Mon, Dec 23, 6:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: The little things, P 2012
bevans84 ( ) posted Thu, 22 September 2011 at 12:48 PM · edited Mon, 23 December 2024 at 6:00 PM
All these little things I keep finding are really nice, like the morph brush remembering it's last setting for each action, or the flyout menus under the Body Parts menu, or orbiting the camera around the selected object or body part.
It makes me wonder what is going to turn up next. :-) I think most folks are aware of the big things like SSS and weight mapping, but all this attention to detail on the little things is refreshing.
Kudo's to SmithMicro and all who were involved in this release
wimvdb ( ) posted Thu, 22 September 2011 at 1:02 PM
Add to that:
 - Display target in the library for drag and drop
 - turn on/off "Remove backfacing polys" for preview
 - Dimension settings button in Render settings
 - "not visible in camera" for objects and figure in properties
 - New lights are created with a white color
 - Gamma correction on Preview mode
 - Delete attached in the Delete Figure dialoog
 - Groupings: Attach figures and props to a Grouping and manipulate the group (scale, rotate, translate)
 -Texture Filter can be set as crisp
  • background texture caching
  • faster rendering of depth queue
MistyLaraCarrara ( ) posted Thu, 22 September 2011 at 1:36 PM
oooo, white lights-new and Delete attached  :wub:
MistyLaraCarrara ( ) posted Thu, 22 September 2011 at 2:21 PM
it's nice to see the Poser banners instead of the Filter Forge. nothing against the Forge, but the banner iz so big and in your face :unsure:
Roy G ( ) posted Thu, 22 September 2011 at 2:28 PM
I'm still waiting for my physical shipment. But I’m curious. Does Poser still default to  the "Textures" directory for image export? That has bugged me for a very long time.
wimvdb ( ) posted Thu, 22 September 2011 at 2:43 PM
Quote - I'm still waiting for my physical shipment. But I’m curious. Does Poser still default to  the "Textures" directory for image export? That has bugged me for a very long time.
They have tried to improve things regarding the default folders where textures, images and objects are saved/loaded from. It is a bit better now, but it still needs a lot of improvement.
It is not as simple as having the Textures folder as default for Export Image, but it tries to be intelligent about it, taking into account where the last images used was coming from - not making a distinction between a texture image and and rendered image.
I keep the issues regarding this open until we have good defaults, but it is not there yet.
RobynsVeil ( ) posted Thu, 22 September 2011 at 6:04 PM
No question: this is the most thoughtful, well-designed release ever. I am convinced SM did listen to customers. I'm keen to see where they'll go with the cloth room - heard it might be on the next development cycle for face-lifting - but to be quite honest I feel like there so much I'm still learning about the current one that I'm still lightyears away from hitting any "wall"...
Metaphor of Chooks
3-d-c ( ) posted Sat, 24 September 2011 at 10:22 AM
I must agree! Finally a nice "Depth of Field" result after all.
Well done SM
3-D-Cs Facebook Page: 3-D-C on Facebook
Check the K-Azonica Story and World Evolving:   K-Azonica
Check my website and products and the large freebie section:   3-D-C
wimvdb ( ) posted Sat, 24 September 2011 at 11:11 AM
One other tiny detail I forgot: The render engine now runs at priority of "below normal" on Windows. I am not sure what it does on the Mac
So it will run at full speed unless other processes need processor time at which time these processes take priority. This makes the machine much more responsive when you use other applications at the same time and you render and there is no need anymore for other tricks/bypasses to achieve this like lowering the number of threads.
Dale B ( ) posted Sat, 24 September 2011 at 11:27 AM
The multithreading in the cloth room is wonderful. I threw an old horror scene at 2012; basically where a mage removes the skin from her victim (this was just after the V3 muscle maps came out). So of course I had a V3 floating over the bad mage's arm to be clothified. That scene has crased every Poser from P6 on......but 2012 did it. And while one core would take the lion's share of a frame cycle, it rotated around, and all 6 cores showed activity. There was some mesh breakage, but that has more to do with polygon type in the V3 mesh, not the clothification.
That's one thing very much improved. Now to find my other 'break the Poser' scenes and see how -they- do...!
SteveJax ( ) posted Sat, 24 September 2011 at 1:15 PM
It was nice finding a premade SSS material for P6 James. Would have been nice to find default SSS shaders for everyone else included though.
bantha ( ) posted Sun, 25 September 2011 at 4:01 AM
The SSS material for P6 James just uses Fastscatter, which is kind of obsolete does not use real SSS. Has nothing to do with the new features.
-"Amazing Grace" Hopper
vilters ( ) posted Sun, 25 September 2011 at 2:46 PM
Working smart props, that inherit bends, and save into the prop libranry.
wONDERFULL !
wONDERFULL !
SteveJax ( ) posted Sun, 25 September 2011 at 3:34 PM
Quote - The SSS material for P6 James just uses Fastscatter, which is kind of obsolete does not use real SSS. Has nothing to do with the new features.
Yeah I figured that out pretty quickly when I didn't see him show up during the SSS pass of the render, just his teeth and eyeballs which I had manually added the SSS node to.
RobynsVeil ( ) posted Sun, 25 September 2011 at 5:00 PM
Quote - > Quote - The SSS material for P6 James just uses Fastscatter, which is kind of obsolete does not use real SSS. Has nothing to do with the new features.
Need to get some decent teeth and eye shaders using SSS... how do yours look, Steve? Are you happy with them? 😄
Metaphor of Chooks
JunkoH ( ) posted Sun, 25 September 2011 at 6:13 PM
With every new version of Poser, there is a different intro and credit screen. I don't know about you, but no matter how novel it may appear at first, I don't really want to see it a few thousand times.
If you feel adventurous, locate
Runtime/ui/30000_credits_splash.psd
and save a copy somewhere, or in the same folder under a different name.
The intro splash screen is layer 30510 and you can paint whatever with a 2D program that supports that format.
The "about" screen is layer 30511 but I only occasionally have to look at it, so it remains the same.
SteveJax ( ) posted Mon, 26 September 2011 at 3:34 AM · edited Mon, 26 September 2011 at 3:43 AM
Quote - Need to get some decent teeth and eye shaders using SSS... how do yours look, Steve? Are you happy with them? 😄
So far I've only been playing with P6 James and he doesn't even come with a teeth texture. I only have one texture for him and it's from a freebie made by Karen, our old Poser moderator from back in the day. Am I happy with them? Yeah! They were free. Do the look the best. Not really. As for eyes, so far, all I've done is use the wacro on them.
So I guess I'm saying don't go by my experiences. LOL. I don't normally strive for total realism in my renders. They're more story oriented than art oriented.
Quote - The intro splash screen is layer 30510 and you can paint whatever with a 2D program that supports that format.
You don't even really need a backup of that file if you just rename layer 30510 to 30510-bac and then just name your new splash screen layer 30510.
