unbiased engines are intended for photo realistic simulation of Light
Toon renders should be done in other biased special effects renderers.
Cheers
Quickie dumb question (I'm due for one...lol):
Firstly, I'm not having much luck getting HDR images to show up in Luxrender with the newest LuxPose build, even though the .lxl file is linking to it.
Secondly - I've made some really nice skies in Vue and Bryce. Is there any way we can, say, use a .bmp image for the sky rather than an .hdr? Inquiring minds wanna know ;o).
Quote - Quickie dumb question (I'm due for one...lol):
Just to make sure it works: Can you please use an HDRI delivered with Poser?
Maybe the images you whant to use aren't the right format.
Yes, you can use LDRI also (Low-Dynamic-Range-Images). But probably you have to use additional light in your scene, because a LDR image commonly has not enough "energy" for good contrast.
Quote - > Quote - Quickie dumb question (I'm due for one...lol):
Maybe the images you whant to use aren't the right format.Quote -
Secondly - I've made some really nice skies in Vue and Bryce. Is there any way we can, say, use a .bmp image for the sky rather than an .hdr? Inquiring minds wanna know ;o).Yes, you can use LDRI also (Low-Dynamic-Range-Images). But probably you have to use additional light in your scene, because a LDR image commonly has not enough "energy" for good contrast.
I did use an HDRI from Poser adp...sorry, I forgot to mention that.... I used the Pond scene. While the .lxl file was linking to it, it didn't render in Luxrender. All I got was a blueish sky. I'm not sure what I'm doing wrong...hehe.
Which version of Vue do you have Laurie ? I'm pretty sure that at least infinite can export as a .hdr image if you turn off all the post processing options
My Freebies
Buy stuff on RedBubble
I did use an HDRI from Poser adp...sorry, I forgot to mention that.... I used the Pond scene. While the .lxl file was linking to it, it didn't render in Luxrender. All I got was a blueish sky. I'm not sure what I'm doing wrong...hehe.Laurie
Please look into the *.lxs file for "premultiplyalpha". Set this to "false" if it isn't.
Make sure there is no other light like sun or sky in your *.lxl file.
Quote - Which version of Vue do you have Laurie ? I'm pretty sure that at least infinite can export as a .hdr image if you turn off all the post processing options
I have lowly version 4....lol. Well, that and Vue 8 Pioneer - the free one. I haven't looked at Pioneer for options yet as I think it puts a watermark or logo or something on the resulting image, which is something I don't want ;o).
Weapons of choice:
Quote - Seems my problem was the metal bars behind her kept throwing all sorts of light sparkles everywhere. After the 3 and a half hours I decided I could post out some of the sparkles and call this one done.
I think you should lower the intensity of this bars. Setting the reflection values to high produces too mutch energy and therefore new lightrays. Even chrome does not 100% reflect.
I only have the one formula for silver, graciously given by LaurieA. I do not know how to change the values or what to change it to.
Weapons of choice:
#-----> ball_1/Preview <-----
MakeNamedMaterial "ball_1/Preview" "string type" ["metal"]
"string name" "amorphous carbon"
"float uroughness" [0.025]
"float vroughness" [0.025]
#-----> ball_2/Preview <-----
MakeNamedMaterial "ball_2/Preview" "string type" ["metal"]
"string name" "gold"
#-----> ball_3/Preview <-----
MakeNamedMaterial "ball_3/Preview" "string type" ["metal"]
"string name" "silver"
#-----> ball_4/Preview <-----
MakeNamedMaterial "ball_4/Preview" "string type" ["metal"]
"string name" "copper"
#-----> ball_5/Preview <-----
MakeNamedMaterial "ball_5/Preview" "string type" ["metal"]
"string name" "aluminium"
#-----> ball_6/Preview <-----
MakeNamedMaterial "ball_6/Preview" "string type" ["metal"]
"float uroughness" [0.1]
"float vroughness" [0.1]
Don't forget to set Catmul-Clark subdivision to at least 1 for low-res props if you use glossy materials on them.
Copied to a Word document, thank you! Yeah, if only my computer would render something like that in Lux in 15 minutes.....
Weapons of choice:
Strange thing ...
I tried something similar to adp's latest render with the different ball materials.
I loaded some balls into a poser scene and created a Diffuse IBL light.
In the MAT.Room I connected an Image_Map to the Color node of the Light. As image I used the Pond HDR file that came with Poser.
I then exported the scene with LuxPose 1.30a and got this Error Msg. in LuxRender:
There was an error while checking the size of file 'H:ProgrammeSmith MicroPoser Pro 2010RuntimeTexturesHDRVFXHDRVFX_pond_01_v_002.hdr'
Unable to open image file 'H:ProgrammeSmith MicroPoser Pro 2010RuntimeTexturesHDRVFXHDRVFX_pond_01_v_002.hdr'
Back in Poser I ran the "TextureReferences.py" and got this:
all texture references:
wrong references:
wrong after resolving tried:
As if the image just isn't there, even tho I can see being connected to the light in the Mat.Room.
Am I doing something wrong here?
I saw a similar error last night about the size of the hdr image. I just deleted my IBL light and re-exported figuring someone will fix the error soon.
Weapons of choice:
Quote - I saw a similar error last night about the size of the hdr image. I just deleted my IBL light and re-exported figuring someone will fix the error soon.
Seems we have 2 problems.
First, LuxRender has some problems after several re-loading of scene files. Just restart to fix it.
Second, Poser before 8 has it's own understaning of how to handle referenced imagefiles :)
The exporter does nothing more than asking Poser for a path/filename. No chance to work sometimes and sometimes not.
I keep all my V4 and M4 textures in a special runtime in my external drive. The current Luxpose versions have had no problem with this. The HDRFX folder is within Poser 8 on my C drive, so the exporter not seeing the path to the hdr image should not have been a problem. I should have copied the error message and saved it, but it did have something to do with the size of the HDR image, not it's location. If it is in regards to the focal length of the hdr image and my Poser scene, well then I guess for the moment, I'm not using IBL on export because I render at no lower than 38mm for my camera in Poser. Anything below 38mm is too distorted. I also now use very low level IBL lights with no attached image in Poser, and I don't believe that is supported at the moment on the Luxpose exporter.
Weapons of choice:
i've had that idl-path problem too (same hdr & same size error message) & changing the backslashes to double-backslashes usually fixes it so lux can find the hdr. don't have to do that for normal textures, so i don't know what's going on or why that works.
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
@LaurieA
Cool! Just glad that I figured out how to add to the wiki so other people that aren't diligently following the thread can quickly find these things.
@jancory
Oh, changing them to double slashes will work? Interesting.
You know, I always knew there'd be a reason I kept most of my Poser 4 runtime intact. I'm setting up a scene now with a DM Productions scene and converted some lovely armor by Lory to use. Will see how this turns out. At the moment, Luxpose likes P4 style textures, then I go into the material file and edit in other things like metals that have been posted. I'm going to try the gold posted by ADP.
Weapons of choice:
Quote - i've had that idl-path problem too (same hdr & same size error message) & changing the backslashes to double-backslashes usually fixes it so lux can find the hdr. don't have to do that for normal textures, so i don't know what's going on or why that works.
That's interesting. Did you try to replace the (single) backslashes with (single) slashes? I'm using LuxRender with Linux, so I can't test it by myself.
I wish the exporter kept the set intensities of the Lights from Poser. When I get a scene into Lux, I have to turn the light groups down.
Weapons of choice:
Quote - I wish the exporter kept the set intensities of the Lights from Poser. When I get a scene into Lux, I have to turn the light groups down.
You can (have to) set "Sensivity", "Exposure" and "FStop" to values a real camera would need for your scene. If you found a set you need for your typical image, you may set your values as the default ones (dataOut.bbml).
No need to push lightgroups down except to finetune.
Note: Lux handles light different than Poser. Exporting light 1:1 is not easy - and probably not what you want. If you're after a Poser-look, render with Poser.
single forward slash worked; just checked it.
i just ran a quick test on an antonia & the textures all loaded ok in lux with single slashes. i'm running Windows XP.
Weapons of choice:
Ran into a problem in Poser 6:
Traceback (most recent call last):
File "", line 203, in ?
File "C:Program FilesPoserLuxExporter_alpha_1-30cworkersPoserLuxExporter_workers.py", line 62, in ?
from BBLuxMat import MatConverter, clearCache
File "C:Program FilesPoserLuxExporter_alpha_1-30cworkersBBLuxMat.py", line 61, in ?
reload(luxmatic.matcore)
AttributeError: 'module' object has no attribute 'matcore
Seems to work perfectly fine in Poser 7 though.
Rendered on a lowly AMD Turion 64 1.8Ghz CPU with 1.406GB of available memory WinXP 32 bit laptop with 256 S/px after 6 hours and 40 minutes.
I just tried jancory's tip, of using double-backslashes.
With this, it works for me, too.
Before I had an error msg in LuxRender, saying:
After altering the path, in the *.lxl file, from: ["H:ProgrammeSmith MicroPoser Pro 2010RuntimeTexturesHDRVFXHDRVFX_pond_01_v_002.hdr"] to ["H:ProgrammeSmith MicroPoser Pro 2010RuntimeTexturesHDRVFXHDRVFX_pond_01_v_002.hdr"] I get the following msg. in LuxRenders log:
"Loading FreeImage Texture: 'H:ProgrammeSmith MicroPoser Pro 2010RuntimeTexturesHDRVFXHDRVFX_pond_01_v_002.hdr'"
And all is working perfectly.
Sometihng "steals" a backslash, during the export =)
Updated Version 1.30d
Pathes now all changed to forward slashes.
To make CC-subdivision more useful, I added seperate scripts to the utility folder:
addParameters2CurrentActor.py
Adds parameter dials to the currently selected prop.
addParameters2AllActors.py
Adds parameter dials to all props in a scene.
Additionally there is a script to delete the parameters: deleteParametersFromAllActors.py
Important note: This parameters are only used if the subdivision-level in dataOut.bblm is set to 0.
I'm getting this error when I run the script:
File "D:e frontierPoser 7RuntimePythonposerscriptsPoserLuxExporter.py", line 219, in ?
ExportFilm(globalParameters).write(f)
File "D:e frontierPoser 7RuntimePythonposerscriptsworkersPoserLuxExporter_workers.py", line 570, in write
if pFilm.hybrid.strip() == "true":
AttributeError: 'NoneType' object has no attribute 'strip'
