Fri, Nov 22, 8:09 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2024 Nov 22 2:37 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: Please report any BUG issues with the new site in this thread only!
Larry F ( ) posted Mon, 11 July 2011 at 11:42 AM
Yes, I did that after reading the message below my question.  Still don't see it.
Will try again.  BRB.
Larry F ( ) posted Mon, 11 July 2011 at 11:46 AM · edited Mon, 11 July 2011 at 11:47 AM
Okay - NOPE! I see no option for "keep me logged in", just space for my name, then p/w and below that is a register.  Cleaned my cache, changed browsers, etc.
Oh - and "site mail", but that's it.  Thank you, though.
StaceyG ( ) posted Mon, 11 July 2011 at 11:48 AM
The techs will be addressing this issue soon
In the meantime
Here is the direct link
https://market.renderosity.com/login.php?
Larry F ( ) posted Mon, 11 July 2011 at 11:54 AM · edited Mon, 11 July 2011 at 11:55 AM
Hi, thanks for the link, but I don't see it. That is the same place I was.
I'll sign off again, clear, and try a bit later.
BTW, this is not a big deal; has been an annoyance. If not today, soon enough.
Thank you.
EDIT: Okay, I can see it in IE, but not Opera. Will sign off and check Firefox.
Larry F ( ) posted Mon, 11 July 2011 at 11:58 AM
Ooooo-KAY! That did it.  Thank you all. Persistently elusive little devil!
And, after all that, have to sign off and drive my wife somewhere!
lesbentley ( ) posted Tue, 12 July 2011 at 3:09 AM
In the above screen capture (FireFox 3.6.18, Win2k) the poster has embedded an off-site image, and this forces the cell that contains to post to assume a greater than normal width. This bug also existed previously, but now the new add panel on the right occludes part of the text and graphics. The post can't be read. I suggest that the cell that contains the graphic should have a limited width, to prevent this problem.
The URL captured in the above image is:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2831275
lesbentley ( ) posted Tue, 12 July 2011 at 3:14 AM · edited Tue, 12 July 2011 at 3:16 AM
P.S.
It's worse than I thought. Even the text not covered by the add runs off the edge of the page without wrapping!👎
lesbentley ( ) posted Tue, 12 July 2011 at 3:52 AM · edited Tue, 12 July 2011 at 3:53 AM
These issues predate the latest site changes, but it would be really nice if they fixed the Reply Box Editor so that the FireFox spell-check worked in the editor. like it used to do before they "fixed" (broke) the editor!
Also text placed in 'pre' tags now comes out with double line spacing. This is very bad, as pre tags are usually used for code snippets.
lesbentley ( ) posted Tue, 12 July 2011 at 9:02 AM
The length of the string in the 'Location' field affects the width of the avatar table cell. The maximum length for this string seems to be 39 characters. If all characters in the string are used, this gives a width for the cell of approximatelly 289 pixels. Perhaps it would be a good idea to restrict the width of the cell to 145 pixels and allow the Location string to wrap?
StaceyG ( ) posted Thu, 14 July 2011 at 11:42 AM
Yes, let me get with the techs
StaceyG ( ) posted Thu, 14 July 2011 at 1:27 PM
Les, this is now fixed:)
lesbentley ( ) posted Fri, 15 July 2011 at 7:06 AM
Yea! At last a change that makes things better instead of worse! Thanks :)
Richardphotos ( ) posted Fri, 15 July 2011 at 2:47 PM
Fatal error: Call to a member function execute() on a non-object in /rn1/renderosity/public_html/bw_core_functions.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code on line 1359
been getting this when posting a comment
jocko500 ( ) posted Fri, 15 July 2011 at 3:10 PM
me too and i can not upload i been trying from around 2:15 this after noon i posted a new treat to show that  some code 643 keep comeing up/ I can not copy and past on this site comments at all when i got window 7
what you see is not what you know; it in your face
StaceyG ( ) posted Fri, 15 July 2011 at 3:21 PM
Okay hold tight let me get the techs in here
StaceyG ( ) posted Fri, 15 July 2011 at 3:32 PM
This is now fixed. Let me know if you see any other weirdness
Biscuits ( ) posted Sun, 17 July 2011 at 5:14 PM
The page to the File Locker is not displaying in the right layout, everything is vertical.
My 2D&3D Store
My Youtube Channel
StaceyG ( ) posted Sun, 17 July 2011 at 8:04 PM
I've let the techs know Bis
Thanks
Khai-J-Bach ( ) posted Sun, 17 July 2011 at 8:34 PM
Quote - This is now fixed. Let me know if you see any other weirdness
well there was this elephant in a pink tutu doing the macarana......
StaceyG ( ) posted Tue, 19 July 2011 at 9:12 AM
LOL, you funny:)
Richardphotos ( ) posted Thu, 21 July 2011 at 9:14 AM
I have been noticing that many posts by various artists are not appearing to be in focus, but when they are opened in full screen they are.just since the new web page design
nobodyinparticular ( ) posted Thu, 21 July 2011 at 5:14 PM
Just over in the Poser forum, and the boxes on the side (Advertising, What's Hot Today, etc.) were overlapping the text boxes on the right side. When I came over here, it stopped. Isn't doing it now. Intermittent problem? Working too much on my part?
Haven't seen any elephants. Will keep an eye out. Did see sugarplums dancing around, but they turned out to be in my head.
Thanks for all the hard work. This really is a great place.
newbie
StaceyG ( ) posted Thu, 21 July 2011 at 6:33 PM
Hi newbie:):)
Can you post a direct link to what thread you were in over there when this happened so I can research further
nobodyinparticular ( ) posted Thu, 21 July 2011 at 11:10 PM · edited Thu, 21 July 2011 at 11:10 PM
I'm afraid I can't recall. Very busy day. I do remember checking and it was more than one thread. When I went to report it in this thread, I noticed it was no longer there. Went back and it was no longer happening. Perhaps my machine? I always customize the software I use. Still, standard FF 5, Win 7 up to date. Sorry to trouble you. Perhaps not worth fretting over. If it happens again, I will be more specific.
RedPhantom ( ) posted Fri, 22 July 2011 at 8:35 AM
Site Admin Online Now!
the problem nobodyin mentioned seems to be intermitent. One place I saw it at http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2831833
earlier but when I when i went back to get the link it was fine.
Also did the wiki retire? Can't find a link for it.
LaurieA ( ) posted Fri, 22 July 2011 at 11:36 AM
Wow Red, you're right. No wiki :(
RedPhantom ( ) posted Fri, 22 July 2011 at 3:32 PM
I guess we can see how popular it is if it took this long for people to notice it was gone.
nobodyinparticular ( ) posted Fri, 22 July 2011 at 3:45 PM
Quote - I guess we can see how popular it is if it took this long for people to notice it was gone.
Well, with a whole new look, it takes time for eyes to adjust to the light.
TomDart ( ) posted Fri, 22 July 2011 at 11:04 PM
For me its log in, not seeing my cookie?  Then take a link while in, go back and it is back to log-in, not the forum where I was     "Keep me logged in" is checked.
I believe this has been reported previously but this is the first occurance for me.  That is a pain.  So, a bug.
Daidalos ( ) posted Sat, 23 July 2011 at 12:01 PM
Dear Stacey and Staff.
First I would just like to say I like the new site. This blue is way better than that other greyish blue nastiness I always hated.
That having been said however I would like to ask a question. Where there any changes made to our bios. I cannot seem to find the post I'd put up there.
And more importantly, does this mean there will be a new logo contest, or has that gone by the wayside, as so many other of the um, lets just say "oldtimer" activities here have. LOL
Again great job on the new site layout guys.
With regards,
Daidalos
"The Blood is the life!"
scifiguy ( ) posted Sat, 23 July 2011 at 3:41 PM
Marketplace product pages cannot be viewed in Firefox 5. It appears that this is due to some tracking pixel you are using:
http://tracking.searchmarketing.com/welcome.asp?SMCID=1982&x=
What happens is the page loads briefly, then it refreshes to a totally blank screen and the browser sits there trying to load this thing. It does not alter the URL in the address bar like a page refresh, but if I use Firebug to "Inspect Element" on the blank page is shows that it is because this tracker has failed to load. It does not do it anywhere else on the site that I could find, only actual product pages. It is possible that their server sends incorrect/non standard headers that Firefox will no longer tolerate or something but I really don't know.
What I do know is that the one thing I can no longer on Renderosity is buy something. I'm not inclined to change browsers to accomodate a third party attempt to track me.
nruddock ( ) posted Sat, 23 July 2011 at 7:14 PM
Block images from that host (FF can do this without any plugins), or install NoScript which will block webbug images.
lesbentley ( ) posted Sun, 24 July 2011 at 7:27 AM
Quote - Again great job on the new site layout guys.
LOL!   :lol::lol::lol:
That's the best one I have heard in years!
TomDart ( ) posted Sun, 31 July 2011 at 7:36 PM
If I can duplicate this, you see it here and there. If not...
I type post, post reply, then go back one page.  There is my text box. So, I post reply again...
TomDart ( ) posted Sun, 31 July 2011 at 7:37 PM
FranOnTheEdge ( ) posted Mon, 01 August 2011 at 8:07 AM
Quote - Oh good.  I don't suppose we could just change the parts where the vendors are! roflmao!  I'm kidding!  Couldn't help myself.  The devil made me say it.(snicker)
Well I'm not kidding when I say "Yes, let the vendors have rotten blues if that's what they want - and give the rest of us back our nice greys" cos anywhere it's blue, I'm not going there.
If I did want to buy anything - I'd go elsewhere, where there are no rotten blues.  Trouble is I can't go to the galleries any more either.
YUK!!!
I can't even stand to go to my own homepage here....  it's dire!
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
Flint_Hawk ( ) posted Thu, 04 August 2011 at 9:42 AM
The last 2-3 days I've had a problem viewing the thumbnails in the Gallery. I'm attaching a screen capture that shows what is happening. I hate missing some of the thumbnails.
Clearing my cookies has not helped. I am using IE8.
StaceyG ( ) posted Thu, 04 August 2011 at 11:05 AM
Checking on this for you Flint
StaceyG ( ) posted Thu, 04 August 2011 at 11:17 AM
Quote - For me its log in, not seeing my cookie?  Then take a link while in, go back and it is back to log-in, not the forum where I was     "Keep me logged in" is checked.
This was fixed a few weeks ago Tom. Are you still having this problem?
StaceyG ( ) posted Thu, 04 August 2011 at 11:19 AM
Quote - The last 2-3 days I've had a problem viewing the thumbnails in the Gallery. I'm attaching a screen capture that shows what is happening. I hate missing some of the thumbnails.
Flint, this was due to the CSS you had in your gallery options with that large font size. It was pushing the page out cause the font was so large and if the image had a long title, it caused this. I've set it back to the standard site 12px but if you need the font larger than that, you will probably continue having the issue you described above.
Stac
StaceyG ( ) posted Thu, 04 August 2011 at 11:20 AM
Quote - If I can duplicate this, you see it here and there. If not...
If you hit the back button and go back on page, it will still be there so I'm not sure I'm understanding what you mean cause this is how it is supposed to work if you hit the back button...
StaceyG ( ) posted Thu, 04 August 2011 at 11:22 AM
Quote - Dear Stacey and Staff.
With regards,
Daidalos
Your bio? You mean on your Artist page? If so it's still there, just go to the Members tab on the top navigation the Artist Page. If that isn't what you mean, you will need to be more specific so I can help you.
The logo contest won't be happening this year as in the past several ones, the participation level has been really low and we are going to try and stick with a certain branded look with our Renderosity font.
Stac
StaceyG ( ) posted Thu, 04 August 2011 at 11:23 AM
Quote - I'm afraid I can't recall. Very busy day. I do remember checking and it was more than one thread. When I went to report it in this thread, I noticed it was no longer there. Went back and it was no longer happening. Perhaps my machine? I always customize the software I use. Still, standard FF 5, Win 7 up to date. Sorry to trouble you. Perhaps not worth fretting over. If it happens again, I will be more specific.
This issue was fixed a week or so ago as well. let me know if you see anything like this happening.
Thanks
Flint_Hawk ( ) posted Thu, 04 August 2011 at 11:23 AM
I notice the font size is a bit smaller now & I am able to see all of the thumbnails!
Thank you StaceyG !
StaceyG ( ) posted Thu, 04 August 2011 at 11:24 AM
Quote - The page to the File Locker is not displaying in the right layout, everything is vertical.
This had been fixed but appears to be out of whack again so I'm having the techs look again.
Thanks
frankie96 ( ) posted Sat, 06 August 2011 at 6:26 PM
Trying to post an image...get everything completed and the hit (preview image) and it deletes the data in the box where the browsed image was put...and nothing happens..does the same if you hit (submit image).  Logged off and tried again  several times to no avail..is there something in the new format that I'm missing..thanks for listening...
FutureFantasyDesign ( ) posted Sat, 06 August 2011 at 7:51 PM
Hi Stacey (*oh you are on vacation?!)
Well to whom ever is taking her place looking here, I am not getting any 'bot' mail notices of thread responses, site mail or any other notices. Could someone check on me? Thank you! :D
HugZ!
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
Winterclaw ( ) posted Mon, 08 August 2011 at 12:27 PM · edited Mon, 08 August 2011 at 12:28 PM
The connect for youtube is on the wrong line for me (below the other ones).
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
StaceyG ( ) posted Mon, 08 August 2011 at 2:22 PM
WC,
What browser and version? Can you show me a screenshot?
Thanks
Winterclaw ( ) posted Thu, 11 August 2011 at 4:20 PM
Image leak in the chat room.
If someone posts a picture in the den room, you can see it in the virtual tavern room.
WARK!
