Sat, Feb 1, 5:18 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: Terradome problem
meltz ( ) posted Wed, 18 August 2010 at 9:44 AM · edited Sat, 01 February 2025 at 5:15 PM
Ok so i rendered this scene in terradome with the lighting and settings they say to use.  But see in the picture the ground and hills have these black holes almost all around. any idea how to get rid of them?
hborre ( ) posted Wed, 18 August 2010 at 10:09 AM
Online Now!
Could you screencap your render settings?
geep ( ) posted Wed, 18 August 2010 at 10:17 AM · edited Wed, 18 August 2010 at 10:20 AM
remove the ... gophers? :lol:
(sorry, couldn't resist)
cheers,
dr geep ... :o]
edited 10/5/2019
meltz ( ) posted Wed, 18 August 2010 at 10:25 AM
here are my render settings. The same as i always use for my figures.
meltz ( ) posted Wed, 18 August 2010 at 10:26 AM · edited Wed, 18 August 2010 at 10:27 AM
Miss Nancy ( ) posted Wed, 18 August 2010 at 2:10 PM
I can never remember if those are due to bad AO settings on materials.
geep ( ) posted Wed, 18 August 2010 at 2:17 PM
Try checking "Remove backfacing polys" and see what happens ... :blink:
Two sided polys present ??? (they usually render black)
cheers,
dr geep ... :o]
edited 10/5/2019
aeilkema ( ) posted Wed, 18 August 2010 at 3:39 PM · edited Wed, 18 August 2010 at 3:43 PM
Make a note of which sky you did use and then I would pick a different sky from the Terradome collection and render the image again to see what will happen. Most likely all of the black will be gone. There a one of two sky/light settings from Terradome that do cause this, I don't recall which ones. Whenever I encounter this problem with Terradome, it seems to me that the light is casting shadows from an object that isn't there, perhaps was left behind accidentely by the makers or a wrong setting used.
The other thing that could be going on is that the hills are casting shadows. For the light that casts the shadow , set the to a lower figure, like 0,8 and see that happens then.
If choosing a different sky will get rid of the problem, head over to RDNA and mention the problem. I think I've seen it brought up there before and they may have a solution for you.
Food for thought.....
Tessalynne ( ) posted Fri, 20 August 2010 at 3:57 PM
If you uncheck cast shadows in the properties for the ground objects it should eliminate the black spots.
Pengie ( ) posted Fri, 20 August 2010 at 5:55 PM
Quote - remove the ... gophers? :lol:
If he removes all the golfers, who's gonna pay the grounds fees?
geep ( ) posted Fri, 20 August 2010 at 8:17 PM
Gophers ... GOPHERS .............. not golfers ............ sheeeesh ... :lol:
You know ... 4 legged critters .... not 2 legged critters. :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
YngPhoenix ( ) posted Sat, 21 August 2010 at 1:18 AM
meltz, just curious to hear if any solution was found. I've been trying to recreate it but no luck.
Silke ( ) posted Tue, 31 August 2010 at 4:44 PM
A golfer's gopher would be called a caddy, right? :P
Ergo... remove the caddys.
SORRY!
Silke
grichter ( ) posted Tue, 31 August 2010 at 5:55 PM
Quote - A golfer's gopher would be called a caddy, right? :P
SORRY!
The original poster is going to scream...If I was you I would ask Bill Murray how to get the grass render correctly. :crying:
Gary
