Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
It is a pain in the ****
Every time I load a figure it is the same thing/
Remove IK on left leg
Romeve IK on Right leg
Goto Joint editor
Zero Joints
A real PIA
Only then you can start.
Since P5 a real PIA
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Quote - It is a pain in the ****
Goto Joint editor
Zero JointsA real PIA
Since P5 a real PIA
Maybe ................. Hire a snake*. :lol:
** a big snake ... like a python*
cheers,
dr geep ... :o]
edited 10/5/2019
The Poser developers strike me as brilliant programmers but dunces at usability. How could thay not have realized that
Figure->Use Inverse Kinematics->RightLeg Uncheck
Figure->Use Inverse Kinematics->LeftLeg Uncheck
wasn't the most user friendly way to go. And you say it's been that way since P5?! Wow! I only started with P8, so I assumed it was a new feature.
But do you really need to zero out a character when it's first loaded? Isn't it at the zero state by default?
OS: Windows 10 64-bit, Poser: 10
*"... But do you really need to zero out a character when it's first loaded? Isn't it at the zero state by default?"*YES ...................... If it has been saved in a zero pose.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Quote - I meant the base characters like V4, M4, etc when first loaded are at the zero state. Right?
Wrong. Most of the DAZ figures load slightly posed. For Example V4's feet by default load flat on the ground even though they are actual bent down on the model.
For Zeroing a figure and turning IK off, one of ockham's scripts will do just that and is a script that I use a lot.
@ ElZagna
Not necessarily ... It depends on how they were saved (stored) in the library when created the very first time. If they were not in a zero pose position when saved then they will not be in a zero pose when loaded. If you want them to load in a zero pose position ... Try doing the following ...
Load the figure
Turn OFF IK for both legs
"Zero" the pose (using the Joint Editor)
"Drop to floor" (optional?)
Save the figure back to the library
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I need to zero the pose of my character without zeroing the morphs I put in for his face and body. Is there a way of doing that? I'm not seeing anything that allows for just removing the pose.
