Thu, Nov 14, 8:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Need help with conforming clothing
Raddar ( ) posted Sun, 24 October 2010 at 3:09 PM · edited Thu, 14 November 2024 at 8:40 PM
I am a complete noob when it comes to conforming clothing.  That being said I ahve read every tutorial I can find and I still don't get it.  Following Microsmith's tut step by step I get several major problems.  The first is when I leave the setup room I get the message telling me not all my polygons are grouped to a bone, doesn't matter how simple the item, or how many times I group it all up, I get this message.  Problem 2 is the piece does not move with the figure at all.  3rd is the bone that points forward from the hip, (pic), for some reason it is attached to my clothing item when I leave the setup room.
Any help?  Or directions to a less vague tutorial?
Thnx gang.
kyhighlander59 ( ) posted Sun, 24 October 2010 at 3:11 PM
Well it appears to be male at any rate. ;-)
kyhighlander59 ( ) posted Sun, 24 October 2010 at 3:12 PM
Have you seen PhilC's tutorial in this months 3D Artist? it is really good.
Raddar ( ) posted Sun, 24 October 2010 at 3:38 PM
Quote - Well it appears to be male at any rate. ;-)
ROFL  Glad I didnt have a drink when I read this, my monitor would have been splattered.
geep ( ) posted Sun, 24 October 2010 at 4:23 PM · edited Sun, 24 October 2010 at 4:24 PM
Um, ..... maybe so but ...... I think it's spelled with an "r" on the end, no? ...  :lol:
(sorry, couldn't resist)
cheers,
dr geep ... :o]
edited 10/5/2019
kyhighlander59 ( ) posted Sun, 24 October 2010 at 4:26 PM
LOL at the end of what? LOL
DarkEdge ( ) posted Sun, 24 October 2010 at 4:58 PM
This will show you everything you need to know...
http://www.contentparadise.com/productDetails.aspx?id=812
santicor ( ) posted Mon, 25 October 2010 at 12:06 PM · edited Mon, 25 October 2010 at 12:08 PM
I can see U R  using an existing rig  from  an  existing  figure. - - - to  make a piece of clothing for this figure
So you have the "setup"  object  present  ( the faux  male organ) because  you  have groups  in your  clothing OBJ  which  do  not match  any of the names  of the body  parts of the character rig.
So  fix  that  issue first,  before trying to  conform  the clothing to the character -   this is your second mentioned  problem -  the clothing does not move  because  you  did not conform  your clothing figure to  the character figure  after you  left set up  room.
if  you  fix  your  poly  group  names  to  make sure eveything  is  also  named  over in  the character ....then  you  can leave setup  room without that  error warning,  you  wont see the male organ,   and you  will  then be able to  select FIGURE- CONFORM TO- " yourcharacter"  you  made the clothing for.
OH damn  I just  noticed  this is  a tail.... it looks like you  are needing only a tail ?????
making this a conformer to  a figure might not be your best  bet .
going this way  mean  you  will most likely  want to have the HIP  bone  of the  charcter  be the HIP bone of the tail.
but then  you might be hard  pressed for the tail  to have a nice  string of  bones  for  wavy  tail movements.
 I think you  should make a stand alone  tail  figure  with its  own bone structure - ( again  , see PHIL C  tutorial  video)  and then  parent this figure to  the rearend part of the character.  forget about ripping the characters  rig  and making a conformer.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
Raddar ( ) posted Mon, 25 October 2010 at 10:59 PM
Quote "OH damn  I just  noticed  this is  a tail.... it looks like you  are needing only a tail ?????"
No no, its actually a lightning bolt thingamajig that will run down the outside of both legs, so it will conform almost like a pair of pants.  And your tips were right on the money.  I followed them step by step  and it worked perfectly.  Thanks for all the feedback.  :)
BTW  I like your quote.  I find it inconceivable that someone else picked that line out of that movie to remember.  :D
