Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Sep 29 9:12 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Thanks tantarus. So that's what the 'View>Background Image' is for! I already had a reference photo, but hadn't realised I could actually set it to appear in the modeler - doh!
I'm very interested in your 'too dense a mesh' comment (please bear in mind that I am still a relative novice!). There are 1664 faces - each sphere for my starting point had 16 rings of vertices, with 32 vertices in each ring. This seemed to me, at that time, the minimum needed to get a good enough 'roundness' on the pawn, while allowing enough flexibility to manipulate the shape into the other pieces.
But looking at the result I see your point. If I was to remodel from scratch (maybe I will, maybe I won't!) what sort of face count (or number of rings/segments for the spheres) would you suggest?
Also, since the very top of the pawn became the tip of the knight's nose, the faces all converge, making the mesh even more dense here. Maybe I should slide some of the edge loops back from the nose area to the eye area? This would perhaps give me the extra faces I need to model the eye?
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
Starting with a primitive is so called "box modeling", but start with very low poly. Egg 8 sided cillynder, 8 sided sphere, default cube, etc. Move points around and get general shape, dont worry about smoothnes and details at that stage. Just get proportions and general shape. Gradually add loops with Knife tool only where needed, and again move points to get volume. Look model from all angles all the time, as what look good from one side looks totally odd from another side. After you have low poly base, subdivide it. Most apps have control cage, meaning you only need to tweak that points from low poly and its shaping the hi poly preview. SubD will smooth allot of areas that need to be defined, so add loops where needed to control the smoothnes. This is just rough explanation, but there is allot of tuts. on the net.
Open your mind and share the knowledge!
Tantarus - thanks again. I've read, and been given similar advice many times, but I seem to have a problem in actually following it! I still end up with overcomplicated meshes. You wouldn't believe how long it's taken me just to get this far, so I won't remodel from scratch - I think I'll follow your initial advice about tweaking the shape to match a reference image.
Airflamesred - "Is there any reason behind the morph route?" - it was just an idea I had. There are hundreds of free chess piece models available (far better than I could hope to make at present). But no morphing ones, at least none I could find. So I thought, "why not give it a shot?".
The real problem is therefore creating a single mesh that is capable of being transformed into any of the six chess pieces. The rook's castellations and the queen's crown effectively set the minimum number of vertices around the model's circumference, and I knew the knight was always going to be the biggest problem.
I suppose I could have started by modelling the knight and then trying to morph it to get the other pieces, but that seemed even more awkward.
(btw - my DAZ thread on the same issue if here http://forum.daz3d.com/viewtopic.php?p=2507837)
Thanks again Tantarus/AirFlamesRed - this seems a much better approach. I have plenty more WIPs that I'll take a fresh look at now as well!
As this is for practice, I would actually use the 128-face sphere topology as is and try to shape it into a very stylized knight. Forget about details, just go for basic recognizable shape. I think that might actually be a very good kind of exercise for beginners: take a fixed, very-low-polygon topology and see what you can do with it.
Or since the sphere has these annoying poles at the top and bottom, maybe you could use a cube and subdivide it twice, which would give you 96 faces.
odf - I like it. Fits with tantarus' "...Find some other theme to model and start with low poly..." idea too. But I also find that deciding (and posting my intention) to release a model as a freebie does wonders for focussing my mind - and it does need focussing!
I think I'll split this project into two: a basic morphing chess piece for release as a freebie (using the two spheres, plus an extra cylinder primitive for the base) by the end of this month; and a "let's see what I can make out of a 96 face cube" project.
( btw - it didn't take me 14 days just to do that! )
Anyway, I've decided to use the 96-polygon cube as the basis for the morphing chess piece. The outline in the previous picture is too angular, so I need to round that off a bit. And I reckon that I need some more faces to define the ridgeline where the horses chin and lower jaw tuck into the neck (I think I've just realised one of the purposes/uses of edge loops, and I don't have one there).
Plus I need to bear in mind that I'm modelling a pawn, bishop, rook, queen and king from the same mesh, and each of them will need more detail but in different areas. This has turned into an intriguing exercise for me.
The upshot of all this is that the morphing chess piece will be delayed (i.e. not released by the end of September), but will hopefully be a better model.
Tantarus - thanks for the positive comment*. I think I'll do as you suggest, and develop the morphing version separately (but using this as the base).
Yes, a good lesson in "less is more", or "Keep It Simple, Stupid!"
Regarding the MORPHING chess piece (which is still my ultimate goal here). I obviously can't use the knight texture map, so a single texture/bump/displacement map will have to work for ALL SIX chess pieces.
But since I now have a very simple base mesh, a few extra faces to add detail for each piece seems a good solution. I'll post the results back here soon.
As always, constructive criticism is very much appreciated.
*the knight actually has an extra horizontal edge loop near the base that I forgot to remove.
Now completed and released as a freebie here http://www.renderosity.com/mod/freestuff/details.php?item_id=61836
I'd love to know what people think of it.
Because this is a morph from my basic chess piece (the pawn) I can't add/delete any vertices - I've got to model it from the faces I've got - basically a sphere on top of a sphere on top of a sphere on top of a cylinder (with spurious faces/edges/vertices deleted and appropriate vertices merged to get a single closed surface). So obviously there are no nice edge loops associated with the mouth, nose, eyes or ears. I don't think this is an issue as I don't plan for the knight to animate - it's just an end-point for a morph.
There obviously need to be sufficient faces in the appropriate areas to model the detail of the horses head. I've played around a bit with the nostrils, mouth, and ears, and I think I have the general approach for these, although more work is obviously needed. But I don't think I've left enough faces to model the eyes (which I plan to do in a similar way to the nostrils).
Any advice, ideas or suggestions would be most appreciated, as always!
P.S. I know models of chess pieces are ten-a-penny, but this is mainly another learning exercise for me, a bit of modelling and morph creation practice. And as long as it ends up half-way reasonable it'll be released as a freebie.
P.P.S I'm posting this on both DAZ and Renderosity forums.
