DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
The draft documentation is here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/start ERC freeze requires that you have the changes you want to make in place, then you go to the property Editor and open the option menu (click the little menu button in the top corner, or right-click the tab) and select ERC Freeze.... In the dialogue, pick your figure, pick the node with the controller you want to govern the settings, and pick the property you want to control the settings (presumably your morph), then make sure the changes you want linked to the morph are ticked in the Freeze properties list and click Accept.
I have imported and applied a head morph to Genesis, but the eyes are shifted so I need to adjust the bones/joints for the eyes. This is easily done (using the Joint Editor), but I haven't found a way to save the resultant figure in a way that also saves the changes the changes (Save as DSF Figure does not save the joint changes).
How do you save Joint Editor changes for a figure?
There is a lot to like in DS4, but the documentation (being completely missing) is not one of them...
