Fri, Jan 3, 2:48 PM CST
Subject: Stupid question on joints / rigging
colorcurvature ( ) posted Fri, 25 November 2011 at 9:28 AM · edited Tue, 31 December 2024 at 4:55 PM
Hi,
I have never rigged a figure before, and now that there is weightmapping, I feel a bit more encouraged to actually learn it. So my first question would be wether we have a reverse weight map functionality. Say, I place my joint center at position ABC and bend my actor 45 degrees. Can I directly sculpt the deformed actor and Poser makes a reverse calculation to create the weight map as necessary or is it only possible to do it the "forward" way, by painting the map and seeing the effect?
I'm on the go so I do not have access to the manual :/
Thanks,
col
Paloth ( ) posted Fri, 25 November 2011 at 10:30 AM · edited Fri, 25 November 2011 at 10:30 AM
If I'm understanding your question correctly, the answer is Yes. If you bend a limb you can create the weight map while the limb is bent. Its effect will be phased out to zero as the limb rotates to the default.
Good job on MorphLoader by the way. It is working perfectly.
colorcurvature ( ) posted Fri, 25 November 2011 at 11:03 AM
Thanks, thats nice to hear.
Yes, I understand one can paint the weightmap while the actor is bent.
But this means that "morph brush" and "weightmap brush" are seperate things? There is no "morphweightmap brush" that does both together?
I had the thought that one could "split" a morph into a weight map plus another morph that would capture whatever the weight map couldn't do. And this in a way that the weight map would do as much as possible and the morph doing the "rest", so that one had a morph which as flyweight as possible.
Do I make any sense?
Paloth ( ) posted Fri, 25 November 2011 at 11:35 AM
The morph brush and weight map brush are separate. There is no "morph weight brush." I wish there was. Sometimes a weight map will only move the vertices relative to the other vertices instead of inward or outward, which might be the needed deformation. As far as I know, morphs and weights are distinct in Poser.
Cage ( ) posted Fri, 25 November 2011 at 1:41 PM
Weight maps for bulges are a very useful and powerful feature of Poser's weight mapping.  On the right, in the attached image, a shoulder bend with bulge maps deactivated.  On the left, bulge maps active.
Cage ( ) posted Fri, 25 November 2011 at 1:43 PM
Quote - Do I make any sense?
I think you make sense.  But Poser doesn't have any kind of automated or built-in features which could do that, currently.  Possibly something could be scripted?
pjz99 ( ) posted Fri, 25 November 2011 at 2:40 PM · edited Fri, 25 November 2011 at 2:44 PM
Quote - I had the thought that one could "split" a morph into a weight map plus another morph that would capture whatever the weight map couldn't do. And this in a way that the weight map would do as much as possible and the morph doing the "rest", so that one had a morph which as flyweight as possible.
Technically I think you could do this, as joint and bulge deformations are restricted to one axis ("in" and "out", in relation to the joint axis); you could examine the position of each vert and only split out the "in/out" part of the delta.  On the other hand, I dunno how valuable that would be, as you'd still need the morph target, and the resulting morph target alone would (I think) very likely be something impossible to modify without trashing it.
e: hmm, the resulting morph target would really just be the verts' sliding around along the normals' placement after the joint deformation is done wouldn't it?  Ask Mike/Diogenes/Phantom3d, he'd probably find that useful for easing texture stretching.
My Freebies
colorcurvature ( ) posted Sat, 26 November 2011 at 1:35 AM
Thereis no api to set weightmap weights, is there?  I didnt know the bulge can be weightmapped too. Interesting indeed.
pjz99 ( ) posted Sat, 26 November 2011 at 4:49 PM · edited Sat, 26 November 2011 at 4:51 PM
I know at least part of weight mapping can be handled via script, e.g. look in the PoserPython Methods Manual:
Quote - JointVertexWeights Explanation
Get a list of vertex weights for the specified joint axis on this actor.
Arguments
The axis argument should be ‘x’, ‘y’, or ‘z’. If no such joint is present, the method will return None.
Syntax
JointVertexWeights( axis)
Example
actor.JointVertexWeight(X)
e: I don't see a corresponding "set" function, unfortunately
My Freebies
colorcurvature ( ) posted Sat, 26 November 2011 at 5:05 PM
Yes. I wonder, why on earth a read api if there is no write api.
pjz99 ( ) posted Sat, 26 November 2011 at 7:31 PM
I kinda think it's there, but not documented.  Mail Phil Cooke about it, he'd know for sure (updated wardrobe wizard).
http://www.philc.net/contact_details.php
My Freebies
