Sat, Feb 8, 1:58 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Figure mixing using only Poser
R_Hatch ( ) posted Sat, 14 May 2011 at 4:43 AM · edited Sat, 08 February 2025 at 11:10 AM
The only real hard part is placing the bones and placing the matSpheres, as Poser's 'load morph target' function is perfectly suited to the mesh blending. I have a feeling that this might be a fairly easy task for someone with some Python skills, which I am not.
The controls needed for the UI would be quite simple, as it should just ask for a source figure, a target figure, and a percentage of target to combine with source. If any JCMs could be converted along the way, that would probably be useful as well.
nruddock ( ) posted Sat, 14 May 2011 at 6:01 AM
Unfortunately I'm pretty certain Python doesn't have access to all the necessary information (it would have to be parsed from the CR2s), and certainly doesn't have the ability to set new values other than by writing a new file (either a CR2 or possibly a PZ2), so while still possible, it's not going to be as simple as could be if the API was extended.
R_Hatch ( ) posted Sat, 14 May 2011 at 8:32 AM
What I have in mind wouldn't be dynamic. It would read values from source and target CR2s, apply blending amount specified by user, then write a new CR2.
