Mon, Jan 13, 2:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Out of Memmory Message
mach ( ) posted Fri, 21 May 2010 at 8:11 AM · edited Mon, 13 January 2025 at 8:38 AM
Hi,
 I'm getting an out of memory message when I try to render certain combinations of objects . I've encountered this issue once before on a previous computer and worked around it by increasing a parameter which I have since forgotten. Does anyone know how  to correct this issue? I.m using Poser 5 with Vista os and 4GB ram.
IsaoShi ( ) posted Fri, 21 May 2010 at 2:08 PM
Does Poser 5 have a render setting for Bucket Size?
If so, what Bucket Size are you using? Have you tried reducing it? This will reduce memory usage during the render.
mach ( ) posted Fri, 21 May 2010 at 2:42 PM
I've been using the Poser 4 Render option, but I'll try experimenting with the Firefly render engine which does have a bucket size.
Thanks
TrekkieGrrrl ( ) posted Fri, 21 May 2010 at 8:53 PM
 In the early Poser versions, "Out of Memory" doesn't always mean that it's ACTUALLY out of memory. It may also mean "I've encountered something i don't know what to do with. I give up" - like, for instance, a missing texture map. The later Poser versions (I think from 7 and above) has finally left that generic error message for something more actually fitting :)
mach ( ) posted Fri, 21 May 2010 at 11:33 PM
I  believe that your asesment  is probably correct. I increased the page file size but the Poser 4 render option still crashed. However the render works using  the firefly render engine on the same scene. I prefer the P4 render option to the firefly because it looks sharper to my eye.
