Sat, Feb 15, 12:07 PM CST
Subject: Zero the pose? How? Poser 2008
Michaelab ( ) posted Sun, 09 January 2011 at 12:11 PM · edited Thu, 13 February 2025 at 12:26 PM
I need to zero the pose of my character without zeroing the morphs I put in for his face and body. Is there a way of doing that? I'm not seeing anything that allows for just removing the pose.
PhilC ( ) posted Sun, 09 January 2011 at 12:22 PM
Suggest using the zero pose button in the joint editor window after first turning off all IK chains. You may then need to finish off by selecting the hip and body and zeroing the translations.
geep ( ) posted Sun, 09 January 2011 at 12:25 PM · edited Sun, 09 January 2011 at 12:27 PM
[menu]"Window" >>> "Joint Editor" >>> "Zero Rotations" (button) @ bottom of JE window
cheers,
dr geep
P.S. Hiya Phil ......... OMS..... what happened to your face?* :blink:
*Oh My Stars
cheers,
dr geep ... :o]
edited 10/5/2019
Michaelab ( ) posted Sun, 09 January 2011 at 12:26 PM
You guys are good, thank you. That worked perfectly.
markschum ( ) posted Mon, 10 January 2011 at 3:12 PM
Help, send a Barber to save Phil, hes being attacked by his beard . !!!
dontcha hate when that happens ?
PhilC ( ) posted Mon, 10 January 2011 at 7:51 PM
Its OK, I'm going a little thin on top so am cultivating a comb-over :)
geep ( ) posted Mon, 10 January 2011 at 9:24 PM
Comb on Phil, did we hair you correctly? :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
vilters ( ) posted Mon, 10 January 2011 at 10:37 PM
It is a pain in the ****
Every time I load a figure it is the same thing/
Remove IK on left leg
Romeve IK on Right leg
Goto Joint editor
Zero Joints
A real PIA
Only then you can start.
Since P5 a real PIA
KimberlyC ( ) posted Mon, 10 January 2011 at 11:30 PM
Quote - Help, send a Barber to save Phil, hes being attacked by his beard . !!!
:lol::lol:
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
geep ( ) posted Tue, 11 January 2011 at 1:15 AM
Quote - It is a pain in the ****
Goto Joint editor
Zero Joints
A real PIA
Since P5 a real PIA
Maybe ................. Hire a snake*. :lol:
** a big snake ... like a python*
cheers,
dr geep ... :o]
edited 10/5/2019
ratscloset ( ) posted Tue, 11 January 2011 at 9:53 PM
Figure Menu> Zero Figure
Remove IK> Use any of the Remove IK Pose that come with Poser. (I moved one to the top of the Pose Library. I think you could put one in the top of every Library (Character, Expressions, etc... ) in Poser 8. I know it will show up, have not tried it.
ratscloset
aka John
ratscloset ( ) posted Tue, 11 January 2011 at 9:54 PM
To clarify, it is Poser 8 (Poser Pro 2010)... Poser 8 was released in August of 2009.
There is no Poser 2008
ratscloset
aka John
ElZagna ( ) posted Tue, 11 January 2011 at 10:20 PM
The Poser developers strike me as brilliant programmers but dunces at usability. How could thay not have realized that
  Figure->Use Inverse Kinematics->RightLeg Uncheck
  Figure->Use Inverse Kinematics->LeftLeg Uncheck
wasn't the most user friendly way to go. And you say it's been that way since P5?! Wow! I only started with P8, so I assumed it was a new feature.
But do you really need to zero out a character when it's first loaded? Isn't it at the zero state by default?
OS: Windows 10 64-bit, Poser: 10
geep ( ) posted Tue, 11 January 2011 at 10:47 PM · edited Tue, 11 January 2011 at 10:49 PM
*"... But do you really need to zero out a character when it's first loaded? Isn't it at the zero state by default?"*YES ...................... If it has been saved in a zero pose. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ElZagna ( ) posted Wed, 12 January 2011 at 7:33 AM
I meant the base characters like V4, M4, etc when first loaded are at the zero state. Right?
chriscox ( ) posted Wed, 12 January 2011 at 7:47 AM · edited Wed, 12 January 2011 at 7:50 AM
Quote - I meant the base characters like V4, M4, etc when first loaded are at the zero state. Right?
Wrong.  Most of the DAZ figures load slightly posed.  For Example V4's feet by default load flat on the ground even though they are actual bent down on the model.
For Zeroing a figure and turning IK off, one of ockham's scripts will do just that and is a script that I use a lot.
Chris Cox
geep ( ) posted Wed, 12 January 2011 at 7:52 AM · edited Wed, 12 January 2011 at 7:53 AM
@ ElZagna
Not necessarily ... It depends on how they were saved (stored) in the library when created the very first time.  If they were not in a zero pose position when saved then they will not be in a zero pose when loaded.  If you want them to load in a zero pose position ... Try doing the following ...
  1. Load the figure
  2. Turn OFF IK for both legs
  3. "Zero" the pose (using the Joint Editor)
  4. "Drop to floor" (optional?)
  5. Save the figure back to the library
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
vilters ( ) posted Wed, 12 January 2011 at 8:43 AM
Correct
and then
GOTO Duplicate figure an SHOCK
Ik is back ON. (on the duplicated figure)
geep ( ) posted Wed, 12 January 2011 at 8:47 AM
Yup ..................... IK is ON for both legs is the default for a figure when it is loaded.
Your choice. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
ElZagna ( ) posted Wed, 12 January 2011 at 9:04 AM
Thanks for setting me straight. The base figures aren't necessarily zeroed.
