Sat, Jan 25, 4:26 AM CST
Subject: The real reason for weight mapping...
Winterclaw ( ) posted Thu, 11 August 2011 at 11:24 AM · edited Fri, 10 January 2025 at 6:17 AM
More realistic (aka Soul Calibur style) breast jiggle. :thumbupboth:
Now all we need is a new base character that will support this feature properly...  IE one with two bones in each breast to control movement.  😉
Who's with me on this?!
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
MistyLaraCarrara ( ) posted Thu, 11 August 2011 at 11:50 AM
man bewbs, too?
the monty will need some flex moves !
Cage ( ) posted Thu, 11 August 2011 at 12:43 PM
Yes, weight mapping should be much more flexible for body handle type manipulation bones.  It's certainly something I would try.  Along with other fleshy bits, and bones for hair or skirts.  Possibly even something like a chain or grid of body handle bones to deform a sheet or something.  Could one use this rigging to animate a bedsheet being folded?  Hmm.
araneldon ( ) posted Thu, 11 August 2011 at 1:34 PM
Quote - More realistic (aka Soul Calibur style) breast jiggle. :thumbupboth:
You totally stole that idea from Genesis, it already has breast bones!
grichter ( ) posted Thu, 11 August 2011 at 1:44 PM
Wnterclaw, "Shake, shake, shake, shake your booty!"
K.C. and the Sunshine band
There was a product in the store here I believe about a year after V4 came out that did add bones to the breasts.   "I'm bad to the bone" George Thorogood
Gary
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 3:01 PM
http://www.renderosity.com/mod/bcs/vicky-4-nipples-/61411
If you want good animated breast movement, Dynachest still works like a charm
http://www.renderosity.com/mod/bcs/dynachest/66004
Combine it with NBM at Daz and you got everything you need. I've rarely used the Vicky nipples bones because I never found a need for it. The other stuff does the trick. :)
NanetteTredoux ( ) posted Thu, 11 August 2011 at 3:46 PM
Not realistic bellywobble and flappy flabby underarms? Or jiggly chinwattle?
Poser 11 Pro, Windows 10
ShaaraMuse3D ( ) posted Thu, 11 August 2011 at 4:16 PM
Any realistic body physics would be really nice.
grichter ( ) posted Thu, 11 August 2011 at 4:34 PM
"The real reason for weight mapping" .....is if you are out camping and pull out a map and spread it out on a picnic table to decide which trials you where going to go hike on. That weight mapping is the act of putting rocks on the corners of your map to keep the edges from blowing up and folding over when it is breezy!
Gary
moogal ( ) posted Fri, 12 August 2011 at 1:50 PM
Quote - Not realistic bellywobble and flappy flabby underarms? Or jiggly chinwattle?
That's why we still need a generic spring or zone based solution.  And adding bones to body masses doesn't really solve the problem if they still have to be manually animated.
Winterclaw ( ) posted Fri, 12 August 2011 at 2:08 PM
You don't look in my gallery much, do you?  ;)
WARK!
pjz99 ( ) posted Fri, 12 August 2011 at 9:23 PM
dlfurman ( ) posted Sat, 13 August 2011 at 1:36 PM
Online Now!
Well for me the thing is clothing was impossible may be possible, if that dragon is any indication.
Spider-Man, Spider-Woman, Storm's original outfit and Black Bolt will be able to be properly done!
They all have webbing or some cloth linking arms and torso. Cool stuff ahead!
Cage ( ) posted Sat, 13 August 2011 at 1:55 PM
Ooh.  Good point.  And Banshee, with the underarm panels.  Some versions of Spider-Man.  And webbed fingers!  Wow, where's Bloodsong?  This would be exciting for Bloodsong.
Winterclaw ( ) posted Sat, 13 August 2011 at 2:27 PM
Quote - How about more realistic butts:
http://www.runtimedna.com/forum/showthread.php?63341-Samples-of-weighted-bulge-settings
I saw that earlier...  more realistic butts are good too.
WARK!
ShaaraMuse3D ( ) posted Sat, 13 August 2011 at 2:30 PM
I second that. Been using Ralfetas Bend to simulate that effect on V4.
