Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 11:21 pm)
Quote - If you have downloaded recently, you should already have the install files. They are located in the AIR subdirectory. There is a readme.txt there, which i would suggest reading first. Pay attention to the file it will ask you to locate.
Thanks, found it.
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Im so glad some of the productive members of the Poser community are looking into a physically based renderer exporter script directly from poser. Ive been hoping for this option for quite some time now. Thanks guys for your passion of 3d rendering, and generosity that us less technically inclined can enjoy such fun tools with tons of buttons and dials to keep us busy for years.
Just wanted to say thanks, Im not at all productive around here. Sorry!
OK, when installing LuxPose when Asked I msitakenly selected the wrong .bbml file.
I have Uninstalled LuxPose several times and tried reinstalling it with No Joy. I get this error:
onInvoke:
--------- FATAL ERROR -------------
Unknown command:
schema
Understandable knowing I selected the wrong file.
I already had Air installed for a few other things, so I do not think i should uninstall Air.
How do I correct the error of my installation and install it correctly?????
TKS
"That government is
themselves."
Thomas Jefferson
Quote - OK, when installing LuxPose when Asked I msitakenly selected the wrong .bbml file.
onInvoke:
Unknown command:
schemaUnderstandable knowing I selected the wrong file.
TKS
I have the same error sometimes. Don't know why. After several rage attacks I deleted the complete AIR folder and installed again from the original ZIP.
That worked (for a while).
If you look in
C:Documents and SettingsApplication Dataorg.LuxPose.LuxPose.CDC95EB2C8653080C2311EFF475397535E851155.1
or something like that, you can just delete that folder and it will ask you again the next time you run it.
I don't know how you have solved some problems if were solved. I found Lux materials very incomplete and lacking of many useful features, at least in version 0.7.
The problems that I found are:
1- Transparency is very tricky and doesn't work properly. The only way that I found is using the mix and null materials. Setting an amount of transparency it works, but when I try to use a transparency map for the amount nothing happens.
2- For a simple diffuse and specular textures and a transparency map that doesn't work I have to create a lot of intermediate textures and materials and do a lot of tricks.
And I haven't tested bump maps yet and... displacement... forget it.
3- The lack of ambient color in Lux materials. The only way to do is to use a light as emisive material, but as LuxRender people says it takes more time to render emisive polygons.
Replacing the ambient color by a light can be very good, but to be useful it need a transparency map applied to the light surface and no way to do this.
4- I tested a simple scene with a big square and a ball behind and the glass and translucent material doesn't work no matter how I change by hand the parameters.
Don't worry, nobody here is guilty of anything, Poser works fine and without problems.
Stupidity also evolves!
Quote - If you look in
Thank You BB!!
problem solved and cure Saved, even though I now see the location was shown during the initial installation.
Cheers
DR
"That government is
themselves."
Thomas Jefferson
Ok, for my setup now it's clear why I get this error sometimes. The contained permanent link contained there does not always exist on my setup. I switch my Wine-installation from one disk or path to another sometimes. My virtual Windows I use for compatibility testing is using completly other drive-letters. Now I set a softlink to this file and anything should be fine.
Thanks, BB!
If transparency doesn't work in Lux, who the hell did they do it in Blender????
Tip: Forget about the tricks you learned for Poser to get "realistic glas". Read the Lux faq and forum. Have a look at the predefined Lux materials.
It's not easy. But it is possible.
This reminds me: from the scene file description, it looks like displacement is done in the mesh, not the material. That makes sense to me, since displacement does in fact change the shape of what is rendered. I don't quite understand the details yet, but it seems that one has to specify a subdivision level as well for the displacement to take effect. If that's in fact the case, that would mean that the higher the level, the more details one would get.
I suspect that once everything's ready, we can simply feed the appropriate displacement 'texture' generated by BB's material conversion into this. All I need is an extra method call to get it out of the converter class.
Quote - Tip: Forget about the tricks you learned for Poser to get "realistic glas". Read the Lux faq and forum. Have a look at the predefined Lux materials.
I am not speaking about Poser and its tricks, I am speaking about LuxRender and LuxRender is not physically correct.
When a ray of light hits a trasparent object, one part of the energy is reflected, other part is refracted and a third is absorbed. You have three color parameters and LuxRender only has two, kr and kt, so it never can be physically correct..
Quote - If transparency doesn't work in Lux, who the hell did they do it in Blender????
I only want to know how it is done.
I want a material with a diffuse color, a texture and a transparency texture applied to the diffuse color. I also want the specular color with some color, withor without a tetxure map, but no transparency applied to the specular component.
It's a simple glass material where the transparency is used to create a micro geometry.
If this material do exist and works I will be very happy to see how was done and learn something new.
Only need a lxm file with only this material.
Once you have specified what gets reflected and what passes through, whatever remains must be what gets absorbed. So you only need two parameters.
Quote - This reminds me: from the scene file description, it looks like displacement is done in the mesh, not the material. That makes sense to me, since displacement does in fact change the shape of what is rendered. I don't quite understand the details yet, but it seems that one has to specify a subdivision level as well for the displacement to take effect. If that's in fact the case, that would mean that the higher the level, the more details one would get.
Of course that it can be done in the mesh, but the purpose of displacement maps is lost.
Displacement map were invented just to give a geometry tiny details without the need of using a lot of polygons for these details.
A geometry with fine details will be much correct than using displacement maps that are only a trick, but a mesh of 50k polygons will turn into a million polygons mesh.
Quote - > Quote -
You just forgot the energy that is turned into heat, and plants also use this energy for other things and human skin turns UV energy in vitamin D and so on...
And a black object? Light goes in and nothing goes out.
Quote - > Quote - This reminds me: from the scene file description, it looks like displacement is done in the mesh, not the material. That makes sense to me, since displacement does in fact change the shape of what is rendered. I don't quite understand the details yet, but it seems that one has to specify a subdivision level as well for the displacement to take effect. If that's in fact the case, that would mean that the higher the level, the more details one would get.
Just to be clear: you don't have to pass a mesh with a million polygons to Lux. You pass in the 50k mesh and your displacement map, and it generates the finer mesh internally (or so it looks, but I may be wrong). Every renderer that does displacement correctly has to have some kind of internal representation of a refined mesh with displacement applied.
Anyway, I may be misunderstanding what Lux does, so it makes no sense to discuss this further until I do.
Quote - Just to be clear: you don't have to pass a mesh with a million polygons to Lux. You pass in the 50k mesh and your displacement map, and it generates the finer mesh internally (or so it looks, but I may be wrong). Every renderer that does displacement correctly has to have some kind of internal representation of a refined mesh with displacement applied.
But if polygons are created internally they must be rendered, so in the end it will render one million polygons and not 50k.
Displacement maps, bump maps, transparency maps and even texture maps are tricks to give good visual image while keeping the number of rendered polygon low.
Quote - > Quote - > Quote -
These are the properties for glass surfaces, a bit more than 2.
name description
glass::Kr The reflectivity of the surface
glass::Kt Fraction of light transmitted through the surface
glass::index The index of refraction for the glass surface
glass::cauchyb Cauchy B coefficient
glass::film The thickness in nanometers of the thin film coating (0.0 disables) on the surface
glass::filmindex The index of refraction of the thin film coating on the surface
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 -
Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD
4670 - 256 MB
Don't cry loud until you are really sure ...
Your missed parameter for refraction is called "index" (Index Of Refraction). And there are 3 more parameters. "couchyb" and 2 for a "film" - effect.
Kawecki, to be brutally honest - everytime you show up and start to open your mouth I get nervous.
If you wanna moan and complain that this or that or the other thing isn't physically correct, maybe you could go someplace else. All it does is start arguements and pisses off one programmer in particular who - quite frankly - we need in order to accomplish this plugin.
I've heard PoserPros is lovely this time of year.
Of course that a glass or any surface has much more parameters, but the three basic are not present, only two.
Well, for glass the refraction index is also a basic parameter, so from the basic four only exist three.
I only want to do something like this, the fire is nothing more than a plane with ambient color and color, texture and transparency map applied to the difuse channel.
Has any rendered in Lux Vicky4 with hair that has transparencies?
Quote - If you wanna moan and complain that this or that or the other thing isn't physically correct, maybe you could go someplace else. All it does is start arguements and pisses off one programmer in particular who - quite frankly - we need in order to accomplish this plugin.
I only want to know how to do transparencies, anyone can help me?
Quote - Has any rendered in Lux Vicky4 with hair that has transparencies?
Not yet, but I've rendered ivy made with the ivy generator that sure had a lot of leaves, each one layered on the other and each leaf with transparency.
Are you sure you even know what you're talking about? Or are you just trying to stir up trouble?
I've gotta wonder. Sorry.
Quote - > Quote - If you wanna moan and complain that this or that or the other thing isn't physically correct, maybe you could go someplace else. All it does is start arguements and pisses off one programmer in particular who - quite frankly - we need in order to accomplish this plugin.
But it all (my ivy with leaves) exported out of Poser to Lux with the exporter intact? What do you need help with? So far as I've tested, ambience is not working yet, but transparency maps sure do.
Quote - But it all (my ivy with leaves) exported out of Poser to Lux with the exporter intact? What do you need help with?
If the leaves use a transparency map, just copy with a text editor the part of the leave material from the lxm file, post it here or send me an internal email and I can you give my email.
Quote - > Quote - These are the properties for glass surfaces, a bit more than 2.
Well, for glass the refraction index is also a basic parameter, so from the basic four only exist three.I only want to do something like this, the fire is nothing more than a plane with ambient color and color, texture and transparency map applied to the difuse channel.
By the way: You are looking for alpha-maps, not transparency.
Quote - > Quote - So far as I've tested, ambience is not working yet, but transparency maps sure do.
Laurie,
ambient light will not work at all. We use area-lights for things like this (those lights having a geometry).
Well, I was looking at his fire plane ;o). I know how I'd do it in Poser, but not Lux I'm afraid.
Quote - > Quote - But it all (my ivy with leaves) exported out of Poser to Lux with the exporter intact? What do you need help with?
Yes, adp is right. The leaves transparencies are just an alpha map, applied in Poser....converted over to Lux just fine. White includes, black drops out.
Quote - Well, I was looking at his fire plane ;o). I know how I'd do it in Poser, but not Lux I'm afraid.
If would be possible to turn the ambient color into a light the fire could illuminate the walls with the fire's shape. This would be much better than Poser!!!!
And I have a lot of dungeons to illuminate....
Quote - [
name description
Couldn't the film effect be useful to fake SSS?
It's really very simple: absorbed = total light - reflected - transmitted.
Example, 5% is reflected, 80% is transmitted, then 15% is absorbed.
If you follow this link you'll see a Luxrender I did with a few glass objects. [http://www.renderosity.com/mod/gallery/index.php?image_id=2099188
](http://www.renderosity.com/mod/gallery/index.php?image_id=2099188)
Pose2Lux
4670 - 256 MB
Quote - > Quote - Well, I was looking at his fire plane ;o). I know how I'd do it in Poser, but not Lux I'm afraid.
Yes, this works terrible good! We need a nice image with fire here ;)
One thing: Have a look into the Lux docs. They are talking about "achitectual glass". It renders faster, because it has no refraction.
They are discussing - or I thought so - how to make a mesh object a light object, which would work nicely (I would think) for something like your brazier object.
Quote - Quote - " Quote - "By the way: You are looking for alpha-maps, not transparency."
alpha map = transparency map
No, Sir. Not really.
Which is the difference?
Quote - It's really very simple: absorbed = total light - reflected - transmitted.
Not so simple, of the 15% absorbed how many turned into diffuse light and how many was transformed into heat, light outside the spectrum internal energy and other energies.
If you follow this link you'll see a Luxrender I did with a few glass objects. http://www.renderosity.com/mod/gallery/index.php?image_id=2099188
Maybe could be interesting to see how glas comes out with area-light. You just have to scale your pointlight in Poser to a high value (I used 1000). Because the light is round then, the shadows are very smooth and perfectly "real".
Quote - > Quote - Quote - " Quote - "By the way: You are looking for alpha-maps, not transparency."
Alpha is a sort of "stamp out". A transparency object can drop shadows and reflect light. Think about a hole in a window. The window is transparent (but with reflection/refraction). The hole is "stamped out" with an alpha-mask.
I replaced the infinite light in Poser with the sun and sunsky setting from the example lux file included with LuxRender. I left the position as it was.
I like the lighing in this and the shadows as well, but I am having that problem with "fireflies" and I have no idea what that bright line is up the right side of the diagonal piece of the building with the doors. If you look behind the planter on the right side of the door it's where it's most noticeable.
I had to shrink this to get it small enough to upload, but the fireflies and that line are very noticeable on the larger image.
Rendertime: 9 hours.
Quote - [
You can see if it is down while defining a point light in Poser. Export. In the lxo file -on top- the lights are defined. A pointlight is actually converted to an area-light with a "build-in" primitive geometry from Lux named "sphere".
# start light "Light 2"
AttributeBegin
TransformBegin
Translate 1.90746486187 190.746490479 19.0746498108
AreaLightSource "area"
"color L" [1.0 1.0 1.0]
"float gain" [0.639999985695]
<span style="color:rgb(255,153,0);">Shape "sphere" "float radius" [0.0654069767442]</span>
TransformEnd
AttributeEnd
The shape-statement can be replaced with any other geometry.
Quote - > Quote - [
# start light "Light 2" AttributeBegin TransformBegin Translate 1.90746486187 190.746490479 19.0746498108 AreaLightSource "area" "color L" [1.0 1.0 1.0] "float gain" [0.639999985695] <span style="color:rgb(255,153,0);">Shape "sphere" "float radius" [0.0654069767442]</span> TransformEnd AttributeEnd
Interesting ;o).
Transparency maps are not transparency even are related.
A transparent object has a fixed value on how much it is transparent, a transparency map is a RGB image that modulates this transparency value, so it can turn the object more or less transparent by pixel value.
Strictly alpha maps are not the same as transparency maps, alpha maps only modulate the overall transparency for all colors. A transparent map can modulate each RGB component.
Poser only use alpha maps.
Example, 5% is reflected, 80% is transmitted, then 15% is absorbed.Not so simple, of the 15% absorbed how many turned into diffuse light and how many was transformed into heat, light outside the spectrum internal energy and other energies.
While that might be important in real life for biology, physics, etc..
It will not matter much when creating an image, you won't feel the heat, your leaves won't be synthesizing sunlight, you won't be imaging ultraviolet or infrared. ;)
So the equation will be close enough for image rendering.
Pose2Lux
4670 - 256 MB
Quote - Transparency maps are not transparency even are related.
Ok, I don't think it helps to argue what exactly what does what and why. It just turns into a pissing contest. For the sake of this plugin, we're going with what Poser uses and that's an alpha map, ok? I don't care one wit how it does what it does or the difference between. The image used to calculate transparency on the leaves in my image was a plain old, run of the mill alpha map. Just black and white. And it converts to Lux just the way it should. That should be the end of it.
Quote - While that might be important in real life for biology, physics, etc..
It will not matter much when creating an image, you won't feel the heat, your leaves won't be synthesizing sunlight, you won't be imaging ultraviolet or infrared. ;)So the equation will be close enough for image rendering.
It will depend on the physical properties of the object. For a silver mirror or a good quality crystal glass the image error will be insignificant, but if you deal with a plastic you are in trouble.
Of course for Poser or Vue users the error will be also not so important, after all we don't care too much with Phong that is physically wrong.
Yes I did.
