Carrara F.A.Q (Last Updated: 2025 Jan 15 2:29 am)
The UV editing section has changed a bit since version6 but the route towards the UV mapping section is the same as mine even though I use 7pro at the moment (gotta get the cash together LOL)
If you check out the image I have attached you will note a button at the top right-hand side that you click on to enter the UV mapping section then it is just a case of browsing the various tabs as you will find the buttons that are essentially the same as what the tutorial shows but just in different places.
Hope this helps.
LOL.. mark aswered whilst I was typing... and learning to spell too.
yes benney that will help a lot. I guess this old body just needs to look a little closer at the interface. It's like windows 7 everything is there that was there in XP but you just have to fine were they moved it to . some times you wonder if it is a help ir not.
thanks for getting back to me
woody2
Even though this is off topic a little,
I've been using C since it ever existed and if it's any consolation, I'm still finding buttons and tabs once in a while.
For me, I think it's easier to miss new features/buttons when you're an old user than when you're learning new. When you're learning a package from scratch you just click on everything to figure out what it does. When you're used to the package, you use what you're used to and don't go and explore the whole thing again.
So every once in a while, I'll go and do something that I haven't done in a long time and dang it if there's not a bunch of new buttons all over the place! The texture engine has been the most infamous for me on that count. Lots of little buttons hidden in places and if you open up an old model, C will continue to display the same texture tree that you used when you built the thing so new buttons/tabs won't show up when you use old stuff sometimes.
-Kix
thanks for any help
Woody2
