Need a material for a Halloween pic I'm thinking of trying in Lux. I'm going to use a melty, drippy candle, either red or black. What Lux material formula would I use for candle wax? And how would I do the candle flame object? I don't absolutely have to light this particular candle, but if I were to???
Weapons of choice:
For candle wax I guess one of Laurie's gel materials, change the colors and glossiness, should look good.
Small point light for candle flame? See this image where I used a scaled down point light.
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 -
Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD
4670 - 256 MB
I stopped the render when I realized the textures had somehow not gone through.
Weapons of choice:
Weapons of choice:
Another possibility to consider, aside from turning the flame itself into a mesh light, your best bet would be to set it to emit light from by modifying it's material and exported geometry, detailed a bit on the LuxRender wiki.
What's interesting is that having an object emit light instead of being a full blown mesh light is that the scene appears to render much more quickly than the norm and the scene still receives light from the said object. Sadly, since that sort of functionality has not been implemented in LuxPose, you'll have to hand edit each flame object emitter mesh and and it's assigned material. Possible example as follows:
<em>Add this after the NamedMaterial section for your light
emmitter:<br></br>
LightGroup "flame"<br></br><br></br>
AreaLightSource "area"
"texture L" ["Flame:light:L"]<br></br>
"float power" [2.000000]<br></br>
"float efficacy" [20.000000]<br></br>
"float gain" [1.000000]</em>
You'll need to play with those settings to see what works for your scene, then add something similar to the following after your generated material for that object:
<em>Texture "Flame:light:L" "color"
"blackbody"<br></br>
"float temperature"
[6500.000000]</em>
If you want to be able to able to control each individual flame, you'll obviously need to change each one's LightGroup name. Also, you don't need to add anything else to your exported lights file (.lxl) as it's not a real light, per say. Again, I also highly recommend that the object is textured and, possibly, transparent for a more interesting effect.
Quote - Updated Version 1.30d
Pathes now all changed to forward slashes.
To make CC-subdivision more useful, I added seperate scripts to the utility folder:
addParameters2CurrentActor.py
Adds parameter dials to the currently selected prop.
addParameters2AllActors.py
Adds parameter dials to all props in a scene.
Additionally there is a script to delete the parameters: deleteParametersFromAllActors.py
Important note: This parameters are only used if the subdivision-level in dataOut.bblm is set to 0.
Any chance that you took a look at the Poser 6 error from earlier and made a fix? If not, is it simply possibly that by being outside of the python folder for Poser 6's runtime that it can't import the necessary files to function?
Quote - Any chance that you took a look at the Poser 6 error from earlier and made a fix? If not, is it simply possibly that by being outside of the python folder for Poser 6's runtime that it can't import the necessary files to function?
Yep. But I need your help because I don't have P6 installed.
I've updated the current package (same version-number). Can you please try if the error still occurs with P6? If yes, start "tellSysPath.py" from the utility folder and post the output, please.
Quote - Yep. But I need your help because I don't have P6 installed.
Well, if I leave it outside the Poser 6 directory, say C:Program Files, I get the same issue. Here are the results of tellsysPath.py:
After that, I tried copying and pasting it into the Python runtime folder(s) to see if it changed any by moving it and got the following:
I guess whether it's in the runtime folder or outside of it, there seems to be some sort of problem for Poser 6. Not really sure what else could be causing it.
Ok now I have a problem. I only downloaded luxrender and the plugin for poser last night, but the render takes too long. I setup the scene in poser and imported it into luxrender. I put in on linear tone mapping and didn't change anything else. It was a simple portrait so i watched it render. It took so long I decided to go to bed and when I woke up it didn't change very much, mostly loads of dots no texture only the form of the face and it was still rendering. This is about 8 hrs.
Am I doing something wrong? What setting should I use. In poser I used one of BB's lights he included in his Vss shader folder. An indoor one. Nothing else!
Quote - Ok now I have a problem. I only downloaded luxrender and the plugin for poser last night, but the render takes too long. I setup the scene in poser and imported it into luxrender. I put in on linear tone mapping and didn't change anything else. It was a simple portrait so i watched it render. It took so long I decided to go to bed and when I woke up it didn't change very much, mostly loads of dots no texture only the form of the face and it was still rendering. This is about 8 hrs.
Textures are not converted yet, because BB is too busy to work on this. What works are only simple textures (P4-style). This is not a real problem, because LuxRender does not need complicated textures.
Regarding to your light: Don't know how you set up the scene. But if you're using IBL than you have to note that LuxRenders lighting system is different from Poser. You better start with simpler spot and pointlight to get a feeling for what LuxRender can do. The most complicated things we are familar with in Poser are not required with LuxRender.
Also, to expand on adp's answer...
LuxRender is an unbiased renderer and therefore, for the present time, is much slower than Poser's firefly. What might take a half hour in Poser will take hours and hours in Luxrender. The result however will be vastly superior in LuxRender. If you aren't prepared to waive time for a better render then LuxRender may not be for you ;o).
The LuxRender programmers are busy getting GPU rendering to work with it, which will speed it up a lot if you have a decent graphics card, but for now, it's all CPU and is slow.
Well, now it's one step close to finding a solution. :)
Traceback (most recent call last):<br></br>
File "<string>", line 61, in ?<br></br>
File "C:Program
FilesPoserLuxExporter_alpha_1-30dworkersBBLuxMat.py", line 55,
in ?<br></br>
reload(luxmatic.matcore)<br></br>
AttributeError: 'module' object has no attribute
'matcore
Do you still need the output from tellsysPath.py?
Also, if I add the following:
try:
import luxmatic.matcore
except:
import sys
sys.path.insert(0, myFolder)
try:
import luxmatic.nodes
except:
import sys
I get this error message:
File "", line 218, in ?
File "C:Program FilesPoserLuxExporter_alpha_1-30dworkersPoserLuxExporter_workers.py", line 63, in ?
reload(BBLuxMat)
File "C:Program FilesPoserLuxExporter_alpha_1-30dworkersBBLuxMat.py", line 67, in ?
File "", line 921
scale=" ".join(str(v) for v in (self.x_scale/scdiv, self.y_scale/scdiv, self.z_scale/scdiv)),
SyntaxError: invalid syntax
Blargh, I probably messed something up somewhere!
Ah, forget it, I'll just post what tellSysPath.py says:
['', 'C:Program FilesPoserLuxExporter_alpha_1-30d', '', 'C:Program FilesPoserLuxExporter_alpha_1-30d', '', '', '', 'C:Python26', 'C:Program FilesCurious LabsPoser 6RuntimePythonDLLs', 'C:Program FilesCurious LabsPoser 6RuntimePythonlib', 'C:Program FilesCurious LabsPoser 6RuntimePythonlibplat-win', 'C:Program FilesCurious LabsPoser 6RuntimePythonliblib-tk', 'C:Program FilesCurious LabsPoser 6', 'C:Program FilesCurious LabsPoser 6RuntimePython', 'C:Program FilesCurious LabsPoser 6RuntimePythonlibsite-packages', 'C:Program FilesPoserLuxExporter_alpha_1-30d', 'C:Program FilesPoserLuxExporter_alpha_1-30dworkers', 'C:Program FilesPoserLuxExporter_alpha_1-30dpydough', 'C:Program FilesPoserLuxExporter_alpha_1-30d', 'C:Program FilesPoserLuxExporter_alpha_1-30dluxmatic', 'C:Program FilesPoserLuxExporter_alpha_1-30d']
I think it was the same as last time, but somehow copying and pasting it into the window dropped off the bracket.
Gah, I should have read that earlier to be sure, but it was soo early. :closedeyes:
Hit another snag with the exporter 1.30d, which is pretty much what Latexluv experienced a page ago. What appears to be happening is for materials that have solid (ie. no textures attached) diffuse and specular colors set to black are being dropped off at the time of export. Without them, LuxRender will default everything to white and blow out the other attached colors or textures attached to the mesh. As a work around until the next version, simply going into the file itself with a text editor and setting the color Kd/Ks information to [0 0 0] or slightly higher fixes the issue. That, or giving everything in Poser a different color prior to running LuxPose would work as well.
Also, I noticed that one of the polygons attached to Terai Yuki 2's flip-flop strap seems to have shifted away from mesh. At first, I thought I was seeing things, but it's consistent with each time I run the export script and is not visible in Poser 7's OpenGL (software, blargh, crap laptop!) real-time viewer or final render. Not sure what to make of it, other than possibly that the area where the polygon/vertex is located is being approximated in some off manner at the time of export. I'll have to get it past 120 S/px to be sure.
Quote - And with with fixed image. Sorry about it being tiny. :unsure:
Thanks for the report!
Fixed Version Alpha 1.30e
Quote - Not sure what to make of it, other than possibly that the area where the polygon/vertex is located is being approximated in some off manner at the time of export. I'll have to get it past 120 S/px to be sure.
Can't say anything about the geometry but nothing has changed here.
With the last version I changed how subdivision is handled. "addParameters2allActors.py" now attaches the dials only in a figures body actor. All other actors of a figure are left alone. The dials in the body are taken for subdividing of the whole figure.
Beside of Catmul-Clark subdividing, LuxRenders own subdividing can also be used. This is mutch faster and should be used if "normal" subdividing is needed and boundaries should stay sharp.
I get this error now.
File "", line 76, in ?
Exception: Folder 'toLux' can't be created in path D:Poser 6RuntimePythonposerScriptsluxrender.Check if a file named 'toLux' exists already
The problem seems to be the luxrender part of the path, that doesn`t actually exist.
Found another problem in 1.30e, most of which links back to xantor's encounter earlier. For the most part, it seems that the directory structure was really hardcoded to be in the following directory: C:Program FilesCurious LabsPoser 6RuntimePythonposerScriptsluxrender. This itself creates some issues if you just extract the scripts into a folder in the same directory, but by the compressed zip file name. After making the directory and moving the scripts over, you're then presented with another issue, this time relating to the subdivision code for Lux itself rather than using CC.
Compiling C:Program FilesCurious LabsPoser 6RuntimePythonposerScriptsluxrenderluxmaticnodes.pyc
Loading pydough.geometry_export
Loading pydough.from_poser
Loading pydough.to_lux
LuxPose Version alpha 1.30e, exporting files to C:program filesCurious LabsPoser 6RuntimePythonposerScriptsluxrendertoLux3poserscene_alpha 1.30e.lxs
Using sampler metropolis
Using integrator path
Using accelerator qbvh
GEOMETRY EXPORT
CC-Subdivision for figures: 0
Figures compute normals: 1
File "", line 219, in ?
File "C:Program FilesCurious LabsPoser 6RuntimePythonposerScriptsluxrenderworkersPoserLuxExporter_workers.py", line 544, in write
ExportFigure(fig, self.globalParameters).write(outfile)
File "C:Program FilesCurious LabsPoser 6RuntimePythonposerScriptsluxrenderworkersPoserLuxExporter_workers.py", line 235, in write
meshparameterstring = (file,
UnboundLocalError: local variable 'sharp' referenced before assignment
Seems that setting lux_subdivision to 1 or more brings this error up on both Poser 6 and 7. Using ccfigures or ccprops at 1 or more does not. Though, oddly enough, setting ccfigures to 1 by itself seems to not work in creating subdivisions.
Oh, and you're right about setting integrator to Path being pretty fast. Seems to really work well with HDR IBL lights and a single infinite light for low level specular. Though, now it appears that the HDR map I attached to the light is showing up on the background! Not sure what happened there, mostly as it was not acting like that the other day.
Quote - Depth of Field...
How is this setup in Poser to LUX?
In the meantime, I finally created an image almost worthwhile of posting:)
Pretty cool image of Sackboy from Little Big Planet. Seeing him just puts a smile on my face.
As for depth of field, I'm not too sure how that works in the current exporter. Chances are that it has something to do with an explicit setting pertaining to the camera controls in the .lxs file, but I really have no idea. :huh:
Anyone else know how to make it work?
I don't think the exporter does DoF, you have to add DoF settings to the .lxs file, like so:
Camera "perspective"
"float fov" [14.8586407274]
"bool autofocus" ["false"]
"float lensradius" [0.00625]
"float focaldistance" [4.0]
lensradius is dependant on the camera aperture setting, this is for an Fstop of 2.8, lower Fstop is larger radius.
focaldistance is distance in meters to the focal point.
autofocus must be false.
Pose2Lux
4670 - 256 MB
Quote - I don't think the exporter does DoF, you have to add DoF settings to the .lxs file, like so:
Camera "perspective""float fov" [14.8586407274]
Thanks for this will give it a shot this weekend :)
The double post has me stummped once again, must be the dialup "Power of Cheese" (read AOL)
Quote - What you think, will there be some material tweaking UI in luxpose coming soon? Do you need any implementation help here? If not, I guess I should buy this reality thing over at DAZ, it has its "last" sale day :)
I don't know what the other guys are planning.
For the GUI: The "webserver" already included in the package could be used to make a "tweaking GUI". At least after some additions.
Quote - [Pretty cool image of Sackboy from Little Big Planet. Seeing him just puts a smile on my face.
OT: It's Samedi from Netherworks Freebie :) Very cool little dude.
here <<<
Version Alpha 1-30g
with DOF support.
Parameters are taken from Posers GUI, except for the parameter "lensradius" (this is how depth the sharp area is). This is taken from "Shutter Open". If "Shutter Open" is zero, depth of field is ignored (camera works as before).
*Traceback (most recent call last):
File "D:8888 - Poser RuntimesPoser ProRuntimePythonposerScriptsScriptsMenuLuxRenderPoserLuxExporter.py", line 57, in ?
raise Exception, "nnPlease install script into correct folder!"
Exception:
Please install script into correct folder!*
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
Quote - *Traceback (most recent call last):
Exception:Please install script into correct folder!*
Which Poser version?
Quote - > Quote - *Traceback (most recent call last):
Poserpro
Quote - > Quote - I don't think the exporter does DoF, you have to add DoF settings to the .lxs file, like so:
Version Alpha 1-30g
with DOF support.
:woot: THANKS!
The best way is to extract the folder "luxrender" from the zip package to [PoserPath]/Runtime/Python/PoserScripts.I tried it on a fresh installed Poser 2010 and it works this way.
makes no difference. same error message as before, just one folder up.
Quote - > Quote -
Don't know why this does not work for you.
The test for correct folder is now only done for Poser versions less than 7. Please re-download and post if this works for you too.
Well export with the latest Luxpose is quite interesting. The image came in at just the right settings under Linear. I didn't have to fiddle with anything. However, I have tried to brighten my lights and use black body temperature but it doesn't appear to be doing anything. I'm still rendering tho. I did want to ask about Poser light export. Will shadow blurring be supported at sometime? My shadow in the image looks way too sharp for my taste.
Weapons of choice:
Try it out with a sphere from Posers "Primitives". If you render such a sphere (with LuxRender) you will see it's very lowres. Catmul-Clark subdivision is a specialized methode to make a 3D-model "smoother". Ask wikipedia to read more about this.
