Community Center F.A.Q (Last Updated: 2025 Jan 30 3:24 pm)
I was just looking in the galleries (just clicked on what's new) and I noticed something. All the lower case y's look like v's. So I started paying more attention and the bottom parts of all the lower case letters in title of the artwork were getting chopped off.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
Hey Stacey??? While you are at it, I have not gotten bots on my forum posts/site mails or gallery comments in weeks! I have to come in and check manually on all 3. I can't find a way to correct this on my side. Could you let Tech know about this too???
Come to think on it, I do not recall Monthly letters or sales notices either! I am getting Bundle notices tho and Wishlist notices just fine.
Welcome back BTW!
HugZ!
Ariana
Water, the ultimate
weapon...
I think Blake was checking on this for you and everything seems to go out fine to you from our end. Do you have rendo email addresses as valid contacts in your email client and have you checked all your junk/spam folders to make sure they are not in there? They seem to be fine going out and other gmail account holders haven't had this issue that we are aware of.
Definitely Improved on the FB/Comments! At least they show up. White may not be the best color, but it beats blue/black on the RO shade of blue! Maybe you might consider the lighter shade of blue like here in this thread, with white lettering? The pics show up fairly well and the posts show up good as well too!
My bot problem is solved turns out it was a G-Mail glitch.
ThanX for the help on both. Big ThanX to Blake for the follow up too!!! :)
HugZ!
Ariana
Water, the ultimate
weapon...
Haven't had any problems. Don't much like the colors but heck, that's a minor quibble, and I'm sure you guys probably still have the options for the user to change the colors if it really bugs me. I'm not crazy about the drop down menus either, but since I can't suggest a better way of doing them, why complain.
Talent is God's gift to you. Using it is your gift to God.
The fix is to adjust your stylesheet to include :-
body { line-height: 20px; }
The exact value you need is 4px larger than the font size you've used (unless you've also altered the top or bottom padding, in which case add the sum of the new values for those).
If you've set the font size in other units (e.g. points) then you'll have to adjust until the lines look right as there's no way to mix units.
If the line-height is set in other styles you may have to also adjust those if not everything is correct.
Just had an odd one, I was trying to replace an image in the edit function. Uploaded the new file, and saved the changes. The gallery thumbnail was good after a refresh, the reduced size displayed corrrectly but every time I tried ot open the full size it went back to the old image. I went back into edit and it was showing the old image in that page again even while diplaying the correct thumb aqnd reduced size. Actually had to delete the whole thing and upload as new for it to finally work.
Anyone else seen this?
I was just checking out D3D's poser file editor and in the description, comments, etc tabs I got this error:
ERROR: Invalid request: 37225
I've seen this in a few other products as well with the number being the same as the store ID number of the product.
WARK!
Yep.
Check out this link and what comes up. The URL meantions a steampunk bomber. I guess that was the problem.
WARK!
Not atm. I guess someone linked me a pervious version.
But the item name of the URL is still messed up.
WARK!
Quote - But the item name of the URL is still messed up.
It's only the item number that matters, the text in the path segment after "bcs" and before the number can be anything and you'll still get the right page, e.g. -> http://www.renderosity.com/mod/bcs/anythingcangohere/88719
ok been just putting up with it... but appreciate the help that said to do this
<span style="font-size:14px;">BUT NOW I CAN'T FIND HOW TO GET BACK INTO MY CSS.. AND NO AM NOT</span>
<span style="font-size:14px;">SHOUTING... STUCK IN CAPS. </span>
<span style="font-size:14px;">THANKS!! :)</span>
Life Requires Assembly and we all know how THAT goes!
Attached Link: http://www.renderosity.com/mod/gallery/member.php?my_options
The gallery stylesheet (and other gallery options) are available at the attached link.This just started about an hour or so...
I keep getting the little balloon explosion with this error message.
Fatal error: MySQL error: Host 'arthur.bondware.com' is blocked because of many connection errors; unblock with 'mysqladmin flush-hosts' in**/rn1/renderosity/public_html/classes/class.bw_Database.php(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code(1) : eval()'d code** on line 162
In Xanadu did Kublai Khan a pleasuredome erect
Hey how do you delete all of these site notices? There are waaaay too many and not all of them do I need to visit or want to keep!!!
There is no delete button for them that I see. Help!!!
Ariana
Water, the ultimate
weapon...
Quote - Tried to upload an image this morning (first time since August 5). Only tried one time. My image never appeared in my gallery and then I saw message " you've reached your maximum number of uploads today). Any suggestions? Thanks
Please see the information at the link below from our FAQ/Help area
http://www.renderosity.com/mod/service/index.php?questionid=10
Thanks
Stacey
Quote - > Quote - Hey any answer on all of those site notices? How do we delete them please????
Thank you... ;)
Ariana
Ariana,
The older events go under the "Older Events" button. Right now there is not a "hide or remove".. We are still enhancing this feature so hopefully something like that is coming:)
Are you serious??? Should not the whole "system" have been completed before it was implimented??? Not to mention the wasted space these things are taking up? Thousands of little notices that are just sitting around. Just seems like the IT folk should have had the whole styem developed before even starting and then letting it just hang there.
I built a kitchen once, didn't see the contractor for 6 months...
Add/Remove/Delete should have been the first function installed before the switch.
Ariana
Water, the ultimate
weapon...
Quote - Add/Remove/Delete should have been the first function installed before the switch.
Which hasn't happened yet
My Freebies
Buy stuff on RedBubble
This notifications system works as intended. The notifications that stay under "older events" is supposed to stay just like that. As I stated we MAY put a hide/remove option there in the future. It was completed for the gallery as intended. When I said it was still being "enhanced" I was mainly referring to other pieces that would involve seeing notifications for other areas of the site besides just gallery as well as possibly adding other things like a hide/remove if we feel it becomes necessary but it is "completed" the way it's designed to work Ariana.
When you have new events (the little color burst notifications is there showing you have new events since you last checked) and you click to go to that notifications page then you will ONLY see the events that occured since the last time you had any new events, all the rest are not shown, they are under that "Older Event" button so you don't have to see them unless you choose to click on that older event button. If you go back to that page without any NEW events then it will show the last 10 events that occurred for you and if you want to see more than the last 10 then click the older events button and it will show you even older ones and that is how it's designed to work.
Hi Stacey,
What I am getting at is the enormous waste of bandwidth these possibly millions of little notices end up taking because they are just there. Doesn't Ro have a limit of "junk" it wants to have on site like this stuff? I mean I actually removed all of my fav gallery notices to stop this mess. So now all that is there is junk that is stuck.
Please allow us to have a delete option. I mean after all, that is what we could do with the e-mails. I hate clutter.
HuggerZ!
Ariana
Water, the ultimate
weapon...
I'm confused cause you don't see any "clutter" unless you choose to click on the older events button. The most "clutter" you will ever see without clicking for older is 10 notifications..
I mean I tend to agree with wanting to have a hide/remove button at some point and hopefully once we get all the pieces in place for all the notification areas then we can look into things like that more:)
That sounds fair. It just is weird having that stuff! I rarely use notices, I tend to skim through my favs on my own. So notices are more like nuisances! LOL!
HuggerZ!
Ariana
Water, the ultimate
weapon...
hey I deleted all of my Artists favs and yet I am STILL getting notices?! o0 MAKE THEM STOP!!!
Seriously are these dang things stuck in there??? I don't like this! :(
Ariana
Water, the ultimate
weapon...
I've sent an email to the techs to look into both issues. I'm showing I haven't gotten any of the new ones in 2 days either Autumn so something definitely is not right.
I'll let you all know when I hear back but it might be Monday since it's the weekend and not sure if they will have a chance to research this until then.
Thanks for the head's up
Stacey
Yes I am aware of that, Just gotta get with the techs when they have a minute.
Thanks WC
