Fri, Feb 7, 1:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: texturing in poser help - Transporter Room
jedman67 ( ) posted Tue, 03 August 2010 at 11:47 AM · edited Fri, 07 February 2025 at 12:12 PM
I recently built a mesh in Max, but converting it to poser is giving me a challenge - namely, certain parts of the mesh are showing a tiled-texture which ruins the texture completely.
This is how it shows up in Poser 9:
 and this is how its supposed to look:
any assistance would be appreciated
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 12:11 PM
 It looks liek you may have doublesided polys there. Try adding a tiny amount of displacement to the back wall, like 0,01  with a noise node - that's too small to be seen but should fix the problem if it is caused by what I think it is :)
Nice transporter room btw ^_^
nruddock ( ) posted Tue, 03 August 2010 at 12:23 PM
Tick the "Normals_Forward" box on the "PoserSurface" node of any materials affected by this problem (the use of displacement is only required by P5 because this option isn't available).
jedman67 ( ) posted Tue, 03 August 2010 at 1:11 PM
 thanks. i think i just figured it out - i just needed to fix U/V scaling and offset. Problem is, changes only show up in render, which is annoying. is there a way to fix the preview so it reflects actual texture changes?
hborre ( ) posted Tue, 03 August 2010 at 1:45 PM
Online Now!
How are you plugging the textures into the PoserSurface?  You should see the changes in Preview if you are connected to Diffuse_Color.
nruddock ( ) posted Tue, 03 August 2010 at 1:54 PM
Quote - is there a way to fix the preview so it reflects actual texture changes?
No, the Preview can only reproduce a subset of what's possible with the shader nodes.
jedman67 ( ) posted Tue, 03 August 2010 at 2:21 PM
 the texture files are not changing - its the tiling that is.
jedman67 ( ) posted Tue, 03 August 2010 at 2:22 PM
Quote - > Quote - is there a way to fix the preview so it reflects actual texture changes?
thats annoying.
