Thu, Feb 13, 4:25 AM CST
Subject: I know what color gold is - finally
stewer ( ) posted Tue, 05 July 2011 at 12:50 PM
Quote - Which is why renderers like Maxwell render in spectra instead of RGB (part of the reason for their ridiculous levels of photorealism)
I understand all the theoretical advantages behind spectral rendering, but so far I haven't found any side-by-side comparison of spectral vs RGB rendering that would show a visible difference. Would love to see one if anyone can find one :)
The closest I've seen is http://www.anyhere.com/gward/papers/egwr02/img/ColorPlate.jpg where the difference is measurable, but barely visible in the direct comparison and would go unnoticed without a reference.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:05 PM
Keith showed us a few pictures, with the intent to show us how gold comes in various colors. That's nice, but I can make a defensible argument that those three samples of gold were identical, and that the color variation came from environment differences or camera differences alone.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:06 PM · edited Tue, 05 July 2011 at 2:09 PM
Observe this gold-plated utensil. I have a set of these in many shapes, but this utensil is the most flat, and therefore the most useful for my measurements. It is resting on a white leather chair.
I believe it is 24K gold, but I'm not sure. I don't really care. Watch.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:07 PM · edited Tue, 05 July 2011 at 2:08 PM
I turn off my camera white balance feature. Now we see an unmodified interpretation of the room lighting. My chair is not white anymore. And the utensil looks different as well.
The disgusting color is from compact fluorescent light bulbs.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:09 PM
So now I'm going to take a bunch of photos like this, holding the utensil in front of me.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:10 PM
And I'm going to crop the center like this.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:11 PM · edited Tue, 05 July 2011 at 2:18 PM
In eleven different rooms of my house, this is the center crop of the utensil.
THIS IS THE EXACT SAME OBJECT IN ALL ELEVEN ROOMS.
Clearly, the photographic evidence of gold variation is not useful AT ALL unless you include the un-reflected object as a reference in the same photo.
3Dave ( ) posted Tue, 05 July 2011 at 2:11 PM
(o) (o)
bagginsbill ( ) posted Tue, 05 July 2011 at 2:13 PM · edited Tue, 05 July 2011 at 2:14 PM
In doing my measurements, I marked an area of a piece of paper. I made sure that I could see that mark both on the paper directly, and reflected in the utensil. I took my ratio of reflection colors by using the same spot, reflected color divided by direct color.
But even this was too casual and has a flaw. The utensil is reflecting light onto the paper, changing its color. Measuring these two this way, I'd be pulling in measurements from a feedback loop. This would give incorrect results.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:15 PM
It was important to keep the utensil tilted and positioned so that it did not throw its own color onto the paper, like this.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:16 PM
And then measure the same spot at a shallow angle to find out what color it is when not viewed straight on.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:17 PM
Stainless steel was easy to find - any butter knife will do.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:18 PM
This is my copper reference. Jumper cable.
bagginsbill ( ) posted Tue, 05 July 2011 at 2:24 PM · edited Tue, 05 July 2011 at 2:24 PM
One more thing about the "color" of gold. I gave you an sRGB color. I'm assuming (and make sure to use) the linear version of that in my shader. That means that to get the actual ratio of components, you must not use the direct value of x/255. You must convert from sRGB to linear.
For example, if the red is 255 and the green is 230, the ratio is NOT 230/255 = .902. You have to take it to the power 2.2 to remove the gamma correction. So the true ratio is (230/255)^2.2 = .797.
Poser Pro does this automatically.
3Dave ( ) posted Tue, 05 July 2011 at 2:24 PM
If memory serves, you've just demonstrated Chevreul's colour theory which itself was a founding theory of Impressionist Painting and taken to extreme by The Fauves in the very early 20thC. Another artistic revolution driven by science, please continue the lesson
Keith ( ) posted Tue, 05 July 2011 at 8:28 PM · edited Tue, 05 July 2011 at 8:37 PM
Quote - Keith showed us a few pictures, with the intent to show us how gold comes in various colors. That's nice, but I can make a defensible argument that those three samples of gold were identical, and that the color variation came from environment differences or camera differences alone.
Absolutely, for part of it. The first was taken in a small room where I didn't need a flash because the flourescent lighting was sufficient. The second was taken in a big empty space where I had to use a flash (with a different camera) because otherwise it would have been too dim.
However, and in this case you'll have to take my word for it, the first brick really was significantly duller and of a different shade than the latter. It surprised a lot of the people there at the time (who'd never seen raw gold before) that it really wasn't very shiny at all.
Now for pure, polished gold (which you have with the spoon) you've got a pretty optimum situation for seeing it in different situations. If you're comparing different gold objects, say a beaten gold Bronze Age ornament, it's going to have potentially a radically different colour, even in the same environment, than a piece of gold ornamentation coming from a different source or processed in a different way. It's one of the things I run into as a geologist regularly: you can't rely on colour/reflectivity alone as a diagnostic feature except when dealing with samples from the same environment examined in the same environment.
kawecki ( ) posted Wed, 06 July 2011 at 12:11 AM
Gold has different colors, it depend of other elements present in gold, even a 24K is not 100% pure gold. You can add the effect of ambient as moisture, dust and the surface finish.
What makes gold look gold is not the color itself, the illumination effects makes gold look as gold.
I did some quick experiments, as I have no gold trimmed shader and no raytracing I did it with what I have.
In this image I used standart Phong for specular channel, a modified not Lambertian for diffuse channel and a modified environment mapping and three directional white lights.
Stupidity also evolves!
kawecki ( ) posted Wed, 06 July 2011 at 12:13 AM
In this image gold looks much better
kawecki ( ) posted Wed, 06 July 2011 at 12:25 AM
In this image are the same two renederings without environment mapping.
As you can see it doesn't look as gold and as I said before I haven't the appropiate shader for gold. What made look as gold were the reflections even if fake.
The second interesant thing was that in the second image where the gold look much better I used instead of Phong (left) the Lommel-Seeliger shader (right), nothing to do with gold and metals, this shader is made for rendering the Moon!!!
The Lommel-Seeliger shader produce a strong illumination at glazing angles, so if it made gold look better it means that gold has strong reflections at glazing incidence angles.
MistyLaraCarrara ( ) posted Fri, 15 July 2011 at 9:45 AM
ohhh, is environment mapping the secret trick?
my results last night were so awful, doan want to post it.
kawecki ( ) posted Fri, 15 July 2011 at 10:56 AM
Environment mapping is a way to make fake reflections. You can make natural reflections with raytracing. The problem is that must exist something to be reflected. A dull room with nothing will not work. You need objects in the room, extended area light sources or windows acting as a light source.
Miss Nancy ( ) posted Fri, 15 July 2011 at 1:56 PM
the above is what I got with lo-qual. FFRender/IDL settings and first approx. of schlick approx. of fresnel gold procedural.  the difficulty here is that if anybody posts screenshot of optimal schlick approx. of fresnel gold procedural, then this would present probs in case bill is planning to sell his metals shader pak.
p.s. the inclusion of the ibis-winged demigoddesses on top of the sarcophagus indicates the origin of the hebrew religion was Amun-Ra.
bagginsbill ( ) posted Fri, 15 July 2011 at 2:15 PM · edited Fri, 15 July 2011 at 2:16 PM
Oh anybody who can figure out what to do is free to post it. Believe me, you're not going to match what I have. I have the same shader doing several golds, several coppers, several brass, bronze, silver, platinum, steel - in all of these I have various finishes (smooth to blurry/rough).  I have grain and mottling where needed. I have the specular node perfectly tuned to match the blur and IOR so that reflections of Poser lights look just like reflections of a Poser glowing sphere. I have several hammered versions that are really beautiful. I don't know of anybody outside guys at Pixar who can match what I'm doing. Not even at SM.
Looking at yours, Miss Nancy, I see:
There is diffuse there in your shader. I measured it on real gold - polished gold diffuse response is less than .1%. Get rid of that.
You don't have the right change in color as a function of viewing angle. That was really tricky and took me a long time to get right.
Did you use the color I gave for straight on? It seems to look a bit too green. That looks more like brass.
Afrodite-Ohki ( ) posted Fri, 15 July 2011 at 2:45 PM
Quote - Oh anybody who can figure out what to do is free to post it. Believe me, you're not going to match what I have. I have the same shader doing several golds, several coppers, several brass, bronze, silver, platinum, steel - in all of these I have various finishes (smooth to blurry/rough).  I have grain and mottling where needed. I have the specular node perfectly tuned to match the blur and IOR so that reflections of Poser lights look just like reflections of a Poser glowing sphere. I have several hammered versions that are really beautiful. I don't know of anybody outside guys at Pixar who can match what I'm doing. Not even at SM.
Now you're just making me impatient LOL
Release that already, will you? (Please?)
Feel free to call me Ohki!
BionicRooster ( ) posted Fri, 15 July 2011 at 2:52 PM
Forum Moderator
Yeah BB, hurry up and finish the pack already, you'll have an instant #1 product!
So get off yer arse, perfect what you believe to be incorrect, and give it to us already! lol
Just kidding, don't rush it cuz us buttheads are impatient hehehe
Poser 10
Octane Render
Wings 3D
Miss Nancy ( ) posted Fri, 15 July 2011 at 5:20 PM
o.k., here's one where it's (255, 215, 147), more colour change and less diffuse.  it looks less cartoonish in this one, but they may expect cartoonish gold if they haven't got a few pieces lying around to compare to their renders.
bagginsbill ( ) posted Fri, 15 July 2011 at 5:51 PM
MN - 100 times better!
Are you using GC or no?
Miss Nancy ( ) posted Fri, 15 July 2011 at 6:52 PM
no, it was HSVTM=1.67, gain =1.33, envdome/hdri and one inf lite at 75%, 4 IDL bounces (quickie).
it's gonna look too dark to many, as this sponza building is like an elevator shaft - even with 16 bounces there ain't much to reflect, excepting the floor.  it would look better in something bright with alotta sky, e.g. the free OBL compound and envdome.  or I could put some lites in the sponza atrium.
bagginsbill ( ) posted Fri, 15 July 2011 at 7:25 PM
That looks really good.
bagginsbill ( ) posted Fri, 15 July 2011 at 7:26 PM · edited Fri, 15 July 2011 at 7:27 PM
More metal fun. Tarnished silver.
Latexluv ( ) posted Fri, 15 July 2011 at 9:52 PM
Are you thinking to include some rusted and dented metals?
Weapons of choice:
bagginsbill ( ) posted Fri, 15 July 2011 at 10:01 PM · edited Fri, 15 July 2011 at 10:01 PM
Over time - initially I just need to get this basic/essential shader done and out the door.
Winterclaw ( ) posted Sat, 16 July 2011 at 12:25 AM
I've still got an awfully long ways to go it seems...
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
kawecki ( ) posted Sat, 16 July 2011 at 1:02 AM
Poser 4
Miss Nancy ( ) posted Sat, 16 July 2011 at 5:58 PM · edited Sat, 16 July 2011 at 6:05 PM
ricardo, to do one of these in poser 4 or earlier, place a camera with focal length = 1 mm at location of gold object, delete gold object, render the scene with that camera, then use that render as the reflection map for the gold object.
sponza ark gold procedural
what one notices when holding a large flat gold surface next to various coloured surfaces: it reflects red, orange, green and purple rather well, but blue looks almost black, hence one may need to decrease blue value in head-on colour of procedural.
kawecki ( ) posted Sat, 16 July 2011 at 9:55 PM · edited Sat, 16 July 2011 at 9:56 PM
Some critics. The romm in the scene looks very good, but the covenant ark looks very bad. The poles or handles are completely black without any relief and un-natural. The ark itself doesn't look as gold. It can look as metal or painted metal that has suffered severy corrosion or have been exposed to the environment for some centuries. The object in the back has gold reflections, but looks more as a black magic mirror.
RobynsVeil ( ) posted Sat, 16 July 2011 at 9:58 PM
Quote - Some critics. The romm in the scene looks very good, but the covenant ark looks very bad. The poles or handles are completely black without any relief and un-natural. The ark itself doesn't look as gold. It can look as metal or painted metal that has suffered severy corrosion or have been exposed to the environment for some centuries. The object in the back has gold reflections, but looks more as a black magic mirror.
In which image? The one just above your post? The handles show up brown on my monitor and look like wood. Might need to have a look at your monitor, maybe? :biggrin:
Metaphor of Chooks
kawecki ( ) posted Sat, 16 July 2011 at 10:20 PM
Quote - In which image? The one just above your post? The handles show up brown on my monitor and look like wood. Might need to have a look at your monitor, maybe?
In the image above. The poles doesn't look as wood and look dark and flat 2D surface (RGB 48.8.0) no matter how adjust the monitor. But the room continue to look very good in my monitor
RobynsVeil ( ) posted Sat, 16 July 2011 at 10:31 PM
Okay, I'll take your word for it, Kawecki. However, on my monitor, the handles look like a rose-wood, with a wood-grainish texture. Might need to check my monitor, then. :blink: Wonder what the original intent was of the image maker? Black or rose-wood? Or something else?
Metaphor of Chooks
Winterclaw ( ) posted Sat, 16 July 2011 at 10:38 PM
Tried experimenting a little more, didn't think I made much in the way of improvements though.
WARK!
kawecki ( ) posted Sat, 16 July 2011 at 10:41 PM
Well, not all the monitors looks the same, the famous gamma story. But, forget the handles, we are not discussing wood that is other story. Our focus is gold.
kawecki ( ) posted Sat, 16 July 2011 at 11:27 PM · edited Sat, 16 July 2011 at 11:28 PM
Returning to the gold question.
We must understand the behaviour of metals and the behaviour of metals can be very different depending on the roughness of its surface.
1-
Metals with very low roughness behaves as a mirror. In this case if we use Phong, Blinn or Torrance it will not make any difference. Just set the reflective color and use raytracing. With gold you set the reflective color to some yellow, with copper to some orange and with silver to white.
A metal with very low roughness it will act as a mirror and you will not see the metallic object, you will see distorsed reflections from the environment where the distorsion will depend on the geometric shape of the object. With planar surfaces there is not disrtion at all and you see a perfect mirror image on the object's surface.
2-
The other case are very rough metals. Very rough metals don't produce mirror-like reflections. Phong and Blinn are inadequated for this case. Torrance works pretty well. The main characteristics of very rough metals is that have a big specular area and illumination falling quickly beyond this area. You can approximate using Phong with very low exponent values (1 to 4), but is not the same as Torrance and don't produce off-specular peaks. This is what I used in my picture posted aomewhere above.
3-
For intermediate roughness metals there is no simple solution, there do not exist a simple model for this.
4-
In all the cases the diffuse compont of metals is very small or zero.
5-
For making images of metallic objects things get very complicated, unless we use simple geometric shapes as the famous metallic spheres.
The behaviour of a metallic surface changes dramatically with the roughness and roughness can be changed polishing the metallic object. If the object is not a simple geometrical shape and many times has a complicated shape the polishing is never perfect and so, we will have areas that have been polished very well, for eample the borders, and other areas where we were not able to polish.
The result is that we have a metallic object with areas that act as an almost perfect mirror and other areas that have a very rough surface.
cherokee69 ( ) posted Sun, 17 July 2011 at 5:50 AM
Quote - > Quote - In which image? The one just above your post? The handles show up brown on my monitor and look like wood. Might need to have a look at your monitor, maybe?
The poles look brown on my monitor.
Miss Nancy ( ) posted Sun, 17 July 2011 at 3:10 PM
on some monitors the gold is gonna look too dark, hence the wood will also look very dark on those monitors.  but looking at gold pieces, I realised it's difficult to even photograph them properly to show them off, the same as trying to photograph the dispersion fx of faceted gems.
The poles look brown to me as well (tops average ~ 90,30,0); ISTR they were originally made of wood of that colour (the nile thorn-tree that giraffes like to eat), but they may need to lighter and more specular to show up well, to show any displacement on them. there also were several errors in the last render in re: lighting and bad welds/smoothing on the lion and wall/floor in the background.  needs more IDL bounces/samples/shading rate.  bill explained how to do blurred reflections in an earlier thread, to give reflection fall-off.
3Dave ( ) posted Sun, 17 July 2011 at 9:53 PM
Quote - I realised it's difficult to even photograph them properly to show them off, the same as trying to photograph the dispersion fx of faceted gems
especially when our view of how they "should" look is at least in part tainted by other post-worked images in the media?
Miss Nancy ( ) posted Mon, 18 July 2011 at 11:53 PM · edited Mon, 18 July 2011 at 11:57 PM
wint, for optically accurate gold renders, we may await the debut of bill's metal shader pak. given the interest shown here, one would suggest including it (even if unfinished) in the next poser release (default runtime, procedurals) in order to obviate any marketplace issues.
p.s. somebody has got a gold sphere which one might compare to our renders, and some guy in ethiopia said he had an ark. when asked if we might see it, he went into his building and did something for a while. then he came out and averred that the ark was still extant, but wouldn't let us see it. :crying:
Afrodite-Ohki ( ) posted Tue, 19 July 2011 at 12:06 AM
Quote - schlick approx. of fresnel gold procedural
This looks f(*¨&¨$$&¨$%$ amazing.
And here I am, still failing miserably at getting anything to look anything near gold.
Miss Nancy ( ) posted Tue, 19 July 2011 at 12:16 AM
o.k., I'll give it up: bill actually posted the basic shader in his floor-tile thread.  it's  ... oh, fab, I can't even find it now.  the one with the blue tiles and the procedural with the schlick approximation inside a red rectangle.  all one really needs is to take a few fotos of some gold items, preferably as large, as flat and as solid gold as poss.
p.s. the coloured reflections may look fake, but I tried it with some flat gold surfaces and it really does reflect most colours quite well.
Winterclaw ( ) posted Tue, 19 July 2011 at 12:37 AM
Is it this thread?
WARK!
Miss Nancy ( ) posted Tue, 19 July 2011 at 5:44 PM
yes, wint.  if, in P8 or later, you can simplify that by deleting some of the tile nodes to get a gold-reflective surface, have 4 ray-trace bounces, use IDL if possible, use GCrender or similar etc., it may look more like gold.  bill gave the gold colour in the first post. you know you're getting close when the bottom half of your sphere is gold, assuming a light diffuse floor colour and IDL.
