DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
I'm not sure about Reality but I know that DS will not render any image you load in as background. The image must be a texture in a plane. If Reality follows the DS convention then this would account for your missing background.
BTW always set you background to black before rendering. It makes a difference to the edges of your image that will slightly bleed in the background colour.
Quote - This might seem a bit obvious to some of you, but why can I not see my background when rendering in Reality? Must I texture a plane and use it?
Cheers;-)
Michael
Hi Michael,
Renderosity doesn't render your background unless you put it on a plane, then make the plane Matt Transulent in Reality.
I find, however, that setting the alpha to PNG in the output settings window, it is very easy to layer in your background image. Paolo has a couple videos on his website which address this. http://www.preta3d.com
Quote - I'm not sure about Reality but I know that DS will not render any image you load in as background. The image must be a texture in a plane. If Reality follows the DS convention then this would account for your missing background.
If you set the output type to JPG, D|S will render your background image just fine.
Cheers;-)
Michael
