program and add your textures. when you load the mailbox.obj in bryce, it will load your new texture map with it.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
ok i have tried thismany time & have had alot of u wonderfulpeople help me w/the the info in the past but still no luck. hey KenS maybe u can shed somelight on this. i downloaded a mailbox(the originalfiles is 3ds & has the "E" button beside it)i brought it up in bryce changed the color from gray to black & added a pic to the lid & the side of the mailbox. now my "modified" version doesnt have the E button beside it. is that because i modified it? then i went to the "Create" menu & saved "my" mailbox as an obp file. i brought the obp mailbox up & still no E button. is there anyway i can turn it into an obj file? i would like to upload the image here in renderosity. i think it looks really cool. ive got Dale Sr.'s #3 logo on the lid & the Dale Inc. logo on the side. If anyone can help i would really really appreciate it. thanx
