Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Quote - Poser suffers from a severe case of gimbal lock. Sure wish the powers that be would fix that ;)
Can't be fixed, it's an inherent problem of using Euler angles for rotation. One solution to the OP's problem is to parent the item to an invisible prop, and use it to provide the X rotation, and the original prop for Y rotation.
Quote - Do you mean an object attached to a figure or just a standalone object? Poser suffers from a severe case if gimbal lock. Sure wish the powers that be would fix that ;).
I use from the poser library: Poser8->Additional Figures-> Hands->RightHand
I guess RightHand is a figure.
However it has many parts: e.g. rThumb1,rIndex0 etc
One of the parts is called "Right Hand". I rotate this object.
I also noticed maybe a bug?
when I execute this command: rightHandActor.SetParameter("Side-Side", -45);
and rightHandActor.SetParameter("Bend", -45); it works fine.
But when I try to alter the "Twist" parameter:
rightHandActor.SetParameter("Twist", -45); it doesn't rotate the object.
I also use scene.DrawAll() but still no effect.
Any ideas???
Thank you!
Paul
Yes, nruddock has a point. A wrist doesn't twist on it's own. The forearm twists, but not the wrist joint itself. Check the file menu at (and since I don't have it open, atm - I'm guessing. I think it's under figure) Figure/Limits or Set Limits. If that's checked, there will be certain things that you can't do with a joint like a bend or a twist that can't be done to the real joint :). If you still want to twist the hand anyway, uncheck the Limits.
Quote - Check the file menu at (and since I don't have it open, atm - I'm guessing. I think it's under figure) Figure/Limits or Set Limits. If that's checked, there will be certain things that you can't do with a joint like a bend or a twist that can't be done to the real joint :). If you still want to twist the hand anyway, uncheck the Limits.
Some limits may be "forced" by a setting in the CR2.
To change that you have to edit the file.
Quote - Some actors may be locked, or have limits set in such a way that effectively prevent rotation.
This is normal for rotation axes that are unnatural for human joints.
Thanks for the reply.
The problem is that if I manually try to "Twist" through tha palette then it works!
If I try to twist it using python then it has the problem.
But I found a way to make it work.
Here is the code:
rightHandActor = scene.Actor("Right Hand");
parmTwist = rightHandActor.ParameterByCode(poser.kParmCodeXROT);
parmTwist.SetValue(-22.5);
Hello everybody,
I need to rotate an object first around it's Y-axis and then around the X-axis.
To my understanding, rotating around Y-axis corresponds to "twist" and rotating around X-axis corresponds to "bend".
I do rotations in the objects local coordinates and NOT in world coordinates.
My problem is that if I first "twist" then I need to rotate around the NEW rotated relative X-axis and NOT around the initial X-axis.
Hope my question is clear!
Thank you in advance,
Paul
