Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Make a note of which sky you did use and then I would pick a different sky from the Terradome collection and render the image again to see what will happen. Most likely all of the black will be gone. There a one of two sky/light settings from Terradome that do cause this, I don't recall which ones. Whenever I encounter this problem with Terradome, it seems to me that the light is casting shadows from an object that isn't there, perhaps was left behind accidentely by the makers or a wrong setting used.
The other thing that could be going on is that the hills are casting shadows. For the light that casts the shadow , set the to a lower figure, like 0,8 and see that happens then.
If choosing a different sky will get rid of the problem, head over to RDNA and mention the problem. I think I've seen it brought up there before and they may have a solution for you.
Food for thought.....
Quote - A golfer's gopher would be called a caddy, right? :P
Ergo... remove the caddys.
SORRY!
The original poster is going to scream...If I was you I would ask Bill Murray how to get the grass render correctly. :crying:
Gary
