Wed, Dec 25, 8:37 AM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: Reality_Rendering Cannot See My BG???
vidyashakti ( ) posted Mon, 08 November 2010 at 2:10 AM · edited Wed, 25 December 2024 at 8:13 AM
This might seem a bit obvious to some of you, but why can I not see my background when rendering in Reality? Must I texture a plane and use it?
Cheers;-)
Michael
LBAMagic ( ) posted Mon, 08 November 2010 at 2:20 AM · edited Mon, 08 November 2010 at 2:22 AM
I'm not sure about Reality but I know that DS will not render any image you load in as background. The image must be a texture in a plane. If Reality follows the DS convention then this would account for your missing background.
BTW always set you background to black before rendering. It makes a difference to the edges of your image that will slightly bleed in the background colour.
tokejr ( ) posted Mon, 08 November 2010 at 4:16 AM
Quote - This might seem a bit obvious to some of you, but why can I not see my background when rendering in Reality? Must I texture a plane and use it?
Cheers;-)
Michael
Hi Michael,
Renderosity doesn't render your background unless you put it on a plane, then make the plane Matt Transulent in Reality.
I find, however, that setting the alpha to PNG in the output settings window, it is very easy to layer in your background image.  Paolo has a couple videos on his website which address this.  http://www.preta3d.com
tokejr ( ) posted Mon, 08 November 2010 at 4:18 AM
Quote - I'm not sure about Reality but I know that DS will not render any image you load in as background. The image must be a texture in a plane. If Reality follows the DS convention then this would account for your missing background.
If you set the output type to JPG, D|S will render your background image just fine.
vidyashakti ( ) posted Mon, 08 November 2010 at 8:48 AM
I thought so:-) Thanks much Toke. Much appreciated.
Cheerio;-)
LBAMagic ( ) posted Mon, 08 November 2010 at 3:44 PM
Quote - If you set the output type to JPG, D|S will render your background image just fine.
Ah! I see. I never use render as JPG. I always use render as PNG because of it's high quality to work with later in Photoshop. Thanks for clearing that up.
